Author Topic: K2 no oil in tank after sitting. Drain crankcase and refill oil tank?  (Read 841 times)
Offline 914eener
My K2 has been sitting for about 5 months on the centerstand while I waited for Marcel to restore my gauges.  It has not been started during that 5 month period.  The gauges will hopefully be delivered soon so I checked the oil tank today getting prepared for a restart.  There is no oil in the tank so I’m assuming it has drained past the check valve and into the crankcase.  Normally the bike is ridden every two weeks or so and I don’t have this issue.
Should I just drain the crankcase and refill the oil tank?  Thought it would be a good idea to turn the kill switch off and crank the engine a bit to build oil pressure before actually starting it.
« Last Edit: November 08, 2021, 12:05:11 PM by 914eener »
1972 CB750 and 1977 CB400F
Re: K2 no oil in tank after sitting. Drain crankcase and refill oil tank?
« Reply #1 on: November 08, 2021, 12:35:11 PM »
Thats fine.
« Reply #2 on: November 08, 2021, 03:14:19 PM »
Fire it up and all will be good.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #3 on: November 09, 2021, 07:07:24 AM »
This happens, you cranking the engine should pump the oil back up to the tank without damaging the engine.
