Author Topic: Wheels for 78  (Read 1302 times)
Offline Beau’s Bar and Garage
Wheels for 78
« on: March 16, 2021, 12:17:28 PM »
I want to go from Spokes to Mags. Any cb750 years fit ?  Is there anything to know before buying some eBay used wheels?  I hate spokes
Offline beemerbum
Re: Wheels for 78
« Reply #1 on: March 16, 2021, 01:04:14 PM »
Remember 77 and 78 used 17 inch wheels in the back. You are the first antispokite I have read here
Offline Ryan66
Re: Wheels for 78
« Reply #2 on: March 16, 2021, 01:12:50 PM »
I agree lol. One of the maindraws to the Cb's were the spoked wheels for me
1976 CB550k (cafe project)
Re: Wheels for 78
« Reply #3 on: March 16, 2021, 01:56:52 PM »
Yeah, me too!  I dont know if i hate spokes so much as i hate cleaning them.  And chromed steel rim with poorly plated spokes just turned into a dusty, rusty, not round, heavy mess.  One area where Honda really cheaped out, in my opinion.
 Lots of wheel swaps doable.  Some of them are gonna require real savvy when it comes to what forks, swingarms, and wheel spacers get you what you need.  Or be on the lookout for some Lester or other aftetmarket designed to bolt right on.
« Last Edit: March 16, 2021, 06:08:53 PM by seanbarney41 »
Offline onepieceatatime
Re: Wheels for 78
« Reply #4 on: March 16, 2021, 05:52:36 PM »
One of my K7 projects had reverse Comstars on it when I bought it.
Unfortunately, I have no idea what Honda they were from, but I traded them to Pielz for the spoke wheels on his K7.
Here you can see them on his bike.
http://forums.sohc4.net/index.php/topic,45183.msg2125861.html#msg2125861
It was a direct swap, same size wheels, spacers, and everything.
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Re: Wheels for 78
« Reply #5 on: March 16, 2021, 06:47:29 PM »
Spokes break and require tubes. No thanks.  Mag all day.  Plus mags are waaaay better looking.
Re: Wheels for 78
« Reply #6 on: March 16, 2021, 07:00:36 PM »
Unfortunately, 75 percent or so of the mags that can be fit to your bike also require inner tubes.  I love the look of cast alloy and mag wheels, but also nothing better than some wide aluminum rims with heavy duty spokes...super strong, super light, build 'em right and spokes ain't gonna break.
Kids with their stock spoked steel wheels where they slather everything in black paint/powder?...come on guys lets not do that anymore
Re: Wheels for 78
« Reply #7 on: March 16, 2021, 11:08:43 PM »
Interesting info. So any cb mag will fit I gather   I want the stock mags that Honda had
Re: Wheels for 78
« Reply #8 on: March 17, 2021, 12:17:35 AM »
77 and 78  F models had Honda mags.... they are not the prettiest, 1/2 steel. Cheap to buy .
 T o put them on earlier models you need to  change the forks, and setup rear for disc...
Offline Alan F.
Re: Wheels for 78
« Reply #9 on: March 17, 2021, 08:06:39 AM »
(Drum brake rear) Comstars from a 78 CB750A will bolt on to your K8 with no mods. My understanding is the bare hubs were all the same, so use all your brake and drive side stuff, axle and spacers. Front should bolt on & go.
