Author Topic: Cold exhaust  (Read 574 times)
Offline jwurbel
Cold exhaust
« on: May 15, 2023, 12:26:19 PM »
#2 exhaust cold as in cylinder not firing.  Tested coils and plugs. All within specs and all connections tight.
Tested caps.  The one leading to #2 registered 4.7 ohms.  The other 3 were at 5.4.
Could that be the issue?
Offline fizzlebottom
Re: Cold exhaust
« Reply #1 on: May 15, 2023, 01:41:27 PM »
Sounds like you might have a clogged jet / pilot circuit.
1982 CB650SC Nighthawk
2024 Kawasaki Z900RS
Offline jwurbel
Re: Cold exhaust
« Reply #2 on: May 15, 2023, 01:48:33 PM »
I think you may be right.
Switched caps and still cold.
Noticed I had gas coming out exhaust drain hole.  Did compression check and read 154 psi.
I guess it’s back to the bench.
If anyone else has any ideas, I would appreciate them.
Jim
Offline Scootch
  • Someday I'll know what I needed to know years ago
Re: Cold exhaust
« Reply #3 on: May 15, 2023, 02:34:59 PM »
Does that plug fire if you put it in a different cylinder?
Re: Cold exhaust
« Reply #4 on: May 15, 2023, 02:35:28 PM »
Pill the float bowl, take a mirror and look up at the jets
Online willbird
Re: Cold exhaust
« Reply #5 on: May 15, 2023, 03:16:07 PM »
In my case the float bowl was empty  :). Float valve needle was stuck up with gunk.
Re: Cold exhaust
« Reply #6 on: May 16, 2023, 01:27:31 AM »
Starter spray can help to determine if a cylinder does not get fuel. Spray into carb and it will start.
If not, ignition.
Re: Cold exhaust
« Reply #7 on: May 16, 2023, 05:21:56 AM »
Well with gas dripping out the exhaust sounds like a stuck open float or needle jammed and probably a fouled plug. That gas can migrate to the oil and if driven or run much won't do that cylinder any favors with the 'gas wash'. Maybe a screwdriver whack will fix it.
  Have you pulled the plug yet to get an idea as to what's going on in there ?
« Last Edit: May 16, 2023, 05:24:01 AM by ekpent »
Offline jwurbel
Re: Cold exhaust
« Reply #8 on: May 16, 2023, 11:35:05 AM »
Needle jet holder was not tight.  Almost completely out.  I wonder who was responsible for that?
Back running, just need to sort out other issues.
Thanks to all who replied
Jim
Re: Cold exhaust
« Reply #9 on: May 16, 2023, 11:57:19 AM »
Quick carb job not completely assembled?
Main jet change or a PO that did not dare or forgot to tighten it?
Put your nose close to oil tank with cap off when engine has been running for a few minutes.
If it smell gasoline, change oil and filter.
« Last Edit: May 18, 2023, 10:48:20 PM by PeWe »
