Author Topic: Mix Match 750 build - next stage cheap 836 kit  (Read 67377 times)
Re: Mix Match 750 build - next stage cheap 836 kit
« Reply #550 on: July 05, 2025, 08:47:36 AM »
Now that it's this far along, can we see some more photos? It looks great.
 :) yes.
« Reply #551 on: July 05, 2025, 09:56:58 AM »
I need a heat gun to get my windshield on the fairing and also need some new plastic 10mm hardware to bolt it together, the stuff I have is chewed up. I wonder if I can get away with half metal half plastic hardware to add some strength.
The reason for the plastic screws and nuts are so they will brake away if you contact the windshield in a forward launch,  in a quick stop......
Acw hardware usually carries plastic hardware.
Offline Shtonecb500
    • Youtube profile
« Reply #552 on: July 07, 2025, 05:55:02 AM »
good to know, I went to one of my local ace hardware stores and they only had white plastic in one size, screws ands nuts no washers. I ended up buying steel Allen bolts, they were a little longer to assist with getting the windshield on rather than struggling with poor fitting and the original hardware not being long enough to make it through the holes. Ill have to keep looking for the proper hardware. With that being said, I dont really love the headlight attachment system for the FM2 fairing, its ugly and requires me to loosen my headlight every time so im thinking of a different attachment system.
« Last Edit: July 07, 2025, 09:53:35 AM by Shtonecb500 »
Offline Shtonecb500
    • Youtube profile
« Reply #553 on: July 07, 2025, 05:58:27 AM »
I've been trying to get as many miles as possible on this puppy, my gf thinks I should name it, she recommended something cat related since its black and has multiple lives.
can only upload two at a time.
« Last Edit: July 07, 2025, 06:06:40 AM by Shtonecb500 »
« Reply #554 on: July 07, 2025, 08:50:48 AM »
Glad to hear you are back on the road!  Take it easy and be safe and have fun!
Offline Alan F.
« Reply #555 on: July 08, 2025, 08:43:53 PM »
I vote for Mister Whiskers!
Congrats on a quick recovery for the bike.
How are your nerves doing?
The day after bringing home my RE Interceptor in 2022 I got hit in my work van, that messed up my intersection skills for a long time, just noticing lately that I'm doing ok again.
I hope you have an easier time than that.
Offline Shtonecb500
    • Youtube profile
« Reply #556 on: July 18, 2025, 04:37:12 PM »
Thank brotha.
Offline Shtonecb500
    • Youtube profile
« Reply #557 on: July 18, 2025, 04:39:22 PM »
Mister whiskers doesn't sound bad. I think im doing alright as far as traffic and decision making so far, thinking about everything and remembering the basics.
Offline Kelly E
  • Geriatric Hooligan
« Reply #558 on: July 18, 2025, 07:41:21 PM »
The best lesson I've ever learned was to always ride like you're invisible.
Maybe name the bike Felix after the old cartoon. 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #559 on: July 18, 2025, 08:10:47 PM »
Cougar2?
Black cougars are mighty rare, but there's at least 1 in Colorado.
Offline Nachtderuntoten
« Reply #560 on: August 15, 2025, 12:35:52 PM »
I was able to place the exhaust in a vise get it cherry red on the bent header down at the collector, and move it closer to where it should be before trying to fit it to the motor in the stand.In the stand we got headers 3 and 4 attached first then got 1 and 2 cherry and got them in position and tightened up the bolts, it was way easier than I thought but I had help handling the torch while I moved the pipes. Synced the carbs and  took the bike up and down the road and it's great. The Shoei fairing got spray bombed and almost has all of the hardware swapped over and I have a plan of attack for the fender thanks to Godffery.
I'm super happy I was able to salvage my pipe, cant wait to ride this weekend.
replaced parts: entire triple tree assembly, fork tubes, fork lowers, front rim, (1) spoke nipple, (1) speedo/tach housing cover, (1) tire, Shoei fairing.
Did you get original new old stock fork parts, or did you get reproductions? Where would you recommend fork tubes from?
Offline Shtonecb500
    • Youtube profile
« Reply #561 on: August 27, 2025, 10:12:15 PM »
I used original parts, I was considering fork tubes for sale on eBay, race tech tubes, or from vintagecb750.com.
« Reply #562 on: September 01, 2025, 10:44:22 AM »
The tubes from vintagecb750 are a good deal, but don’t be tempted by their fork caps. The last sets I tried were junk. They didn’t even thread 1/2 way in before they started to seize up. Original Honda parts screwed in perfectly, so definitely lousy caps with poorly cut threads.
Offline Godffery
  • Godffery's Garage
« Reply #563 on: September 05, 2025, 01:45:18 PM »
Actually I've experienced that issue before with new Fork Tubs.  Turned out to be the New Tubes were cut with a tighter tolerance then the original Honda ones were, and if the replacement Caps were threaded according the more forgiving (a bit looser) Honda Tubes, then they would be too tight and bind.
