Author Topic: Brass fuel outlet tube pulls out of petcock.  (Read 1411 times)
Offline Old Moe Toe
« on: January 11, 2023, 12:45:58 AM »
As the title says, the brass outlet tube pulled out of the petcock when I was trying to remove the rubber fuel hose. 750K2
I am certain that this has been done before by many folk but the search button is a mysterious thing to me and never seems to work.
So I am wondering what the accepted fix for this is if one wants to stick the brass fuel outlet tube back in?.
Thank you
Re: Brass fuel outlet tube pulls out of petcock.
« Reply #1 on: January 11, 2023, 01:17:45 AM »
Take a centre punch and gently tap it into the pipe end that goes into the alloy to flare it out a bit then epoxy it in
« Reply #2 on: January 11, 2023, 02:09:56 AM »
Search tip in Google
"Terms you search" site:forums.sohc4.net
That will give you a list of hits on the site. The site's engine search is far from very helpful many times. I rarely use it because it doesn't work 85% of the time.
JB Weld is generally the epoxy most use successfully with tip that  Old Moe Toe provided.
« Reply #3 on: January 11, 2023, 03:05:12 AM »
When you pull the hose from the petcock's pipe, it's best done by twisting the hose hither and thither whilst pulling.
« Last Edit: January 12, 2023, 12:55:05 AM by Deltarider »
« Reply #4 on: January 11, 2023, 05:20:52 AM »
I have reinstalled with help of a metal hammer. No additional stuff.
« Reply #5 on: January 11, 2023, 06:08:50 AM »
I always add a small amount of JB Weld and tap them back in. They never come out again.
Offline WhyNot2
  • I'm finally an
« Reply #6 on: January 11, 2023, 06:29:51 AM »
I've got a few that the tube can be pulled out. I just slightly tap them back in, no problems.
« Reply #7 on: January 11, 2023, 06:30:28 AM »
I've cleaned the end and slightly scuffed with some sandpaper and tapped back in with a little bit of Seal-All.
Offline Little_Phil
« Reply #8 on: January 11, 2023, 07:35:13 AM »
When getting the hoses off I generally spray a little wd40 or the like around the end and leave for a few minutes. Remove from rear fixing of tank and prop up a little to give more room if hoses allow. Then as stated twist and pull and pry down on the end of the hose with a driver is well affixed.
Offline CycleRanger
  • No comment about being an
« Reply #9 on: January 11, 2023, 07:35:56 AM »
That is what I have done. No issues.
« Reply #10 on: January 11, 2023, 07:39:09 AM »
Would a bit of Locktite work?
Offline WhyNot2
  • I'm finally an
« Reply #11 on: January 11, 2023, 09:05:19 AM »
just need to be careful not to block the passageway.
« Reply #12 on: January 11, 2023, 01:23:10 PM »
I’ve used it too. Works fine.
« Reply #13 on: January 11, 2023, 01:37:05 PM »
Good to know
« Reply #14 on: January 11, 2023, 02:53:12 PM »
Veni, Vidi, Loctite!  ;D
