Author Topic: Clicking noise 1973 cb500  (Read 1284 times)
Offline scott jones
« on: August 01, 2019, 05:43:00 AM »
There is a clicking noise while riding my bike. It seems to be coming form the final drive area & engine chain sprocket. The noise is persistant when coasting in neutral. I have spun the rear wheel while the bike is on the center stand & in neutral. I hear no unusal noises or loud clicking. Any ideas before I take the left engine side cover off & look in there?
Offline DaveBarbier
Re: Clicking noise 1973 cb500
« Reply #1 on: August 01, 2019, 05:58:24 AM »
I’d make sure the rear sprocket is aligned with the front. You aren’t using an o-ring chain are you? If it’s on the center stand the rear suspension is relaxed, might only do it if it’s loaded. I’d remove the cover and have a look. Does it do it if you push the bike around with engine off? I assume it changes frequency as you speed up/slow down?
Offline Scott S
« Reply #2 on: August 01, 2019, 08:40:12 AM »
 Center stand touching the chain?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline scott jones
« Reply #3 on: August 01, 2019, 09:34:41 AM »
I don't think I have a oring chain. I'm sure its the original chain but you guys don't know of any tell tale symptoms like this clicking sound for the cb500? I'll check the chain and see if it's hitting anything. I hadn't thought about the fact the rear suspension is relaxed on the center stand. I hear the noise when I'm riding the bike espescially in neutral and the rear suspension is loaded. The side cover is a little intimidating because of the clutch cable. I'll check it out. Thanks, Scott.
Offline scott jones
« Reply #4 on: August 02, 2019, 04:03:36 AM »
I'm pretty sure it's the chain making the clicking noise. Took a look at it last night. It's in rough shape. Probably should be replaced. It was very loose too.
Offline DaveBarbier
« Reply #5 on: August 02, 2019, 04:28:23 AM »
Chain and sprockets normally get replaced together.
  • I'm back
« Reply #6 on: August 02, 2019, 06:51:50 AM »
Normally for a CB500 is that a set of sprockets will last 2 standard chains. At least they did on mine for the last 100.000 km. (I learned this from a dealer who owned a CB500 himself)
Offline scott jones
« Reply #7 on: August 02, 2019, 10:40:09 AM »
I'm pretty sure it's the original chain. The bike has 20,000 miles on it. I hope the sprockets are ok. I want to take the side cover off but I'm afraid to. Looks complicated. I'm sure its very dirty in there.
Offline Scott S
« Reply #8 on: August 02, 2019, 11:28:17 AM »
 It's not complicated.  Probably the hardest part is getting the screws broken free. Be sure to check the clutch pushrod to see if it's broken. And don't lose the ball bearing in the lifter mechanism.
'71 CB500 K0
'81 Yamaha XS650
Offline scott jones
« Reply #9 on: August 02, 2019, 11:46:19 AM »
Ok thanks. I'll look at it this weekend. I do have a nut driver for the screws.
  • I'm back
« Reply #10 on: August 02, 2019, 12:58:26 PM »
An impact driver is ideal. You may consider to replace the crossheads by allen bolts. Do not forget to tighten the cover well.
Offline scott jones
« Reply #11 on: August 02, 2019, 01:11:06 PM »
I meant impact driver. Thanks I will.
Offline Scott S
« Reply #12 on: August 02, 2019, 05:53:22 PM »
 Check your center stand.  Is it rubbing the chain?
My ex GF had a 400F. Somehow,  a nut got caught in the chain..... can't remember details now.... but put the bike on the center stand and rotate the wheel.
 Then, put it on the ground and roll it.
 K.I.S.S. Look for the simple stuff first?
'71 CB500 K0
'81 Yamaha XS650
Offline scott jones
« Reply #13 on: August 05, 2019, 06:45:04 AM »
Thanks buddy. The center stand is hitting the chain. I'll make a stop for it.  :)
Offline Scott S
« Reply #14 on: August 05, 2019, 07:09:05 AM »
 CB750.com, 4into1.com,  etc, all sell versions of this.  Or fab one up from scrap metal.
 I'll drill a hole in the end and attach a rubber bumper,  too.
« Last Edit: August 05, 2019, 07:11:51 AM by Scott S »
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
'71 CB500 K0
'81 Yamaha XS650
Offline scott jones
« Reply #16 on: August 05, 2019, 02:31:24 PM »
Thats exactly what i am going to do. Thanks.
