Author Topic: Who sells the best starter clutch repair kit these days??  (Read 1344 times)
« on: June 23, 2021, 10:05:29 AM »
Not sure if still available from Honda??
Who else's kit have you used successfully?
Where did I see a new replacement starting clutch gear? Yamiya? Someone has one out there in aftermarket land??
Re: Who sells the best starter clutch repair kit these days??
« Reply #1 on: June 23, 2021, 11:01:13 AM »
Only the small stuff with springs. I think I bought my not yet used set from eBay Germany or DSS UK.
Yamiya add a washer too
https://www.yamiya750.com/index.php?main_page=product_info&cPath=246_21_250_58&products_id=62
They have also the gears and stronger motor too. DOHC CB900 motor with 800W/0.8kW marking might not be  that common on eBay.
https://www.yamiya750.com/index.php?main_page=index&cPath=246_21_250_59
Good looking CB750 starter gear available on eBay for less.
Offline Alan F.
« Reply #2 on: June 23, 2021, 03:15:07 PM »
I've seen YouTube videos where some sportbike's starter clutch was adapted to the early DOHC Honda fours, I wonder if that'll work for SOHC?
Edit: added video.
« Last Edit: June 24, 2021, 08:11:08 AM by Alan F. »
Offline Old Scrambler
« Reply #3 on: June 23, 2021, 06:45:35 PM »
Jerry.......a CB900 starter works great in my C.B.R.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #4 on: June 23, 2021, 10:50:20 PM »
My K6 has a CB900 starter motor too, thanks to this forum. ;)
« Reply #5 on: June 24, 2021, 09:55:26 AM »
Don't need a starter. My stock starters work great in both the 915 and the 1000. Just looking for starter clutch rebuild kit.
I do need to look at Yamiya.
OUCH!!! That starter clutch gear is pricey  :o
« Last Edit: June 24, 2021, 09:59:14 AM by Jerry Rxman Griffin aka MuthaF'er »
Offline Kevin D
  • SE Michigan
« Reply #6 on: June 24, 2021, 11:35:00 AM »
Following
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
« Reply #7 on: June 24, 2021, 04:02:06 PM »
I just ordered a refurb kit from CycleX which includes the starter gear, rollers, springs, and seal. Advised to reuse the spring caps.
« Last Edit: June 24, 2021, 04:17:43 PM by Jerry Rxman Griffin aka MuthaF'er »
Offline Kevin D
  • SE Michigan
« Reply #8 on: June 24, 2021, 05:58:51 PM »
Wow, I hadn’t seen that offering before… and for a reasonable amount.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
« Reply #9 on: June 24, 2021, 07:21:50 PM »
Hey Jerry, I did try refurbishing the starter gear hub a while back, and set it to CBJoe to test it. IIRC it worked for a short while, then began acting up, so he replaced it with a used one from Bill B(?), which also worked for a short time. When you get the gear, please measure the hub; IIRC I had to reduce the diameter by about .012" to clean up the surface.
