Author Topic: 550 carb overflow, Niagra put to shame  (Read 1098 times)
Offline jvandyke
« on: August 26, 2022, 07:55:06 AM »
Just finished rebuilding a friend's carbs, complete teardown and rebuild, back on bike and gas ran right through them (at least 3/4) pulled them (yes I know, I should have benched tested before install), checked needles and seats, they all pass the blow test, easily holding back what I can blow into the gas lines, double checked float height, all 22mm, this is part of the reason for the rebuild; gas pouring through the carbs although I'm 95% sure this is first time rebuild for these carbs since '75.  All 0-rings were rock hard.  Not sure where to go from here, I will check overflow tubes for cracks, make sure floats actually float I guess....what else?
1972 CB500, 7500 miles, in family since '73
Offline OldGreyBeast
  • I like motorcycles.
Re: 550 carb overflow, Niagra put to shame
« Reply #1 on: August 26, 2022, 08:22:07 AM »
2 of my carbs do that any time the bowls run dry.  I have to slowly feed gas into them and tap on the bowl/body lightly with a screwdriver, add a little more gas, tap again, etc.  I've replaced the floats and the pins but those 2 carbs do it regardless.  The floats have just a tiny bit of resistance before they'll start floating.
If you do that does gas still pour out,or does it eventually stop and hold properly?
1974 CB550, 1975 CB550, 1976 CB550, 1986.5 Nissan D21, 1987 Mercedes 190D Turbo, 2010 Mercedes E350, 2016 Suzuki GSX-S1000
Offline jvandyke
« Reply #2 on: August 26, 2022, 08:59:01 AM »
I can try tapping and such to get them to shut off but just now I used a tube in place of the drain screw and verified on the bench that that one at least just keeps on flowing so I readjusted it to a bit over spec; 23 or mm, which to me means it will shut off a bit quicker and re-tested, it didn't overflow, according to the clear tube next to the carb body.  I think I just go through and reset all the float heights and bench test and play until I get consistent shut off, it's no fun fitting carbs over and over for testing.  My manual shows checking the float height with the carb at 90 degrees, but when flat my floats are light enough they don't seem to compress the needle spring at all so not sure it matters.
Offline jvandyke
« Reply #3 on: August 26, 2022, 10:07:21 AM »
Okay well I'm not sure what did it but after resetting all float levels to maybe 23, just a tad out of spec, they stopped dumping (yes, bench tested this time!) reinstalled and she seems to run great.
Offline Flyin900
« Reply #4 on: August 26, 2022, 10:36:59 AM »
When refitting the fuel needle it is important to ensure it moves smoothly in the brass seat bore too. The side of the brass seat can also be gummed up with old gas varnish.
So if as you noted the fuel needle isn’t smooth in its motion in the brass seat, that will also cause hang up float issues and flooding.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
« Reply #5 on: August 26, 2022, 11:30:41 AM »
My 550F is same way, one carb will overflow when first started but then will be ok after a few minutes
« Reply #6 on: August 27, 2022, 12:58:35 AM »
are they the early type one or the later PD carbs?the PD carbs can develop a split in the over flow pipe,ive seen a few,some have split the entire length and others about 10/12 or so down from the top.
Offline sixthwisconsin
« Reply #7 on: August 27, 2022, 10:22:53 AM »
I've had much better luck using the clear tube method for setting float height. I set if for about 2mm below the bowl seam.
Here is a link but there are many.
http://forums.sohc4.net/index.php?topic=151263.0
Offline Deltarider
« Reply #8 on: August 28, 2022, 12:16:49 AM »
I've tested this clear tube method and I found it quite a hassle with the risk of jumping too early to conclusions. Also you have to manufacture a tube that will fit (thread!) first. My method is simple, fool proof and works well on all oldstyle carbs. As a bonus you will have cleaned the bowls from any debris in the process, which is recommended to do anyway, say once a year. http://forums.sohc4.net/index.php/topic,185754.msg2151647.html#msg2151647
Oh... and I never had to readjust the float heights in 46 years, so as long as previous owners have not touched them...
« Last Edit: August 28, 2022, 12:41:24 AM by Deltarider »
CB500K2-ED Excel black
