Author Topic: Small slide crash on my left, alternator cover possibly cracked  (Read 1870 times)
Offline Xander^
« on: October 19, 2020, 02:17:17 PM »
Hey guys, not One of my best days, riding in the city with streetcar tracks I had my front wheel slip into a turning channel of the tracks and slide to a fall to my left side, bike fell on the left handle bar and alternator side case. Thankfully i was going slow and didn't get hurt, and no other parts were damaged.
After lifting the bike back up,  I immediately noticed drips of oil falling from the bottom of the Alternator cover, i figured the slide forced the gasket seal open and maybe a screw snapped, however on the face of the side cover towards the bottom of the HONDA circle, I believe the slide cracked the casing. Small line fracture maybe? Small drip of oil was scene today around that cracked line. What do i do now? Lol..
1977 CB750K cafe
Re: Small slide crash on my left, alternator cover possibly cracked
« Reply #1 on: October 19, 2020, 02:41:38 PM »
Lean it tyd othef way wipe with cleaner, apply sealer.. keep riding it .
 I think mine got a small crack and I did not hit anything.. strange..
« Reply #2 on: October 19, 2020, 03:17:51 PM »
Yeah, that is all it takes to crack them.  A, nice clean replacement can be slightly hard to find and/or expensive.
Offline Xander^
« Reply #3 on: October 19, 2020, 03:38:58 PM »
Can you recommend the best sealer plz. Im going to drain the oil and replace the gasket over the winter anyways so sealer is a great idea
1977 CB750K cafe
« Reply #4 on: October 19, 2020, 05:13:44 PM »
I don't know what the latest sealers are that will seal porous cast aluminum,but they are out there.You might consider sealing it on the inside so it won't show.I don't think that cover will ever be pretty again but it can be sanded and polished to remove some of the roadrash.. a better option is another cover.
« Reply #5 on: October 19, 2020, 07:58:05 PM »
JB weld
« Reply #6 on: October 19, 2020, 08:21:38 PM »
JB weld
I successfully sealed a porous casting area on the 1985 VF500F I had on the oil gallery area,outside of the left top crankcase back behind the countershaft sprocket area.The area needed to be very roughed-up and prepped/sprayed-off with Brakleen numerous times to wash the oil out and then sprayed-dry with compressed air.That patch did hold nicely,I used a heat lamp in my previous shop to cure it in the Winter.
« Last Edit: October 20, 2020, 03:22:32 AM by grcamna2 »
Offline flatlander
« Reply #7 on: October 19, 2020, 11:25:13 PM »
is there any oil behind that cover on a 750? not on my 550.
« Reply #8 on: October 19, 2020, 11:54:36 PM »
Yes the 750 is "wet"
« Reply #9 on: October 20, 2020, 06:07:34 AM »
I’m 1 hour N.E. Of Mosport, and probably have a spare one if you end up needing one.
Offline Xander^
« Reply #10 on: October 20, 2020, 08:28:13 AM »
JB weld
Interesting, going to take the cover off and do it properly this winter. Clean it well and try to JB weld. If not i might have to go see BenelliSEI lol
1977 CB750K cafe
« Reply #11 on: October 20, 2020, 08:52:38 AM »
Exactly what I did in the 80's.
I used a JB Weld like 2k product. Chemical metal, quick hardening.
I let bike lean to a wall, cleaned with acetone and applied the 2k putty.
Waited 15 minutes and continue to ride. It held up really well.
Offline spotty
« Reply #12 on: October 20, 2020, 04:24:29 PM »
did the same to my first 750, rolled off the side stand and punched a hole right through
took it off, gave it a good clean inside and out and used two part epoxy glue ( araldite in australia) , used a bit of scotch tape to keep the glue inside while it was setting and it came out relatively smooth on the outside when it set
probably no different in effect than the much vaunted JB weld but a whole sh1tload cheaper
 it was still there and not leaking when i sold it to terry about 10 years later
i blame Terry
« Reply #13 on: October 20, 2020, 05:16:23 PM »
JB weld
A really Thorough cleaning/prep is the deal maker.  :)
When a welder does tig welding on a part like that,they will clean every last bit of oil out of those aluminum pores that they can,then put it into an industrial oven so the open alloy pores release as much oil as can be,it takes a few applications like that:take it out of the oven and wash it oil free with something like Brakleen or another oil free solvent or hot water and Dawn,etc.The oven brings out more oil that's trapped inside the aluminum every time the part is set in there for a while, so there is a clean weld(in your case a tight bond between the JBWeld and the cast aluminum.
