Author Topic: Ethanol question  (Read 3070 times)
Offline bert96
  • past ride
Ethanol question
« on: November 19, 2019, 03:20:39 AM »
Hi,
I live in Quebec/Canada and the governement want to increase the ethanol in gas (15%). Do you see problems for our old bikes to run with a high ethanol gas!?!
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline Erny
Re: Ethanol question
« Reply #1 on: November 19, 2019, 06:10:54 AM »
15%??? That's crazy!
Here in Slovakia they will increase from current 5 to 10 % from 2020. This is already bad for old engines, especially carbs that were not designed for.
I think that bike will be running (but worse) provided you will use it regularly.
Even now, fuel manufacturers declares petrol stability and quality only 3 months after it is produced.
If you can avoid it, do, or apply at least some fuel stabilizer.
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
Offline Steve F
« Reply #2 on: November 19, 2019, 07:14:33 AM »
Ethanol in gas is a political sham, and is lining the pockets of those in Washington that support it.  You get less mileage and less performance with this corn by-product polluting our engines.
Offline bert96
  • past ride
« Reply #3 on: November 19, 2019, 07:19:13 AM »
Thats what i thought...
Its not a good news,to say at least.
Bert
Offline Tim2005
« Reply #4 on: November 19, 2019, 11:37:15 AM »
You will need to check if 15% ethanol is ok for your fuel lines, o-rings etc. Currently we have 5% ethanol here and some brands of fuel lines go hard and develop leak problems.
Offline bert96
  • past ride
« Reply #5 on: November 19, 2019, 12:13:29 PM »
Dammm!!!
Just  F***** problems!!!
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #6 on: November 19, 2019, 04:33:35 PM »
We have had "up to 15% ethanol" in Ohio for quite some time. There are issues, not only with old bikes. I had a plastic fuel elbow in the line from the tank to the injectors in my 2012 BMW K1600GT come apart. The in-tank fuel gauges/senders on some BMWs fail and modern in-tank fuel pumps have seal issues. I use Startron Enzyme Fuel Treatment on a regular base and also use ethanol-free gas whenever I can.
1973 CB350F -sold
1974 CB350F -218 orig miles, sold
1976 CB750K - in restoration
Other Hondas:
3 x CBX
CB1100R
GB500
Plus Kawasakis, BMws & Ducatis
Offline bert96
  • past ride
« Reply #7 on: November 19, 2019, 04:45:49 PM »
I don't understand why they want to use ethanol(corn)
The earth barely feed all the peoples now,i don't see the logical point to use food for another use.
« Reply #8 on: November 19, 2019, 05:03:18 PM »
and then there is that corn isn't that great for food either.  The way it is used in U.S. processed foods is nigh on mass poisoning and has destroyed the health of millions of people.
« Reply #9 on: November 19, 2019, 05:34:51 PM »
 My older Dodge mini-van can use the pure E85 stuff but still afraid to put any in as I might kill it for good. I bought a gallon once to experiment with and had some outdoors in a cat food can. I left it for awhile and when I came back it had a lot of dead flies floating in it. Must be some be some sweet stuff but gave them the kiss of death.
  A friend of mine uses it in his Ford truck off and on and says its good for it and cleans things out.
« Last Edit: November 19, 2019, 05:36:42 PM by ekpent »
Offline bert96
  • past ride
« Reply #10 on: November 19, 2019, 06:40:04 PM »
 I heard that there is more water in ethanol than the regular gas!?!
 I don't know about you guys but here in winter,we can reach -25-30 C easy. Guess what will happen....
Offline Steve F
« Reply #11 on: November 20, 2019, 07:18:53 AM »
See reply #2
Offline Steve F
« Reply #12 on: November 20, 2019, 07:20:18 AM »
The land that's used to grow corn could (and should) be used to grow other crops.
Offline Nicklopic
  • New York
« Reply #13 on: November 20, 2019, 02:41:46 PM »
I think people play up the problems with ethanol just a little, is it ideal in every situation? Definitely not. It attracts moisture more than standard gasoline and doesn't keep as long. However, its pretty wide spread in the US as far as I've seen to have ethanol contents up to 15%. Ive caught nonethanol fuel at a station maybe 1 time living in NY.
Its not the end of the world. Just be mindful when you park it for months at a time if anything.
80' CB650
Build Thread
Offline rb550four
« Reply #14 on: November 20, 2019, 04:35:57 PM »
EVERYONE HATES THIS FUEL ADDITIVE
Offline bert96
  • past ride
« Reply #15 on: November 20, 2019, 04:54:43 PM »
 ;D
« Reply #16 on: December 20, 2019, 06:28:53 PM »
Ethanol strips lubrication from the top rings and valve guides/stems. It is a solvent.
In the 750, with its steep valve angles, it wears out the valve guides quickly, in about 8000 miles in my experience, unless one is vigilant about adding oil to every tank of fuel. I managed to get 25000 miles from my 750 after ethanol 10% appeared here, by adding 1-2 ounces of oil to every tank of gas. Still, it wore the intake guides a lot. Installing bronze guides, as are found in cars engines made for the crap, works well. The 500/550 and 350F/400F have much shallower valve angles and don't suffer as badly from it.
BUT...it turns the fuel lines to hard plastic in about 12 months' time. Even the so-called 'ethanol-rated' lines (with the red stripe on them to symbolize "ethanol tolerant") lose all of their flexibility in about 18 months. There is some polyethylene fuel line out there, but in 1/4" size (a bit too big) that can help, if you can find some hose clips to seal up their weeping at joints.
If you rebuild, use only chrome top rings, too. This will help it last longer. Our friends at CruzinImage have lately (last 8 years or so) started doing this, too.
Offline dusterdude
« Reply #17 on: December 21, 2019, 03:49:58 AM »
I would think some mmo mixed with the gas would help
Sent from my LG-US601 using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline bert96
  • past ride
« Reply #18 on: December 21, 2019, 03:56:36 AM »
Excuse my question but what is mmo?
Offline dusterdude
« Reply #19 on: December 21, 2019, 03:58:24 AM »
Marvel mystery oil
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline bert96
  • past ride
« Reply #20 on: December 21, 2019, 04:20:31 AM »
Thanks for the answer!
Offline dusterdude
« Reply #21 on: December 21, 2019, 04:23:16 AM »
You're welcome
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #22 on: December 21, 2019, 05:51:41 PM »
Sean is right
« Reply #23 on: December 21, 2019, 07:17:05 PM »
we still have non eth fuel here,id add a little two stroke oil if anything over mmo?its designed to be burnt and leave little ash.
Offline BenelliSEI
  • 1969 cb750
« Reply #24 on: December 22, 2019, 01:09:45 AM »
Bert...... lots of “Super” pumps here in Ontario still have zero ethanol. Not true in Quebec?
