Author Topic: Round top carbs - How to remove slides?  (Read 2281 times)
Offline jakec
« on: August 06, 2020, 09:57:54 PM »
Is it possible to remove the slides without removing the carbs from the rack?
1970 CB750 K0
1977 CB750 Chop
1984 Big Twin Evo Chop
1997 XR650L
Online PeWe
Re: Round top carbs - How to remove slides?
« Reply #1 on: August 07, 2020, 02:52:46 AM »
I tried on my CB750 K6 carbs. Had to remove carbs, loosen them from rack..
« Reply #2 on: August 07, 2020, 09:25:43 AM »
If you think pulling carbs off rack is a hassle. . Wait till you try  removing the rod from the forks without destroying its function and being able to reuse it..
Offline jakec
« Reply #3 on: August 07, 2020, 09:40:36 AM »
You mean the forks that lift the slides?
I didn't want to de-rack the carbs because they don't leak right now, so I don't want to disturb the fuel tubes.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #4 on: August 07, 2020, 10:14:56 AM »
What are you trying to do ?
Offline jakec
« Reply #5 on: August 07, 2020, 10:35:01 AM »
I'm going to ultrasonic clean the carbs and I wanted to replace the dust seals at the top of the slides. My cleaner can fit all 4 carbs together.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #6 on: August 07, 2020, 12:52:23 PM »
 If I was going to do a good job of cleaning the carbs even if I had a big sonic cleaner I would still take them apart like pulling the slides etc..Be a good time to replace those 45+ year old o-rings in the fuel tubes anyways  along with new orings in the float bowl drain screws too if you can get them out. Just did that recently on a pair of carbs and that rubber looked pretty sad.
Offline jakec
« Reply #7 on: August 07, 2020, 01:49:38 PM »
I've read on here one time, if those T joints and fuel tubes between the carbs don't leak.. don't mess with them. But yeah, if it's the only way to get the slides out then I guess I have no choice.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #8 on: August 07, 2020, 04:21:39 PM »
 Well you will be messing with them by just putting fuel line on or off, soaking them or other things. I have noticed that on the two orings on each end of the fuel tee's one can be worse then the other.Possibly the one that stays the driest . The other main reason why I would want to get them apart is to be able to blow all the water and or cleaners out of them well after they have had their soak. The worst part of removing and splitting the rack is messing with the little cotter pins on the choke linkage. I only remove two and the middle linkage bar and try not to turn the ones on carb 1 and 4 so it goes back just the way it came off quickly and easily without having to readjust. Love doing the roundtops because they are so easy.
Offline jakec
« Reply #9 on: August 07, 2020, 07:02:55 PM »
Yes, I did notice that when I was contemplating removing them from the rack, it is WAY less complicated than with PD carbs.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline grcamna2
« Reply #10 on: August 07, 2020, 07:24:50 PM »
subscribed
75' CB400F/'bunch o' parts'
Online PeWe
« Reply #11 on: August 07, 2020, 10:41:07 PM »
+1, Replace fuel T o-rings when carbs are off. Drain screw o-rings can be done if leaking. Float bowls are easy to remove.
I removed drain screws on 2 extra bowls I used for clear tube check. Bowl screw head in a vice, turned bowl.
Bowl rubber gasket is hard as bakelite, right?
Offline jakec
« Reply #12 on: August 08, 2020, 10:14:59 AM »
Bowl gaskets were hard, but drain screws came off easy using my giant T shaped screwdriver.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #13 on: August 08, 2020, 12:07:48 PM »
 I will say I have never had to replace a stock bowl gasket on any roundtop carbs I have worked on and that's a lot. I never pick them out either I just leave them unmolested in place even during a carb dunk. The only one I ever replaced was some cheap rubber one that was all swelled up and bad.
Offline jakec
« Reply #14 on: August 09, 2020, 08:57:06 AM »
FOr your viewing pleasure. Sorry for bad lighting. Has anyone polished the chrome slides before?
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline jakec
« Reply #15 on: August 09, 2020, 09:04:14 AM »
For future reference the 7.8x1.9 O rings (8) can be got here:
https://www.theoringstore.com/store/index.php?main_page=product_info&products_id=1864
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #16 on: August 09, 2020, 09:37:10 AM »
I just clean the slides with lacquer thinner, never felt the need to polish them.
Offline itsahonda4
    • www.wfomodels.com
« Reply #17 on: August 09, 2020, 06:58:59 PM »
you shouldnt polish the slides, just clean them.....
Online PeWe
« Reply #18 on: August 10, 2020, 12:58:54 AM »
I had to file mine lower inner edges after too hard bench sync in the 80's.
Stock spring is very hard, not good letting it snap down when drill is in.
« Reply #19 on: August 10, 2020, 06:21:47 AM »
Dont let the slides clack down on the rod.. no reason
 I polish  the rod or bar , then roll it as I adjust.. . I use a brass rod, no worry about scratching. ..
Offline jakec
« Reply #20 on: August 10, 2020, 11:17:25 AM »
Should I replace the intake boots? They were pretty hard. I didn't use any heat but I used two cam straps to eject the carbs.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline Remcod
« Reply #21 on: August 10, 2020, 11:30:32 AM »
Between carbs and airfilter? Recommendable.
Offline jakec
« Reply #22 on: August 10, 2020, 12:32:05 PM »
I'm talking about the ones to the engine. The airbox ones are soft.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #23 on: August 10, 2020, 06:28:18 PM »
 The stock ones(manifolds) if in good shape are probably better quality then repops and a heat gun and a little grease really makes a difference. You don't need to do this but I ditch the old stock clamps usually if not doing 100% resto. Between the old rubber shrinking slightly and the original low quality clamps stretching a little and bottoming out on their tabs to me makes for a bad combo. I don't like being able to spin them with my hand when the little clamp is tightened all the way. I reuse and like the airbox clamps.
« Last Edit: August 10, 2020, 06:33:33 PM by ekpent »
« Reply #24 on: August 10, 2020, 07:19:27 PM »
Eric, could you post a link to the clamps you use that work good?
