Author Topic: Header chrome performance query  (Read 1469 times)
Offline exponent
  • Obsessed
« on: April 02, 2023, 03:08:43 PM »
I had a curious question and maybe someone knew an answer. Does the chrome plating on 550/750 headers affect performance? Does it mitigate or help control heat? I've no ideas I don't know the chemistry or thermodynamics of chrome.
Wondering this partly because I wire brushed some of the chrome off my headers on accident and have been thinking of getting them redone.
'78 550K 2106630
Re: Header chrome performance query
« Reply #1 on: April 02, 2023, 03:38:28 PM »
 These days re-chroming usually costs more than new headers. I think chrome is usually more for aesthetics than performance. My new pipes get coated with eastwood interior header coatings, mostly for corrosion control but I think it protects the chrome as well.
 I'd take a look at Stainless steel headers if yours begin to look worse than you want.
Offline newday777
« Reply #2 on: April 02, 2023, 04:06:44 PM »
Most chrome platers won't rechrome pipes because of the oils in side the pipes from exhaust deposits which will contaminate the batch.
Chrome is for looks.
The Honda stock headers came double walled to help prevent blued pipes.
Most aftermarket pipes are single wall pipes.
Stu
My current rides
Prior bikes....
Offline Tracksnblades1
« Reply #3 on: April 02, 2023, 08:23:09 PM »
Good question,
The engineering hand book shows chominum has a heat coefficient of 70-80 dependent on temperature 71.3@ 991*
and 80@ 621*.  Where as carbon steel has a heat coefficient of 54 and they don’t show any different coefficients for temperature changes.. Copper having a heat coefficient of 383 @ 621*, and aluminum has a heat coefficient of 232 @ 621*,
for some examples of some metals that can really conduct heat always..
Looks like chrome helps conduct heat faster than just plain carbon steel..  cast iron has a coefficient of 54.7@ 621*….
Like others have said…. May not see any big HP with either type Dyno you use…
Age Quod Agis
Offline exponent
  • Obsessed
« Reply #4 on: April 03, 2023, 09:38:35 AM »
Good question,
Thanks this is interesting! Guessing I'll leave them as is
'78 550K 2106630
Offline C317414
« Reply #5 on: April 03, 2023, 11:16:58 AM »
Good question,
Decorative chrome usually has three layers over the original metal substrate: copper, nickel, and chromium.  The thicknesses are so small, that the effect on heat transfer is insignificant.
Offline Flyin900
« Reply #6 on: April 03, 2023, 02:04:57 PM »
I have had a variety of old exhaust systems rechromed on high level builds and the shop I use will chrome used pipes. As previously noted the pipes will contaminate the tanks if left exposed. The plater I use designs plugs to seal the system to prevent that happening.
That said a few systems ago one of my exhausts let go of the plug in his tank and destroyed the tank chemicals with contanimates. With the eye watering prices he charges I'm sure all was good.
It's hard now to find anyone who replates for cheap anymore, because of the environmental laws etc.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
« Reply #7 on: April 03, 2023, 02:35:28 PM »
Most chrome platers won't rechrome pipes...
I've had exhaust re-chomed, was not cheap or quick. Chrome wont get you home!
Offline newday777
« Reply #8 on: April 03, 2023, 03:12:37 PM »
I've had exhaust re-chomed, was not cheap or quick. !
How recently? What shop and where?
Stu
My current rides
Prior bikes....
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #9 on: April 03, 2023, 03:49:05 PM »
There is a chrome shop in SoCal, if you need the contact I’ll look it up.
Expensive but very nice work.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #10 on: April 03, 2023, 08:34:12 PM »
Good question,
I’m glad you included the last sentence in my post… 😁
Carry on….😁    You must…😁
Age Quod Agis
« Reply #11 on: April 03, 2023, 08:50:03 PM »
Jet Hot silver.
« Reply #12 on: April 03, 2023, 11:38:53 PM »
Jet Hot silver.
I could not resist to search.
Lots of hits and nice photos.
www.jet-hot.com
Look good! ;D
« Reply #13 on: April 04, 2023, 12:52:17 PM »
Two years ago, Kawasaki pipes [3].  Cen Tex Plating in Austin...David is the owner.
https://centexplating.com/
« Reply #14 on: April 04, 2023, 01:34:55 PM »
Jet Hot silver.
www.jet-hot.com
Look good! ;D
You can coat the outside and inside. Pipes cool down very quickly.....nice if you have to work on the engine after running it.
Offline newday777
« Reply #15 on: April 04, 2023, 03:35:42 PM »
Jet Hot silver.
www.jet-hot.com
Look good! ;D
Is that a do it yourself product or do you send the exhaust to their shop?
Stu
My current rides
Prior bikes....
