Author Topic: Reusing float bowl gaskets  (Read 2072 times)
Offline The Gurg
« on: February 11, 2021, 08:11:29 AM »
Pulling apart my carburetors because I’m wrapping up a rebuild and the carbs are already off the bike. Carbs ran great before. Thought I might dip the jets in carb cleaner and run a wire though them. Blowing out passageways with  air. The rebuilt engine is freshly painted. Don’t want gas leaking on the new paint from the carbs above.
1.) How likely are leaks from the float bowls if I reuse the float bowl gaskets?
2.) My float height is sitting way too low. I don’t even need to measure because it’s so obviously low. Seems like adjusting the tab wouldn’t be enough. Anyone had this issue?
My first rebuild. Honda CB750K5
« Last Edit: February 11, 2021, 08:32:08 AM by The Gurg »
Re: Reusing float bowl gaskets
« Reply #1 on: February 11, 2021, 08:41:01 AM »
 Just me but I never change or even remove/disturb the float bowl gaskets on 750 round top carbs when I clean and dunk them. If they have been changed to junk rubber aftermarket sometime in their life your results may vary.
  Make sure your overflow tubes are hooked up and a good rag or towel is under the bank the first time you fill them up to save fresh paint if there is a problem.
« Last Edit: February 11, 2021, 08:42:36 AM by ekpent »
Offline The Gurg
« Reply #2 on: February 11, 2021, 08:58:51 AM »
I pulled the gaskets so I could scrub with a brass brush a little. Cleaned out where the gasket sits as well. There was a very very small amount of gasket material in the corners etc. I rebuilt the carbs about 8 years ago and didn’t use oem gaskets.
Have lines run from the floats to the floor. So good there!
Offline The Gurg
« Reply #3 on: February 11, 2021, 09:44:09 AM »
Photos of the gaskets in question.
« Reply #4 on: February 11, 2021, 10:03:32 AM »
Eric, you have lots of experience of carb gaskets!
If you say they work when old, that's the truth.
I have cheap gasket from Cruzinimage. No leak yet after 2 years. But I saved the old hard Honda gaskets.
I have another carb repair set with gaskets and all jets I got a week ago.
I'll use the gaskets only, bowl and throttle top to an extra set of CB750 K6 carbs.
Repair set was very cheap from Taiwan. Seller ensure viton, not swelling. Lets see if that will work ;)
That carb setup will use all stock jets except for main jet, probably another size of Keihin jet. The old gaskets will be saved in my Keihin parts bag.
Offline The Gurg
« Reply #5 on: February 11, 2021, 11:29:11 AM »
Eric-
Does these being aftermarket change anything for you? Or you think their fine?
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #6 on: February 11, 2021, 02:18:18 PM »
Eric-
Not Eric but I found some aftermarket carb bowl gaskets to be skimpy compared to stock.
Sent from my moto g(7) using Tapatalk
cb750 k6 - ugly
Offline The Gurg
« Reply #7 on: February 12, 2021, 04:27:01 AM »
Gasket set (16010-300-305) should be all I need for a rebuild, if I reuse the jets, right?
« Reply #8 on: February 12, 2021, 05:03:21 AM »
If youare doing all the carbs 4 ofthem!!
Offline Old Scrambler
« Reply #9 on: February 12, 2021, 09:41:53 AM »
OEM gaskets were borrowed from the 305 twin models.........I often soak the gaskets in a 50-50 blend of Marvels Mystery Oil & Dawn Detergent.........sometimes I add Wintergreen Oil......
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Online seanbarney41
« Reply #10 on: February 12, 2021, 12:48:52 PM »
I am another guy who does not mess with the oem float bowl gaskets...if they are stuck in there?...all the better.
« Reply #11 on: February 13, 2021, 02:53:21 PM »
Ah, that minty smell! :)
The old gaskets in those carbs will usually work unless they are showing signs of cracks: then they will weep and be wet around the corners, usually.
It sounds like someone changed the floats valves at some point? The modern ones have much stiffer springs and are often taller by about 1mm. This makes the float level quite low if the float tangs are not readjusted to them. Float height in the K5 carbs is 25-26mm, and the cast lines across their floats will be dead parallel with the gasket surface when you set them. ;)
Offline The Gurg
« Reply #12 on: February 26, 2021, 06:22:38 AM »
I think I’m measuring the floats wrong. I’ve just let them hang, while holding the carb oriented upright. Instead, you hold the carb at a 45° and let the the float valve just graze the float, while measuring right?
« Reply #14 on: February 26, 2021, 07:51:33 AM »
Yes on an angle is the correct way.
Offline The Gurg
« Reply #15 on: February 28, 2021, 06:49:35 AM »
The JIS head on this choke throw from the fourth carb fell off when I took off the nut. Took the top turn of threads with it on one side. Can’t find just the throw by itself on eBay. Thinking I’ll put some loctite on it and use it. Thoughts?
Photo with carb in the picture is before the nut was removed.
« Last Edit: February 28, 2021, 06:52:33 AM by The Gurg »
« Reply #16 on: February 28, 2021, 06:55:32 AM »
 I know this is no help but I have never felt the need to take any of that stuff apart on the carbs or anything thing on the rack that holds them. Don't make more work then needed unless you have to for some other plan.
Offline The Gurg
« Reply #17 on: February 28, 2021, 07:46:15 AM »
Yeah, I should have left it. Good advice Ekpent!
Think it’s fine to put it back in?
Online BenelliSEI
« Reply #18 on: February 28, 2021, 08:15:49 AM »
The set I just did was the same. I just left the lock washer out (the nut went deeper and found some threads) and put a drop of blue loctite. Visible, if you look closely. I’ve done it before, works fine. Next time I visit my favorite aircraft hardware store, I’m going to see if they have a nylock nut that small!
P.S. I reuse floatbowl gaskets all the time, if they still have some flex. The ones in these +50 year carbs were rock hard and got changed. They need some “give” to work.....
« Last Edit: February 28, 2021, 08:18:34 AM by BenelliSEI »
Offline The Gurg
« Reply #19 on: February 28, 2021, 08:44:33 AM »
Great idea BenelliSEI, really not missing any thread, so leaving out the lock washer should work perfect.
Have a specialty bolt warehouse in the midtown area, I’ll see if they have a nylock nut that size, have some other hardware to pickup anyway. You don’t use loctite with nylock or can you?
Offline Alan F.
« Reply #20 on: February 28, 2021, 09:49:44 AM »
Have a specialty bolt warehouse....You don’t use loctite with nylock or can you?
I've never heard of a thread locker for nylon screws but it probably exists. Maybe your Specialty bolt place knows more?
Online seanbarney41
« Reply #21 on: February 28, 2021, 10:00:04 AM »
It's kinda silly but does work...nylock is considered a thread locking device but it is really only meant to be re-used a number of times.  Every time it is removed and replaced it loses some of its thread lockability.  Locktite or other liquid thread lockers accelerates the deterioration of the nylon...but then you have threadlock from the liquid...so your decision.  Also, that cross in the end is not meant for a JIS or any other driver.  It is staked, intentional mutilation of the threads to prevent removal of the nut...honda did not want the casual maintainer to remove it!
« Reply #22 on: February 28, 2021, 10:46:03 AM »
You can use tread tape as a locker or hylomar
Online BenelliSEI
« Reply #23 on: February 28, 2021, 11:47:06 AM »
I would not use loctite if I use a nylock nut.
Offline The Gurg
« Reply #24 on: February 28, 2021, 03:23:23 PM »
Seanbarney-
Was there a way to remove the nut without harming the staking?
Appreciate the insight BenelliSEI and BryanJ!
