Author Topic: HM300 vs HM341 Exhausts  (Read 6597 times)
Offline GLRoberts99
« on: March 27, 2021, 11:22:03 AM »
It's clear that everyone wants HM300 exhaust systems for their K0 / K1 rebuild, but how do you recognise a genuine HM300 system?
On my K1 project, number 1 exhaust is clearly marked HRM CB750 HM341 with light stamping. Exhausts 2 and 3 have HM300 stamped quite deeply and nothing else, and number 4 exhaust is badly pitted in the stamping area. All are badly corroded and should really be replaced, however, if the 2 & 3 exhausts are genuine HM300s then I'd like to invest in repairing them, but if they are replicas then I'd be better off spending money getting new replicas.
The questions I have are;
1. How can you tell if the exhaust is genuine?
2. Where should the numbers be stamped on the exhaust body?
TIA
Gareth
Offline 34barab
Re: HM300 vs HM341 Exhausts
« Reply #1 on: March 27, 2021, 01:09:56 PM »
I think both stamps indicate OEM Honda pipes.  HRM CB750 HM341 indicates it went to a European market.  HM300 is from an earlier model, possibly K0.
Current Projects: 1973 CB750K3; 1972 CB350K4; 1980 CX500D;1969 CB750.  Roadworthy: 1971 CB750K1
Online BenelliSEI
« Reply #2 on: March 27, 2021, 05:23:42 PM »
HM300’s were original to K0 and  K1 (1970/71).
Offline Tom
« Reply #3 on: March 27, 2021, 09:24:33 PM »
If you have a good number 2 pipe that’s the hard to find one, when the bikes are left on the side stand the small drain holes where the mufflers join the pipe do not face the ground and hold water and eventually rust out No2 is the hardest to find followed by the No1 pipe and then the NO 4 usually scraped then 3 is the most common good luck they are out there and you are half way there.
'59 T120.,'70 T120R Had one new.,'69 CB750 Oz Sandy Ruby Red.,'69 CB750 Oz Sandy Blue Green.,'70 CB750 K0 Candy Gold.,'71 CB750 K1 Valley Green I bought new.,'71 CB750 K1 Candy Garnet Brown.,'76 Rickman Honda CR750 R.C. Eng Cobra Powered. Two CB750 Choppers a Amen Saviour and a a Santee rigid arm Softail. A ‘72 Z1 Jaffa, and lotsa fun Honda Monkey bikes.
« Reply #4 on: March 28, 2021, 09:28:07 AM »
 I used to watch ebay several times a day and list by newest ads. I was able to find 3 decent pipes.
Offline GLRoberts99
« Reply #5 on: March 28, 2021, 12:10:09 PM »
I've taken some photos of the numbering to show the difference between the HM300 stamping and the HM341. I'll have a look to see what it'll cost to restore the HM300s because it'd be nice to keep the original exhausts on the motor if I can.
« Reply #6 on: March 28, 2021, 12:17:25 PM »
 The style of the baffle will tell you of you have a 300 or 341 if the pipes still have them. The 300 is a tube that can be wrapped and the 341 is just basically has a cap or "diffuser" at the end of the pipe.
« Reply #7 on: March 28, 2021, 12:25:45 PM »
I recently had some Kawasaki pipes rechromed, I considered it a deal at $425 for three pipes.
Most shops wont chrome exhaust as they dont want to contaminate their tanks.
If your pipes have rust holes it may not be worth restoring them, most repairs that I've seen did not look good.
Offline caluser2000
« Reply #8 on: March 28, 2021, 12:39:28 PM »
The '70s exhausts didn't last that long at all before showing signs of rust out from the inside.-3 to 5years.
If I owned a 4 piper with rusted OEM mufflers  I'd get an adapter made up to fit a single muffler each side or buy a good used or new after market 4 into two system or decent 4 into 1 system/headers that the muffle can be replaced  on, not sound like the hounds of hell increasing my deafness on a long rides, doesn't look like a drainage pipe and I can keep the center stand. And preferably stainless steel.
The reduced weight ioss an obvious benefit.
« Last Edit: March 28, 2021, 12:55:52 PM by caluser2000 »
Every time you set your ass on a bike, you're playing a game of Russian Roulette between yourself and your own stupidity."
Offline Kevnz
« Reply #9 on: March 28, 2021, 12:59:40 PM »
FYI, a respected Honda dealer and racer from the '60's and 70's told me his shop often replaced mufflers under warranty. Said the problem was leaded gas, when we moved to unleaded, problem went away.
Good grammar: The difference between knowing your #$%* and knowing you're #$%*
Offline caluser2000
« Reply #10 on: March 28, 2021, 01:07:08 PM »
No it didn't. My brand new OEM 4 into 1 system I bought for my 1976 CB550F in 1990 were showing signs of rust rot at 5 years . Using unleaded fuel just increased the time a bit before you saw rusting the outside. Same happened on my brand mew 1981 CB650 Custom 4 into 4 mufflers. As well as the Japanese market CB750F2D muflers which I bought new in 1986 and made sure the exhaust drain hole were clear.