Dealer take-off new rear wheel: https://www.ebay.com/itm/NOS-1978-Honda-CB750A-CB750-Auto-Rear-Wheel-Rim-w-Bridgestone-Super-Speed-21-r2/360694823189?epid=1529954228&hash=item53fb163915:g:lYQAAMXQXZZRfSHg
Cheap & dirty rear wheel: https://www.ebay.com/itm/1978-honda-cb750-a-hondamatic-rear-wheel-rim/264978265887?hash=item3db1ef771f:g:vwcAAOSwQrpf2Ty0
Cheap & dirty front, same seller, maybe same bike:
https://www.ebay.com/itm/1978-honda-cb750-a-hondamatic-front-wheel-rim/254809324695?hash=item3b53d1bc97:g:khcAAOSwGb9f2Tzo
And a less dirty front:
https://www.ebay.com/itm/Honda-CB750-CB-750A-Hondamatic-7530-Front-Wheel-Tire/371958094549?_trkparms=ispr%3D1&hash=item569a6e1ad5:g:iPwAAOSwJH1ZInjU&amdata=enc%3AAQAFAAACcBaobrjLl8XobRIiIML1V4Imu%252Fn%252BzU5L90Z278x5ickk8ihYa55VeJusc0Ydu6jng8ALJpIVfmbiJp0aiQM4NiGh9EPu7cFPzAEaIBITorBOUak%252FfSW1vLmdGQHKdCU1MQ3iarlQDonTpBg13Q%252B%252FqKWe7G3jk8n1f8Iv3gqYkknmuBXzP1hi4v7CB5SJohuB19WqYlyUlh%252F3z%252F4hmqfhrDeFWvao2QQqsy0pZkgAEHSMXrWNbwzl8Gvtjc1tCiz1ifsa48lV3zA3Gi%252B7C8x8hiqxs36O0zGDL7rzDqWbaZ2F4cMABdB2tDMrxLegmt8H3keoj5q6ydN5jPmbYXvBZZ669s3F32Bx8Ys4Ldt1sUR0oyPEC7T59k7EaCa%252B8N1Lo7v90Rt%252FZP3rLG2OIoJb0xhw7bRsVEzeK1D1XU8aNWobbmMeyBIVMiWVbvbeHM5lkEQjC6eaB9NBNyBwHxXetgx1sJAY0X40E3O60Y0SWj31GFpi%252BQYmiHilz0THG0Ypl79NiRA2J5LqZvkEzTJ%252BI0c1w67H74aiGWCd%252FVZdt209zR%252FNOCV%252FgZJGMQQ0Be2fUt0Gtg28HPoGRvY8yEF5QfCR5lHIpKgP8EIYxJhuWwz7I9mB4Gb%252Bxcj8vnjgJJbMUecZLxn2aek5cXJLcUFXrepXX8kz7iEf4w7hvDpzWf0rw1jCg48A7rqjRVCk3dGLwltMx%252FsxiZVuDwQQbyaTZBXFPWkBL5SQQ6lOBkJsxgAZiV%252Bwa2FLUuTC0L0EUHw6dqX1UTMlmkL7N02zqhPUixKNI%252BuPkQHvof1nG0bB%252FE850WU%252FxXM8E%252BZQzP8%252BDC0zvw%253D%253D%7Ccksum%3A3719580945492843b553494a46c1a11931b7f28cbfc1%7Campid%3APL_CLK%7Cclp%3A2334524
« Last Edit: March 17, 2021, 11:10:13 AM by Alan F. »
Re: Wheels for 78
« Reply #10 on: March 17, 2021, 10:11:35 AM »
I have Comstars on Red, very happy with them.  I installed NAPA valves 90426 and run them tubeless.
Re: Wheels for 78
« Reply #11 on: March 17, 2021, 08:13:52 PM »
These 18”/19” Lester’s came on my K8. They worked really well on it for years (K8 sprocket hub lines the chain up perfectly). Moved them to the K3 +5 years ago. Bolted in a valve stem and run them tubeless.
« Last Edit: March 17, 2021, 08:21:08 PM by BenelliSEI »
Re: Wheels for 78
« Reply #12 on: March 18, 2021, 03:30:35 AM »
Something i found recently.  You could also tap the wheel with 1/4" NPT and use water tank valve.
Re: Wheels for 78
« Reply #13 on: March 18, 2021, 06:05:50 AM »
I used bolt ins from a local speed shop. Leaves the valve hole unmarked (rubber gasket on both sides of the hole) so I can still use a tube if needed. They also are cranked out at 45 degrees that makes filling and pressure checks a dream!
Re: Wheels for 78
« Reply #14 on: March 18, 2021, 07:49:47 AM »
I use these, but the 45 degree valve would come handy.  Do you have a part number?
Re: Wheels for 78
« Reply #15 on: March 18, 2021, 02:40:48 PM »
You guys rock. Should I just wait and get stuff to make rear disc and do forks too?  I’m kind of digging the modern fork look.  Just never done anything like that before.
Offline Alan F.
Re: Wheels for 78
« Reply #16 on: March 18, 2021, 02:52:50 PM »
That all depends on what you want to spend and how soon you want to ride. Do you have access to a lathe to make custom spacers?
Re: Wheels for 78
« Reply #19 on: March 19, 2021, 02:31:52 AM »
I used fork and swingarm from F3 to build Red, some frame customization was needed, but the brakes can run circles around the K0 brakes.
Re: Wheels for 78
« Reply #20 on: March 19, 2021, 08:21:39 AM »
F3 being the 1978?
Re: Wheels for 78
« Reply #21 on: March 19, 2021, 11:50:51 AM »
F3 being the 1978?
Yes, 78 SS
