Author Topic: Valve cover damage  (Read 3411 times)
Re: Valve cover damage
« Reply #25 on: April 15, 2021, 12:18:25 AM »
six sided socket with the ramps ground off,like the one on the left.
Offline Kevnz
« Reply #26 on: April 15, 2021, 12:22:11 AM »
Place in pre heated bbq, bake at 250 deg C and serve with seasonal vegetables! ;D
I filed the flats down to a tight 16mm, had to hammer the socket on, still no go, hence bbq trick.
Good grammar: The difference between knowing your #$%* and knowing you're #$%*
Offline caluser2000
« Reply #27 on: April 15, 2021, 01:34:22 PM »
Where did you source that cover from Kennz?
Every time you set your ass on a bike, you're playing a game of Russian Roulette between yourself and your own stupidity."
Offline wolf550
« Reply #28 on: April 15, 2021, 02:12:55 PM »
That would have been a great pic in the BBQ!
that cover looks medium... Medium well?
If you are going to be looking I still have an extra cover in my cabinet.
74' CB550 (Sold)
71' CB500/550 (Sold)
« Reply #29 on: April 15, 2021, 02:55:29 PM »
when you can push a fork into it its ready!
Offline Kevnz
« Reply #30 on: April 15, 2021, 07:28:23 PM »
All beadblasted and ready for some bling. Fortunately, tappet threads all good.
Caluser, got cover from PO, plus a few other bits. Got seat back from upholsterer, looking good. Beadblaster is my go to tool. A cheapo from Supercheap, it bleeds grit around the seals so end up with grit all over the garage floor, but worth the inconvenience.
Offline Kevnz
« Reply #31 on: April 16, 2021, 01:38:26 PM »
Hi Guys,
I just swapped over the rocker gear into the new cover. Just noticed, when picking up the cover from the other bike, that the rockers are quite loose, move freely. On the one I have just done, there were wavy washers on the rocker shafts that take out the endfloat on each rocker; not shown in the parts manual. Is this a later mod or something a PO has done? Rockers are quite stiff to move, others just rattle.
Thanks.
Online Kelly E
  • Geriatric Hooligan
« Reply #32 on: April 16, 2021, 02:30:52 PM »
When we got our blast cabinet we used silicone caulk for metal and layed a solid bead along all of the joints before assembled them. Once cured we removed any excess from the inside. It barely leaks any media. We spill more opening the door.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline Kevnz
« Reply #33 on: April 16, 2021, 03:35:24 PM »
That's not a bad idea. I added spongy internal door sealing strips, but they have compressed a bit and are now leaking, although they were never really good.
Thanks for the idea.
Offline Motorcycle jones
« Reply #34 on: April 17, 2021, 04:29:20 PM »
What motorcycle and what year?
Offline robvangulik
  • Honda Fourever
« Reply #35 on: April 18, 2021, 02:48:07 AM »
If you read only the last few posts you'll never know 8)
Offline Kevnz
« Reply #36 on: April 18, 2021, 03:49:37 AM »
Picture about 3 posts ago is a bit of a clue. Made an executive decision and decided to remove the spring washers; the rockers were too tight on the shafts for my liking. Now on the bike with tappets adjusted.
