Author Topic: 1979 CB650  (Read 817 times)
Offline scott jones
1979 CB650
« on: July 21, 2021, 09:59:10 AM »
Hi there, Scott here. I have a 1979 CB650 that I just got. It's a little bit of a basket case but it seems to be all there. I was putting the cylinder head on last night & I managed to break 1 of the head bolts. It broke before i got to 17 ft lbs. Are these bolts reusable or should I have gotten new ones. Thanks.
Re: 1979 CB650
« Reply #1 on: July 21, 2021, 10:41:32 AM »
Usually they can be reused but, always a good idea to change them if you can afford it. Not sure if manual has specs for length to determine if they can be reused or replaced...stretched length...
Offline scott jones
Re: 1979 CB650
« Reply #2 on: July 21, 2021, 11:49:49 AM »
I understand. Thanks. I'll look for that.
Offline DaveBarbier
Re: 1979 CB650
« Reply #3 on: July 23, 2021, 12:37:59 AM »
Hi, these aren’t stretch bolts so it must have been a bolt on the exhaust side which was rusted up. You can guy them online but be aware that there’s 2 different lengths. Also these bolts should have oil or moly grease on the threads and under the head flange when torquing. That wouldn’t have asked the break so no worries if you didn’t add that.
If the bolt snapped and it didn’t look in bad shape I’d have a look at calibrating your torque wrench.
