I haven't seen much mention of coatings in the various engine build threads, but I'm sure many of you are using them or would like to know more. I first got interested in coatings in a big way about 20 years about when myself and some friends starting racing out at Bonneville, albeit with a little 260ci Chevy V8 in a '23 roadster on gasoline. That little Chevy made over 600hp naturally aspirated on gasoline and we shifted at 9800 rpm...custom 2.5" stroke and over 4" bore. That got us our first red hat and into the 200mph Club...anyway in the coming years we went from the little E class motor all the way  up to the AA unlimited class and took every record in every class, many still standing today. Running 5 miles at WOT REALLY make you think about how to make an engine last...I think of a LSR motor much like a road race motor....you want gobs of HP, but not so much that it's unreliable. In the end basically every single moving part has some sort of special coating on it. Sorry about the ramble....so anyway...what are you guys using on your race motors? Any lessons learned?
I've been applying Techline coatings in my shop for a good 15 years. Some things I've learned along the way are that you really need to look at each specific motor, how it's designed-air cooled-liquid cooled-, how it will be used...what type of fuel...
Ceramic heat barrier type coatings are amazing and I love them, but you need to be careful before coating everything and the kitchen sink. Many race motors will get a ceramic on the piston crown ( and Dry Film Lubricant -DFL-on the skirts) as well as the combustion chamber and faces of the valves in an attempt to keep ALL the heat in the chamber...because heat is HP and if it's in the chamber, it's making power right? As well there is another type ceramic that I put in some exh port runners to both keep the head from overheating and as well to keep the exh as hot as possible, which turbo motors really love and NA can be good in some cases and motor design...but one also needs to consider things like...if you are keeping all the heat away from the piston (which heats the oil quite a lot on many motors) and away from the head, which also gets the motor and oil up to temp, especiailly on a water cooled motor....so then you end up with a motor that can't get it's oil to temp until the last lap...but you made 0.02% more HP due to combustion efficiency, but lost 0.5% HP due to cold oil. those are just hypothetical numbers for the lesson.
Fuel quality....pump gas, race gas, E85, methanol....when you keep all the heat in you chamber, you better have good fuel and also be able to keep an eye on detonation and control it. You can't make HP if you have detonation...or not for very long...
..E85 and alcohol/methanol are great, they keep everything cool and doesn't really matter if you are a bit rich or lean, your aren't going to hurt the motor. Nitro..that's another thread. I have a customer here in Norway that has a giant turbo on his old Volvo rally car. The 98 we get at the pump isn't really as good as you might think so we ceramic coat his pistons to protect them, but not the chambers so they can extract some of the heat from the process and he can run a bit more timing without detonating. His motor lives and he wins races.
On our air cooled inline 4 motors, they are all quite similiar from the smaller variations to the big bore liter plus bikes. Basically all sliding friction surfaces could likely benefit from a DFL coating on just about everything I'd think. The majority of all wear on  plain bearing(insert bearings) comes from the time you start the motor until the bearing gets oil pressure and its riding on a film of oil. The DFL helps hold oil on the bearing surface so you don't get that wear and as well can decrease the frictional losses as well. Same principal on your piston skirts...they are just a sliding bearing and while crank centerline to bore centerline does have an effect on the side thrust, all the wear and business end of a skirt is the sides perpendicular to the pin, which is why you can cut down the skirt on the pin ends with no loss of function and decrease your frictional losses. You can even coat your tranny gear teeth faces and thrust faces after you spent all that time lapping them together...And rod bearings!!! Oil control is via your clearance of the bearing to crank...it is not and should not be controlled by tight clearances on your rod side clearance to the crank...run those suckers loose...the Dyno will thank you.
You can also coat your rotating assemblies with oil shedding coatings so you aren't carrying extra ounces of oil on you parts turning 10-12000rpm....when you just got done balancing the assembly not taking this into account...
I'm rambling and my wife is yelling that I'm being rude that dinner is on the table....please post you experiences and thoughts!!