The bike would most likely be on it's second owner at 5 years.
These bikes were designed to run unleaded fuel from when they were first manufactured.
« Last Edit: March 28, 2021, 02:35:17 PM by caluser2000 »
« Reply #11 on: March 28, 2021, 01:19:33 PM »
Same as Honda knew that 750F2 valve guides wore out quick but only replaced them under warantee if they failed in first year. Low mileage riders had to pay for the repair when the smoke zgot bad
Offline caluser2000
« Reply #12 on: March 28, 2021, 01:31:31 PM »
There's also the early V-4 valve clearance issue. That tool they came out with was just a big hoax. I read tech docs from the head mechanic at Honda in the US at the time and he was quite clear the "special" tool hid the fact that the tool just camouflaged the wear issue.
Offline Kevnz
« Reply #13 on: March 28, 2021, 03:34:08 PM »
Mufflers rusting out in 5 years is a bit different from rusting out in 6 months, though. :)
I owned Jags in the 80's, and you would be replacing 1 muffler every WoF ( 6 months, there are 4 of them). Once unleaded came into use, mufflers seem to last forever. Have not replaced 1 in the last 20 years.
« Reply #14 on: March 28, 2021, 03:44:50 PM »
Simply not true. I have multiple '70s original exhaust on my bikes including CB750, CB550F, CB450 & SS50.
And I recently sold two sets of CB550K exhausts, one was in mint cond and the other in VG cond with only 1 rust area, not all the way through.
And if you want to talk two-stroke bikes, they never rusted out!
[have original exhaust on my H1, RD350, TS250 & Puch 50]
Offline caluser2000
« Reply #15 on: March 28, 2021, 03:54:18 PM »
How often have they been riden and how many miles have been clocked up? When was the last time those motorcycles were actually riden?
Fish oil was used to increase there life a bit more. The drain holes get blocked and athe moister is held inside and rots them out.  You will also probably notice the the majority of the ear 4-stroke Hondas actually in regular use had the mufflers or the whole exhaust system replaced. England and a few other countries use salt in the winter. Luckily we mostly use gravel grit. Climate is also a factor if it is a dry desert or temperature controlled emviroment of course they will last longer.
I've been riding Honda 4-strokes for a loooong time and know a lot issue with a lot of models.
Original 2-stroke smufflers of that era tend to rust from the outside if left to sit for a long time without any attention.
« Last Edit: March 28, 2021, 04:27:52 PM by caluser2000 »
« Reply #16 on: March 28, 2021, 04:41:34 PM »
 My 500 exhaust rotted out in 2 seasons but I rode in the cold on short trips.  Any new exhaust I get now gets coated on the inside and baked to cure it before it's ever installed.
Offline caluser2000
« Reply #17 on: March 28, 2021, 05:20:14 PM »
What do you coat it with Don R?
« Reply #18 on: March 28, 2021, 06:06:11 PM »
+1. I have 2 CB750s - one with HM341s and one with HM300s. Had both bikes for 20 yrs with the exhausts - in that time they have been ridden well - the HM341 bike has done 64, 000 miles and the HM300 bike 36,000 miles. One HM300 had to have a hole patched at the very end with JB Weld and its held for years. The HM300s originally came from Germany. I ride from March to December here in the Northeast. I park them in the garage for winter but do nothing special with the exhausts.
« Reply #19 on: March 28, 2021, 09:15:55 PM »
 The local Honda shop put 2x4's along a wall and hung all of the stock take off 4-4 pipes on the rack, when the rack went all around the shop, they got worried about the weight and scrapped them all. My buddy hauled pickup loads of them away.
« Reply #20 on: March 28, 2021, 10:09:51 PM »
Steve,the pipes complete with mufflers $425 ?? That's a Huge Deal !  8)
« Reply #21 on: March 28, 2021, 10:58:56 PM »
More pipes, Lotus Root variant
http://forums.sohc4.net/index.php/topic,166498.0.html
Car stock exhausts became much better when the steel were aluminized on both sides. Before that, end silencer rottened in a few years.
It's a pity that these expensive pipes have no rust protection.
« Reply #22 on: March 29, 2021, 01:50:39 PM »
1967 CB450....21,180 miles, last ridden 3/26/21
1976 CB550....14,198 miles, last ridden 3/19/21
1974 CB750.....9,868 miles shown, NOM, last ridden 1/29/21
1972 SS50.......TMU.......last ridden 3/25/21
[I generally ride one of my bikes every Friday]
Any other questions?
Offline caluser2000
« Reply #23 on: March 29, 2021, 02:00:02 PM »
Good for you.
I just love the passive aggressive types. :D
Do the ladies really agree that everything is bigger in Texas? 8)
« Last Edit: March 29, 2021, 02:05:07 PM by caluser2000 »
« Reply #24 on: March 29, 2021, 02:34:24 PM »
 I was always told short rides in cold weather cause condensation.  Your mileage may vary.
