Author Topic: What did you do to your non-SOHC4 motorcycle today?  (Read 77940 times)
Re: What did you do to your non-SOHC4 motorcycle today?
« Reply #950 on: September 28, 2025, 08:19:29 AM »
Beautiful 1100!
If it didn't already have an O2 sensor, how will it be used?
« Reply #951 on: September 28, 2025, 10:43:28 AM »
Beautiful 1100!
I have an autometer gauge on the handlebars, it reads out digitally and with a color bar graph. It also has a digital memory that I can check later. It seems the carbs came jetted very well when new. My probe was reading rich and led me astray.
Offline Magpie
« Reply #952 on: September 28, 2025, 04:27:41 PM »
Into the guts of it.
« Reply #953 on: September 30, 2025, 08:05:42 AM »
Is it damaged? Or just routine freshen up?
Offline Magpie
« Reply #954 on: October 01, 2025, 08:57:34 AM »
It's new to me so I wanted to see how it looks inside. New rings coming. Cliff.
Offline Kelly E
  • Geriatric Hooligan
« Reply #955 on: October 07, 2025, 02:10:27 PM »
I finally finished installing the National F-16 windscreen on the 77' KZ 1000 LTD. I needed something to block the wind blast. I like the basic design but the quality control could be better. I knew I would have to alter the mounting slots because of moving the front turn signals from the bars to the headlight mount. I had to open the slots up from 10mm to 15mm. I wasn't happy with the amount of vibration at the top of the windscreen and how easily I could push it back further so I made braces for the upper part.
I used some handlebar clamps from an old busted windscreen, some rubber lined 3/16" P clips and a couple pieces of 3/16" rod. I drilled 4mm holes in the upper part of the windscreen to mount the P clips. With an inch of the rods bent about 110° to fit in the P clips and the bottom goes into the bar clamps. I have used this method for other fork/handlebar mount fairings, it works great.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline Magpie
« Reply #956 on: October 11, 2025, 10:10:45 AM »
A bit of cleaning and the frame is ready for paint prep and waiting on a friend to go through his Triumph stuff that I can have. This may be a long term project.
« Reply #957 on: October 13, 2025, 07:41:16 AM »
Cliff….. looking at your photo. Replace the oil pump now?
Offline Thunder
« Reply #958 on: October 14, 2025, 06:43:01 AM »
Finished a CB, then found the older "finished" bikes needed a refresh , so CBX on the bench
...Faceplates were $$$, so of course i go an crack one when inserting the needle stop
« Last Edit: October 14, 2025, 06:47:40 AM by Thunder »
« Reply #959 on: October 14, 2025, 09:37:04 AM »
CBX  8)
