Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
What size are the venturi on those throttle bodies ?
Rear wheel looks great in there! What's your plans for the front? Swapping forks and brakes out or doing some custom mods to adapt a hub?
Groovy! If the CBR rotors give you issues, I can hook you up with Drilled & Thinned CB rotors.
Have done a prototype for a new trigger cover. Not shure if I should try and cast in aluminium or make one in carbon. Will have to make a new version where sensor is rotated 180 degrees.Skickat från min iPhone med Tapatalk
Rear wheel finished. It will look nice on the road.
