Got the belly pan printed and stapled together.
Its mostly hanging on its own. Gotta position the front mounts tomorrow.
Front fender is probably going to stay in two pieces since it makes all the assembly easier.
Halfway through sanding down all the staple shaped ridges, i decided to do stapling from the inside going forward.
Began modeling the front fairing support in cad. Getting creative and thinking of more organic shapes likes bones and tree limbs. The first article was printed light, one wall, minimum infill. But was still super rigid. The final piece will certainly be something else. I gotta reposition the gauge cluster to make room. Not that the tacometer ever worked.
I'll come up with something similar for the tailfin. Both parts feature a centered slot to aid with aligning the fairing on the bike. Airshapers virtual wind tunnel really drove it home, how sensitive laminar airflow is to even small variances in positioning.
The switch on my battery powered die grinder went out. Got stuck in the on position.
Sometimes, it doesn't come back on unless the battery gets slammed into the posts a couple of times. So i thought to myself "who says you can't kickstart an electric motor?"
In other news, am penciled in for shoulder surgery by the end of the month.
