Author Topic: RING Security System?  (Read 830 times)
« on: October 28, 2022, 01:03:50 PM »
Hey Guys...need to upgrade our current home security system, our current provider wants to push us to ATT for some reason?
The wife has "assigned" me to research, buy and install the Ring system or Simply Safe, but she is leaning towards Ring after reading reviews.
Do any of you have one and DIY installed it? If so, plz give me some useful tips.
https://ring.com/
Not looking for any other advice from someone that does have first hand experience even if their wifes-brothers-second-cousins-uncles-red-headed-step-child doesnt like it!.
Thanks
Re: RING Security System?
« Reply #1 on: October 28, 2022, 03:07:55 PM »
subscribed.
I lost a decent used leather jacket 2 years ago on account of porch thieves;I'm so mad because I was in the apt. at the time and I waited 20 minutes to open the door after Fedex delivered it..  >:(
I still need a leather jacket to ride with.
« Last Edit: October 28, 2022, 03:28:12 PM by grcamna2 »
« Reply #2 on: October 30, 2022, 08:05:47 PM »
The RING (doorbell + video) things are springing up all over my neighborhood (which goes along with the front-porch delivery thefts rising like pop-bottle rockets). The owners I've talked with about them all have smartphones that link to them and alert the owner to any movement on their porch. While it does an alert and takes video/pix, and some let you yell at the thief from your cellphone, so far it hasn't actually STOPPED any thefts. One or two victims managed to cooperate and get one thief cornered and the police called to nab the perp, but there are dozens of them going on every month here.
We don't suffer a lot of burglaries around this neighborhood, though: about 70% of houses have dogs of some sort, and about that many homeowners have, umm...armament...handy. Some actually have notices about this on the doors of their homes, too. Mostly we try to watch each other's houses if we're out and about (like, walking our dogs, etc.), and if someone isn't home, but there's packages on the porch, we either move them to their backyard or otherwise hide them from drive-by viewers. It's surprising how fast this sort of activity will 'unite' a neighborhood, too.
« Reply #3 on: October 31, 2022, 01:56:14 AM »
I never had problems with packages left outside the gate but I have seen houses with special "box for deliveries" installed by the mailbox if their driveway is too long.
« Reply #4 on: October 31, 2022, 02:42:00 AM »
That's an idea..... bolt it down to concrete or better up on a concrete filled steel post, maybe with an electronic lock on it where you give the code in the delivery instructions on your order, and wire in a zapper if someone decides to mess with it without having the code, the more they mess with it, the bigger the zap!!
« Last Edit: October 31, 2022, 02:44:40 AM by newday777 »
« Reply #5 on: October 31, 2022, 02:44:53 AM »
Update the firmware on your Wi-Fi regularly and change the password on your Wi-Fi with complex passwords REGULARLY!
You gotta keep both the cameras up to date and the Wi-Fi they are on secure. Some cameras do better at night than others.
Put a battery backup with more than a couple hours capacity on your ring alarm hub as well as your Wi-Fi setup. Wi-Fi jammers can black out your cameras for more professional thieves…just hope yours aren’t too professional.
Remote monitoring is a good idea so you are aware of anything shady and they retain the records longer than a home based system will…
They can handle any alerts you might miss and take action for you.
The Ring cameras are pretty good and you can set sensitivity zones on the camera to ignore bushes that wind blowing might trigger normally. Just don’t inform your potential thieves it is a Ring or Simply Safe, etc system. Be sure you have cameras protecting your cameras so to speak… you don’t want to have a camera be disabled without a camera capturing that camera’s blind spot… In Texas you are likely to have sufficient sunny days to use solar chargers that can keep your cameras charged so you aren’t using a ladder to change out charged batteries every month…or less if they are getting triggered a lot.
