Author Topic: K&N "High-Performance" Air Filter  (Read 3069 times)
Offline Kaze
« on: November 06, 2023, 10:21:58 AM »
It's time to buy another air filter. I've always used whatever was available at the shop, which in most cases was Emgo. I'm probably just going to get another "cardboard" type filter this time too, but I was wondering if anybody liked the reusable K&N filters? From my limited knowledge of filters, it seems like one of those "good on paper, not in practice" type ideas.
I'd especially appreciate any opinions from folks who have actually tried one of these, or use one currently.
https://www.jegs.com/i/K%26N/599/HA-0100/10002/-1?gad_source=4
One man's rubbish is another man's project.
Offline rotortiller
Re: K&N "High-Performance" Air Filter
« Reply #1 on: November 06, 2023, 12:21:12 PM »
They are good so long as they are oiled properly. The K&N filter media is actually good enough to be used for aircraft air filters and they are cleanable/reusable, a virtue just like with Unis. I have one K&N on a Kawasaki triple that works fine. Also have Emgo and Unis OEM shaped air filters on various street bikes with no issue. Oil laden air foam filters are common on dirt bikes as they catch all the dirt. I have an oiled foam air filter on my R6 that works great. K&N is just a different way of filtering, so follow the directions and it will be fine on a street bike. Filters I would stay away from for a CB750 would be the pod types.
« Last Edit: November 06, 2023, 01:16:55 PM by rotortiller »
Offline Alan F.
« Reply #2 on: November 06, 2023, 02:37:22 PM »
That's not a bad price for the last air filter you'll ever need.
I picked one up on ebay a few years back for $55 and thought that was a very good deal. I wonder how their shipping costs are?
Online seanbarney41
« Reply #3 on: November 06, 2023, 03:24:49 PM »
That is all I have ever used on my cb750's...except for the anti-pod (foam) and a HA breadbox with UNI foam filtration.  Granted, SW Michigan where I do most of my riding is not very dusty, as long as you spend most of your time on the pavement.
« Reply #4 on: November 06, 2023, 04:32:58 PM »
I've used the K&N in every 750 I've owned or built up. There's nothing like them. When you get one new, it is severely over-oiled, so get the "Cleaning and Oiling" kit, too. It and the filter will still be usable when I'm dust!
When you get it, clean it completely, using the detergent and instructions in the cleaning kit. Let it dry for 1-2 days afterward. Then add just a drop (literally) of oil at the outside of each pleat, or if you get the spray oil, use a fast-pass across only the upper side (half) of the gauze, let it soak down, this will take most of a day.
Then it is good for 25 years, unless you ride more than 10,000 miles per year. I only cleaned and oiled my last one 4 times in 126,000 miles. It shrank at the top after 40+ years and wouldn't fit well in the airbox, so I bought a new one, in 2006. It hasn't been cleaned nor re-oiled since, and doesn't need it, either.
In case you can't tell, I REALLY like these filters... :D
« Last Edit: November 07, 2023, 08:06:44 AM by HondaMan »
« Reply #5 on: November 06, 2023, 05:09:40 PM »
In our stock air box they work well, the pod filters would require more frequent maintenance given their exposure will make them quicker to load up with dust.
Here in Southern AZ most shops do not recommend the K&N filters or Uni filters because of the high dust conditions we have almost all the time.
Offline Kaze
« Reply #6 on: November 06, 2023, 08:31:22 PM »
WOW. I did not expect such a resounding positive vote. Thanks guys! I'm glad that I asked. It's a big help.
« Last Edit: November 06, 2023, 08:51:26 PM by Kaze »
« Reply #7 on: November 06, 2023, 09:20:19 PM »
It’s just like another oil thread.. just tell me what manufacturers install them (K&N) on their products at the factory or will warranty the same on yours. On or off road..
https://www.project200.com.au/dm-iso5011/
Some tests of all that “properly treated dirt”.
It’s like what’s  the best oil? Pennzoil, Quaker State,  or Shell ?
Wonder who owns all 3.?
And another not as scientific as the 5011 test but similar results..
« Last Edit: November 07, 2023, 02:50:38 AM by Tracksnblades1 »
Offline Kelly E
  • Geriatric Hooligan
« Reply #8 on: November 06, 2023, 09:27:38 PM »
Banks Engineering supplied a K&N cone shaped filter with the premium Sidewinder turbocharger kit I installed on my 93' Ford F-250 diesel..
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline enwri
  • So that noise is normal?
« Reply #9 on: November 11, 2023, 08:14:29 AM »
I always thought K&N used to be popular because they flowed better for racing applications, and wear was just an accepted result from increased performance with engines being rebuilt regularly anyway.
Better than open stacks with stone screens, and still being able to breathe when covered in dirt.
Screwing everything out of most engines rarely results in long life and reliability but people do it anyway. It's just whether the performance gain is worth any negatives.
So unless you're riding near or through deserts, (Silica dust especially) the amount of contamination you'll pick up in your area could be low to start with so any extra wear may be negligible.
So will any performance gain, but it'll be there .
Can reuse them forever so that's a positive.
77 CB 750 k.. 29 years and counting.
91 TDM 850 (No.34) so comfy and soft
8? XJ 550 meh...
76 XL 350 Super Sport stump puller..
80 XR 200 idiot proof
75 MX 250 b dangerous
« Reply #10 on: November 11, 2023, 08:47:49 AM »
I have searched for alternative filters for my Mikuni TMR32 carbs.
Only K&N that make filters that fit. Pod filters.
I looked for Weber dual port filters that might fit. Again only K&N.
