Author Topic: 85 fz 750  (Read 20987 times)
Offline grcamna2
Re: 85 fz 750
« Reply #175 on: December 24, 2024, 06:27:24 PM »
How did your replacement fuel tank look Mark;did the inside look better than the original ?
75' CB400F/'bunch o' parts'
Offline Mark1976
Re: 85 fz 750
« Reply #176 on: December 24, 2024, 07:11:22 PM »
The replacement tank was great inside, everything worked and aside from two small dings, it had the fuel gauge sending unit and a decent petcock, no gas tank cap, bought a new one (only cost $25). Repaired/repainted the lower half silver again and a couple of coates of clear later, and it was done. I spent $225 total on the tank, cap and paint. A steal in today's world. It still has the original graphics (which are checked) and the original red on top. Re-cleared the entire tank to preserve the upper half. Might, might..... Repaint the entire tank and apply new graphics in the spring, there just sitting on a shelf, but the red on the tank has a rainbow like flake in it (very fine) and I've not found a reproduction color of that yet. There's the solid red (Toyota color) available, just not with flake in it. So yeah we'll see...
Start with the end in mind...
Offline grcamna2
Re: 85 fz 750
« Reply #177 on: December 24, 2024, 07:40:56 PM »
Mark,do you know if a person can install some type of risers that will accept regular handlebars ?
Offline Mark1976
Re: 85 fz 750
« Reply #178 on: December 24, 2024, 07:54:31 PM »
   So, I've seen where there are adaptations for conventional bars, whether or not that means you could install a riser and then round stock conventional bars, I don't know. The bar setup as it is, really isn't that low. It may have been in 1985 but by today's standards, its standard.
Offline Mark1976
Re: 85 fz 750
« Reply #179 on: March 01, 2025, 06:54:19 PM »
   So about three days ago we had a break in the weather, so I thought I'd (since it's been more than a few weeks) start up the various bike in the garage and take 'em for a spin. When I got the  fz750 it wanted nothing to do with it, the damn thing turned slowly and then ground to a buzzy halt. I'm thinkin, battery, check it then put it on the charger. Nope battery's fine (f#$k), so out comes the starter, not bad, not fun either, but after its out and apart it's obvious the starter's fried. Brushes are worn right down to the leads and the commutator is just burnt to a crisp. Sooo, call a friend of a friend and for $29 I get a pretty good reasonable used starter.
   Put it in a we're good to go, waaaay better'r than the original, spins way quicker than the old one. Life should always be this easy.
Re: 85 fz 750
« Reply #180 on: March 02, 2025, 01:26:34 AM »
Glad your friend could bail you out with a spare starter and issue resolved...
Look forward to ride report and you joining the 25 rides thread.
Offline Mark1976
Re: 85 fz 750
« Reply #181 on: August 06, 2025, 10:16:40 AM »
  Well, doing a pretrip and guess what shows up, fkn screw stuck in the rear tire. Had to have happen right at the tail end of yesterday's ride, there's almost no sign of wear on the screw head, guess who's buying a new rear. This is a first in over 50 years of riding.
Offline simon#42
  • liverpool
Re: 85 fz 750
« Reply #182 on: August 06, 2025, 11:05:14 AM »
you could put a plug in it , they work fine and it saves a tyre
Offline Mark1976
Re: 85 fz 750
« Reply #183 on: August 06, 2025, 12:53:02 PM »
   Yeah, I'm kinda on fence about what to do, decent tires are getting pricey, it is what it is. It can sit, I've got other bikes to ride. Fk....
Offline grcamna2
Re: 85 fz 750
« Reply #184 on: August 06, 2025, 05:03:28 PM »
+1
Offline BenelliSEI
  • 1969 cb750
Re: 85 fz 750
« Reply #185 on: August 07, 2025, 06:06:11 AM »
+1. I did one just like that two years ago and no issues.
