Author Topic: Air solution  (Read 1439 times)
Air solution
« on: November 11, 2022, 04:16:44 AM »
Is anybody carrying some kind of an air source on the bike?  The main reason I am thinking about it is to be able to top up forks on the 900.  I learned in my bicycle days that hand air pumps are just chinese crap that brakes within few uses.
I remember adapter for engine cylinder but while it's clever solution, I dont want to go that route.
Thoughts?
« Last Edit: November 11, 2022, 04:18:54 AM by 70CB750 »
Re: Air solution
« Reply #1 on: November 11, 2022, 05:19:06 AM »
Last time I did this was on my Gl1000. Any compressor generates too much pressure and volume. A hand pump is best. There was a good bicycle shop near where I lived and they sold me an excellent pump. So small, it fit in the map/tool tray on the ‘wing. The bike is long gone but I still use the pump.
Re: Air solution
« Reply #2 on: November 11, 2022, 05:39:09 AM »
Thank you, would you know the brand?
Offline jgger
Re: Air solution
« Reply #3 on: November 11, 2022, 08:46:47 AM »
Check out Jensen USA, my son used to work there ant they sell  good equipment. It is a bicycle place and they have top quality mountian bike stuff.look for shock pump in their search.
https://www.jensonusa.com/sale
« Last Edit: November 11, 2022, 08:55:01 AM by jgger »
Re: Air solution
« Reply #4 on: November 11, 2022, 11:09:35 AM »
Thank you, I will take a look.
Re: Air solution
« Reply #5 on: November 11, 2022, 11:11:22 AM »
You could run a hollow-tubed swing arm that is charged with air and tap that intermittently with a portable hose you construct. Then, refill the swingarm as needed with your compressor at the house.
I built a bull bar for a friends truck out of 3” round tube for this exact purpose (inflating/deflating his tires). Works a treat when he shore fishes or camps in the outer banks.
I am familiar with that concept, I have on board air in my CJ7 - complete with York compressor.
Offline Kelly E
  • Geriatric Hooligan
Re: Air solution
« Reply #6 on: November 11, 2022, 02:25:08 PM »
I eliminated the problem by installing adjustable preload fork caps. They make them in a bunch of sizes.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline simon#42
  • liverpool
Re: Air solution
« Reply #7 on: November 12, 2022, 03:53:21 AM »
i use a low pressure bike pump similar to this , there are some very good quality ones around , make sure the pump screws on to the valve though . the forks hold very little air and it is very easy to loose it all disconnecting the pump
Offline Alan F.
Re: Air solution
« Reply #8 on: November 12, 2022, 05:30:25 AM »
I think the Honda spec is 3 to 11 psi.
Online HondaMan
Re: Air solution
« Reply #9 on: November 12, 2022, 09:20:35 AM »
I carry and use the old-style remove-a-sparkplug-and-screw-in-the-air-hose gizmo. works fine if you also carry the Honda toolkit. Both will fit under the seat, if you don't also carry the tire irons under there. One of these ends up in my tourpak.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Air solution
« Reply #10 on: November 12, 2022, 01:05:43 PM »
Not suspension related but...
In my first tour, i kept a cheap mini 12v compressor under the seat with tire plugs.  Only needed to use it once.
On my second tour, i got a li-ion portable compressor thats also palm sized.  Much more convenient for quick pressure checks ala cold mornings or elevation changes.
The li-ion almost had a shot at refilling a 200/x0-r18 tire on a broke down travellers bike.  Unfortunately, i had mis  sed plugging a hole.  Having already patched up two of em.  Probably woulda done the job.
Re: Air solution
« Reply #11 on: November 12, 2022, 04:16:14 PM »
So you dont use air at all in your forks?
Re: Air solution
« Reply #12 on: November 12, 2022, 04:17:13 PM »
Thank you, guys, for ideas.
Offline Kelly E
Re: Air solution
« Reply #13 on: November 12, 2022, 08:10:40 PM »
Nope, no air at all. It's easily adjusted in small increments. Many modern bikes come stock with adjustable preload fork caps. There's no downside unless you absolutely have to have everything bone stock.
1983 Honda CB 1100F
Re: Air solution
« Reply #14 on: November 13, 2022, 03:07:49 AM »
I like that.  The 900 already has progressive shocks in place of the rear air shocks, tires hold the air well and I have CO2 bomb for emergencies.
