Author Topic: Cb650 Cafe racer  (Read 19296 times)
Offline Jimcg
Re: Cb650 Cafe racer
« Reply #100 on: November 25, 2021, 02:48:20 AM »
The wheel looks good, can't wait to see it on the bike!
Interesting about the fuel project. Will be following that too with great interest.
/Jim
1982 CB650Z RC03 owner in Eskilstuna, Sweden
About my bike:
http://forums.sohc4.net/index.php/topic,183848.0.html
Just the pictures and no text:
https://www.flickr.com/photos/189154615@N04/?
« Reply #101 on: November 25, 2021, 03:24:45 AM »
Very nice work on the wheel. Ambitious and interesting that you are doing FI on the bike…look forward to seeing what you can share on that journey!
« Reply #102 on: November 25, 2021, 10:49:22 AM »
What size are the venturi on those throttle bodies ?
Offline dkihlgren
« Reply #103 on: November 28, 2021, 10:47:26 PM »
36mm
Skickat från min iPhone med Tapatalk
Offline dkihlgren
« Reply #104 on: December 14, 2021, 11:17:12 PM »
Slow progress. I bought an empty hub and all the little parts are priced like they are made of gold. So I make all the collars etc.
Offline Jimcg
« Reply #105 on: December 15, 2021, 11:12:39 AM »
It looks very promising! Can't wait to see the result with tires and everything on the bike. Slow progress sucks for curious forum members... 😄
/Jim
About my bike:
Offline dkihlgren
« Reply #106 on: December 18, 2021, 12:17:40 AM »
Started making a trigger wheel. Will be a 24 tooth wheel. Next is to mark and drill holes for small magnets. But I need to get the hall sensor so I know where to put the magnets.
Offline Godffery
  • Godffery's Garage
« Reply #107 on: December 18, 2021, 04:56:10 AM »
Rear wheel looks great in there!
What's your plans for the front? Swapping forks and brakes out or doing some custom mods to adapt a hub?
Offline dkihlgren
« Reply #108 on: December 18, 2021, 07:40:10 AM »
I have a cb750 hub from a -78 (I think). I’ll keep my forks. Installed gold valves recently.
I did some measurments and it’s a 6x80mm bolt circle. After som searching I found that fzr600 rotors should fit. The dream would be Ducati 1000 Sport classic Brembo calipers. Very thin but expensive. Probably go with cbr600 calipers with some adapter plates.
Offline Godffery
  • Godffery's Garage
« Reply #109 on: December 18, 2021, 08:12:32 AM »
 Groovy!
If the CBR rotors give you issues, I can hook you up with Drilled & Thinned CB rotors.
Offline dkihlgren
« Reply #110 on: December 20, 2021, 10:24:18 PM »
Groovy!
That is good to know
Offline dkihlgren
« Reply #111 on: February 04, 2022, 07:30:44 AM »
Have done a prototype for a new trigger cover. Not shure if I should try and cast in aluminium or make one in carbon. Will have to make a new version where sensor is rotated 180 degrees.
Offline Godffery
  • Godffery's Garage
« Reply #112 on: February 04, 2022, 12:11:26 PM »
I take it you are making that because the new trigger wheel requires more clearance then the stock cover provides?
Given the choice between aluminum or carbon, I'm thinking the aluminum could likely handle more abuse in the event of a tip-over.
Offline dkihlgren
« Reply #113 on: March 02, 2022, 11:09:33 PM »
Rear wheel finished. It will look nice on the road.
Offline Godffery
  • Godffery's Garage
« Reply #114 on: March 03, 2022, 06:37:53 AM »
 Now that's look'n Right Proper!
Offline Jimcg
« Reply #115 on: March 04, 2022, 10:32:22 PM »
Looks perfect! Very excited to see how it will transform the look of the bike.
/Jim
About my bike:
Offline dkihlgren
« Reply #116 on: March 13, 2022, 11:10:29 AM »
So hard to work during winter. Space is very limited.. Anyway! Have to make some new spacers to center the 750 hub. 6,5mm off center.
Offline dkihlgren
« Reply #117 on: March 20, 2022, 11:42:05 PM »
I think I’ll only do preparation for my efi conversion this spring/summer. Really want to do some riding. New wheels will be my priority next month.
Offline dkihlgren
« Reply #118 on: April 21, 2022, 12:57:52 PM »
Some progress today
Offline Jimcg
« Reply #119 on: April 23, 2022, 11:19:05 PM »
Almost back on wheels again, it's looking very nice!
/Jim
About my bike:
Offline Jimcg
« Reply #120 on: July 30, 2022, 04:53:36 AM »
Hope you are having a good summer!
How are things moving along for you, with the spoked wheels? Can't wait to see a picture when it's back on wheels again. I'm very curious to see how it affects overall visual impression.
/Jim
About my bike:
