Author Topic: Wheel Hub Retainers  (Read 706 times)
Offline mblutcher
Wheel Hub Retainers
« on: December 06, 2020, 06:29:27 PM »
Hi Everyone,
Looking for opinions on using a little blue Loctite on the front and rear wheel hub retainers on a CB750 instead of punching to lock retainers in. What do you think?
Offline robvangulik
  • Honda Fourever
Re: Wheel Hub Retainers
« Reply #1 on: December 07, 2020, 02:46:55 AM »
Why?
Offline low-side
« Reply #2 on: December 07, 2020, 03:00:31 AM »
I personally wouldn't do that.  It wouldn't be as reliable as punches and would be harder to remove than drilling punches is.
« Reply #3 on: December 07, 2020, 08:35:57 AM »
I have used that.
I tightened the retainer and put just a little in each hole where earlier drilled. I used Loctite 222 which is weak.
Another rear hub nothing, copper paste only to let it move easier ;D
Threads had issues after the removal of old retainer since I punched rather hard in the beginning of the 80s with no thoughts about a remote future where I have to replace bearings again. Maybe parked for 20 years helped. Quality SKF bearings
That bearing is squeezed into it place when wheel is tightened.
« Last Edit: December 07, 2020, 08:38:17 AM by PeWe »
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: December 07, 2020, 06:39:32 PM »
+1 to PeWe. I use a drop of blue and has never come loose.
« Last Edit: December 08, 2020, 06:26:16 AM by BenelliSEI »
Offline mblutcher
« Reply #5 on: December 07, 2020, 10:06:57 PM »
Thanks for the input!
