Author Topic: Mystery Oil Droplets After 30min Ride?  (Read 2338 times)
Offline SalNYC750
  • I’m a big fat Italian Guy so sue me!!!!
« on: November 22, 2019, 09:49:56 AM »
My 72.....she don’t leave any spots on the garage floor but after a 30 min ride see picture! What gives!
im not the sharpest tool in the basket so big NYC thank youz guys to all who help this lunk!!!!
74&72cb750 in various states of disrepairs!
Re: Mystery Oil Droplets After 30min Ride?
« Reply #1 on: November 22, 2019, 10:44:32 AM »
Chain oiler is not closed?
All covers can leak, oil filter cover ab
Nd neutral switch included.
YOU have to look from where the oil cone from.
« Last Edit: November 22, 2019, 10:40:39 PM by PeWe »
« Reply #2 on: November 22, 2019, 12:56:18 PM »
 Check valve cover breather hose  for a crack..
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #3 on: November 22, 2019, 01:18:22 PM »
Egggzackly
Offline SalNYC750
« Reply #4 on: November 22, 2019, 01:42:58 PM »
Thanks fellas ;D some additional pictures the circle shows where some of the oil pools up a bit.
My fins seem to look a lil’suspect but I dunno... whatdathink???
Offline SalNYC750
« Reply #5 on: November 22, 2019, 01:49:11 PM »
Ohhhhh and the when sitting on the bike the left side cover has I nice smatterin’ of what looks like oil?
Minimal on right side! Ughhhhh :o
« Reply #6 on: November 22, 2019, 06:25:02 PM »
This one might be an overactive chain oiler, or just chain lube a little overdone? You can adjust the screw in the center of the countersprocket inward by a turn or so to see if it settles that down a little bit.
The valve cover: check to make sure the cover's screws are tight on that left side. If the gasket is leaking (it's 50 years old now!) it may need replacing. Not simple, though: engine has to come out for that one. :(
Offline SalNYC750
« Reply #7 on: November 23, 2019, 01:18:51 AM »
Big thank ya to everyones!!!!! I’m gonna check all the suggestions and get back at ya!
So Hondaman... do I gotta pull the engine if it’s the valve gasket?  :P This fella seems to have a nifty fix:
« Reply #8 on: November 23, 2019, 04:41:46 AM »
That will be easier with a quality gasket as Honda original. Cheaper aftermarket has bad fitment, especially front close to cam chain between plug 2-3. Gasket has wrong shape colliding with cam holder near plug 2. Also bad hole fitment in general, like the flat area above chain tensioner adjuster.
Honda original hurts more when order, a good friend when assemble.
All side cover gaskets use Honda that fits, cheap will miss 1-2 holes, possible to ruin the gasket when assemble the M6 screws that crash the gasket when tighten. Good gasket can be reused again if lifting cover.
Offline SalNYC750
« Reply #9 on: November 23, 2019, 04:57:09 AM »
link to OEM? 8) 8) 8)
Offline SalNYC750
« Reply #10 on: November 23, 2019, 05:17:53 AM »
ok definitely oily wetness between cylinder head and manifold!!! Time to yank the engine??? :-*
Offline SalNYC750
« Reply #11 on: November 23, 2019, 05:44:26 AM »
yep.... Sumofabitc... :o is that a compromised gasket??? Oy vay!!!
Offline maxheadflow
« Reply #12 on: November 23, 2019, 07:26:25 AM »
It's hard to say if the headgasket is actually leaking. On my 78K, I had oil pouring out between the 2-3 plugs and running down the front of the cylinder.  For me it was the rubber pucks under the cam towers that needed replace.   I did have to pull the motor to replace the pucks and cleaned the motor.   I did not replace the head gasket tho.   First couple of rides, I still had some oil creeping out but clean it when I see it and it is becoming less and less.  In my case I didn't want to pull the top end as I needed to resist taking it apart and modifying it.  :D
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #13 on: November 23, 2019, 08:21:46 AM »
give that a try first.  buy two gaskets.  let us know how it goes.
cb750 k6 - ugly
Offline SalNYC750
« Reply #14 on: November 23, 2019, 09:52:43 AM »
Tank off inspected with a good vantage point ....Hose is good from breather,,,, no signs of cracking off oil tank and return hoses all look great.
Thinking it’s high speed = greater oil pressure and oil finding the weakest gasket to spray from?
per the last picture above.... :o
« Reply #15 on: November 23, 2019, 10:09:33 AM »
It should be easier to tighten the head. Engine out if no frame kit.
Cover off,  rockers, cam, cam holders. Now possible to tighten head nuts.
Back in the days only tighten once. Not tighten, wait 24 hours and  tighten again.
Big difference and less leaks.
Good reason to install Frank's weldless frame kit! :)
« Last Edit: November 23, 2019, 10:14:45 AM by PeWe »
« Reply #16 on: November 23, 2019, 03:34:19 PM »
THAT , is what we call a really dry one..
 When they really leak it will get on your clothes and leak on the ground. 90 percent of them are like yours or worse.
 I would just not worry about it..
« Reply #17 on: November 23, 2019, 07:46:04 PM »
+1 to 754. Not worth fixing for now.......
« Reply #18 on: November 23, 2019, 08:12:46 PM »
 If you are running synthetic, it may weep more than if you run dino oil..
Offline SalNYC750
« Reply #19 on: November 24, 2019, 02:42:57 AM »
alrighty!!! I will live and let live with this minor inconvenience! Only old timey 10-40 for this lunk!
A drip here a drip there,,, here a drip there a drip ——-everywhere a drip-drip!  :D
Ol’ McSalle had a 750 e-I-e-I ohhhhhh!!!
Thanks for all the the advice!!!! As long as I’m not hurtin anything!
I do burn a 1/4 qt bout every 500 miles, and the oil goes black pretty quick,,,, but I do ride her hard and in NYC traffic conditions!!! Put on about 10,000 miles in 18 months with trips upstate and to Jersey to see my cousins in ‘waste management’....  8)
« Last Edit: November 24, 2019, 02:44:51 AM by SalNYC750 »
« Reply #20 on: November 24, 2019, 03:23:25 AM »
10-40 for a CB750?
Too thin, 20/15/10W-50 is recommended. Unless you will ride the bike in a cold climate seldom over 15C.
Offline 1976cb750f836
  • 76 cb750f, 836, 78 wheels
« Reply #21 on: November 24, 2019, 06:39:50 AM »
I'd add a frame kit (allows engine work without pulling engine), pull the top end during winter, and have it ready for spring?
Offline SalNYC750
« Reply #22 on: November 24, 2019, 01:16:26 PM »
frame kit?!!! I can’t use a welder!  :o :o :(
my catch can off the valve coverrr breather hose produced some fluid that smell more like gas then oil?
what’s up wit that????  ;D ;D
« Reply #23 on: November 25, 2019, 06:11:44 AM »
My frame kit(home made), used NO welder, just a hacksaw!
Offline Maraakate
« Reply #24 on: November 27, 2019, 06:35:50 PM »
Agreed, seems like all my vintage hondas get a little weepy around the head gasket.  Just watch your oil level and you will learn how much you may need to top it off.  Unless it's extreme I would just let it be.
1977 CB550K
1979 CM400A