Offline Mark1976
Re: 85 fz 750
« Reply #186 on: August 07, 2025, 06:48:54 AM »
 Well, I ordered a new tire, wasn't comfortable with the idea of a plug or a patch, but I'm going to see if one of the shops in my area will do it and then hang on to it for a while. Whether I toss it or repair it, eitherway it'll cost a few bucks. And in the meantime, there's other bikes to ride..
Offline grcamna2
Re: 85 fz 750
« Reply #187 on: August 07, 2025, 07:11:21 AM »
The small screw hole there can easily be patched,and the best type is a Radial Patch,where the tire is removed and the tire repair shop installs it from the inside;they carefully prep it,and it'll never pull out.
Bring it to a quality tire place,and don't let a kid who doesn't care do it;have an employee that's done it many times install it.
Nice bicycle  :)
« Last Edit: August 07, 2025, 07:15:01 AM by grcamna2 »
Offline Mark1976
Re: 85 fz 750
« Reply #188 on: August 07, 2025, 07:18:16 AM »
Nice bicycle  :)
Will do...
Offline grcamna2
Re: 85 fz 750
« Reply #189 on: August 07, 2025, 07:29:03 AM »
Nice bicycle  :)
Will do...
I have seen guys in a tire shop install them.
The employee first removes the piece of metal/screw to see which path the hole was on;with a screw,they carefully un-screw it and see the angle the screw took when it embedded itself into your tire,then they use a hand tool to prep/rough-up the hole in the orientation/path the screw was in there. They prep the area around the inside of the tire for the patch to overlap the hole and add rubber cement into that area and the hole,then pull the Radial Patch all the way through from the outside. I hope you didn't remove the screw,let them do that so they can see the path the screw took.
Offline Kelly E
  • Geriatric Hooligan
Re: 85 fz 750
« Reply #190 on: August 07, 2025, 08:55:09 AM »
I've done plenty of plug patches from the outside and then wore out the tire. It works great and I've never had one leak. I carry a plug patch kit on the Concours incase I pick up a nail or screw out on a road trip. No need to replace a perfectly good tire over a little screw or nail hole.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline simon#42
  • liverpool
Re: 85 fz 750
« Reply #191 on: August 07, 2025, 10:04:15 AM »
yes me too , very handy when you are miles from home and everywhere is closed .
Offline Mark1976
Re: 85 fz 750
« Reply #192 on: August 07, 2025, 10:07:55 AM »
I guess I oughtta invest in one... $198 for a tire, and I dismount and remount and balance the whole sha-bang, gettin not to be so much fun anymore. The local shops wanted $300 plus to do the same thing, I was like, "I can't do that, its one f#$%'in tire." The whole bike repair/maintenance thing is just getting ridiculous, cars are no different, but I literally can't fix the car anymore so it is what it is... If you're buying a new bike everybody wants to know ya, if ya got an old bike nobody cares.....
Offline grcamna2
Re: 85 fz 750
« Reply #193 on: August 07, 2025, 10:25:37 AM »
A new tire can be a spare,for when you wear-out this one.
You can remove that good(slightly used)tire yourself,take it to a tire shop for a good repair.
Offline BenelliSEI
  • 1969 cb750
Re: 85 fz 750
« Reply #194 on: August 09, 2025, 05:04:51 PM »
Totally agree. I wouldn’t go to the salt flats or road racing on it, but for the road, no problem.
Offline Mark1976
Re: 85 fz 750
« Reply #195 on: August 09, 2025, 06:12:48 PM »
   Well, I'll invest in the kit somewhere down the road, but for the time being I mounted and balanced a new tire today. So it's done with, avon mkII roadrider, $210 from dennis kirk, a full $116 less than what the local shop wanted.
Offline grcamna2
Re: 85 fz 750
« Reply #196 on: August 10, 2025, 12:49:31 PM »
I've always liked Dennis Kirk & their deals,still order things from them monthly.
I call in and reach a live agent,every time.
