Author Topic: Does this look like the exhaust gasket is still on there?  (Read 803 times)
Offline denward17
« on: December 05, 2022, 12:18:05 PM »
Looking at the pics, does that look like the exhaust gaskets are stuck on the head exhaust ports?
I tried using a pick tool to see if they would come loose, no luck.
Before I resort to harsher techniques, wanted to check to make sure that these are the old gaskets.  I assume they have never been out.  The stock rusted exhaust was still on the bike when I purchased.
Offline Tim2005
Re: Does this look like the exhaust gasket is still on there?
« Reply #1 on: December 05, 2022, 12:21:22 PM »
yes, it's the reddish-coloured thing
Online Don R
« Reply #2 on: December 05, 2022, 01:15:08 PM »
 Yup. go for it.
« Reply #3 on: December 05, 2022, 01:37:21 PM »
+1.  I typically use a small screwdriver and a hammer, a light tap should separate it.
Offline denward17
« Reply #4 on: December 05, 2022, 02:37:51 PM »
Good to know, Thanks Guys..
« Reply #5 on: December 05, 2022, 03:41:46 PM »
It is made of copper and the head is aluminum, so gentle tap, don’t wanna score or scar the exhaust port sealing surface.
Offline Shtonecb500
    • Youtube profile
« Reply #6 on: December 05, 2022, 06:11:35 PM »
use a razor blade to get it started if need be so you arent gouging with a screw driver.
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
« Reply #7 on: December 05, 2022, 09:01:12 PM »
Very small, thin screwdriver to get inside the gasket and lift it a little.
Then use a bigger one and get the gasket out.
Offline denward17
« Reply #8 on: December 06, 2022, 07:01:44 AM »
Got them this morning, using a small screw driver, Thanks for the tips.
« Reply #9 on: December 06, 2022, 11:02:40 AM »
It is possible that the gasket is not that visible.
Adding a new one on top and the exhaust might get a strange fitting.