Same for my Mikuni VM29. They have K&N pods too.
My CB750 K2 has K&N filter in stock airbox.
Modern bikes have other filter maker alternatives.
When Im riding my K6 with pod filter I look for sudden dusty winds.  Typical in springs after winter when meeting a heavy vehicle as a truck or buss. Throttle off, clutch lever in and keep on rolling to clean air.
I have killed engine once after acceleration before rolling thru a local dust storm. Dry soil.
Kill switch on when thru and released the clutch lever to start it still rolling.
I trust the filter, just not want to make them dirty and need to clean them.
I rode 2 rides in November 2022 that made pod filters dirty. Wet slimy roads with thin sand like material. I got thoughts about volcanic ash.
Cleaned the pods again. They were cleaned only a month before.
The entire bike was covered by the dirt
« Last Edit: November 11, 2023, 09:21:14 AM by PeWe »
« Reply #11 on: November 11, 2023, 11:22:35 AM »
You would like BT Barnum and Mark Twain. They have some quotes  that follow your assessments..
« Reply #12 on: November 11, 2023, 11:34:24 AM »
 Has anyone else tried a K&N in a K0 airbox? They don't fit mine very well at all. I've never bought a new one, but they came in a couple bikes I've owned.
« Reply #13 on: November 11, 2023, 11:46:14 AM »
In 1977 my brother and I met in Texas in August, then toured the Southwest for several weeks (hint: do this in Spring or Fall, not August...). We were headed north from the Carlsbad Caverns area when we ran into a sandstorm out of the west. We decided to ride thru it, but when we got out of it both of our Vetter windshields were opaque down the left side (about 6" across the front from the left) and the bikes were running poorly. He had the Honda paper filter, I had my first K&N, in the airboxes. We stopped in the next town for the night, pulled out the air filters, and I washed mine out from the inside in the motel's sink and let it dry overnight. My brother had to run without a filter until we got to Albuquerque where the Honda shop had one for his CB500 SOHC4. His bike fouled the plugs about 50 miles after he removed the filter, so he was running on my spare set of X24ES-U by then.
The moral of this story became: use K&N filters when touring in remote areas. They are easy to renew out on the road. ;)
« Reply #14 on: November 11, 2023, 11:49:19 AM »
They are a TIGHT fit in the K0 box. I stretched one out lengthwise, using a long nut and 2 pieces of Allthread rod, pushing against 2 little wood dowels (with a hole drilled halfway thru to seat the rods), to stretch it lengthwise. It then fit on width-wise. It took overnight to 'set' the stretch. It was still snug to get on: that was many, many moons ago!
Online scottly
« Reply #15 on: November 11, 2023, 08:02:41 PM »
Mark, K&N warrantied the filters for 1 million miles, and would have replaced it for free. :)
« Reply #16 on: November 12, 2023, 02:21:25 AM »
But.....K&N has discontinued the filter for the 750.... so the Would have is the key word....
  • I'm back
« Reply #17 on: November 12, 2023, 04:41:21 AM »
I recommend the genuine Honda filters. They do not restrict, filter way better than foam and can be serviced within seconds. A filterexpert informed me that when airfilter A filters out 99,8 % of the particles and airfilter B 99%, enginewear with B will be fourfold.
If foam filters would be better, Honda would have chosen them.
Foam filters may do fine on lawnmowers.
Some may find it hard to believe, but as a matter of fact, paper filters get better in use. For this and more info: http://forums.sohc4.net/index.php?topic=98901.msg1102737#msg1102737
Can't believe so many favour aftermarket filters which are already inferior fom the start. On a CB500 Four, I can change my airfilterelement within 12 seconds and that includes opening the seat, removing the tooltray, etc. And time, my friends, is the only thing I cannot make extra of. So why would I spend precious time on oiling, getting my hands dirty and then have to worry: did I oil too much, too little?
« Reply #18 on: November 12, 2023, 06:51:55 AM »
I tend to stick to stock stuff like air filters whenever I can, few exceptions. I'm sure there are other good choices like K&N but I just like to stick with the stock stuff.
Offline rotortiller
« Reply #19 on: November 12, 2023, 08:20:04 AM »
I kind of like the Emgo paper OEM type airbox filters. One thing about some pod filters being exposed is when they get wet washing the bike  will often foul the machine, like running with the choke on lol. Pods bad airbox good  ;D
« Reply #20 on: November 12, 2023, 06:46:01 PM »
Wow! That's truly bad news... :(
« Reply #21 on: November 12, 2023, 09:11:41 PM »
K&N has not stock style on their web site. Only pods for CB750.
There are still filters to find by sellers.
I gave my K2 the first K&N filter for stock air box March 2022.
I have no known need today.
Maybe I should look for a filter nearby and order just for sure.
I think it flows air better, can be good as an additional jetting thing.
« Last Edit: November 13, 2023, 06:55:01 AM by PeWe »
« Reply #22 on: November 13, 2023, 06:42:45 PM »
+1….
Carl Sagan
“One of the saddest lessons of history is this: If we’ve been bamboozled long enough, we tend to reject any evidence of the bamboozle. We’re no longer interested in finding out the truth. The bamboozle has captured us. It’s simply too painful to acknowledge, even to ourselves, that we’ve been taken. Once you give a charlatan power over you, you almost never get it back.”
PT Barnum and Mark Twain both said similar at different times… and it will repeat itself for sure…
« Reply #23 on: November 13, 2023, 06:56:32 PM »
I might go dig it out and try that! I think it's still hanging in the garage somewhere. :)
« Reply #24 on: November 13, 2023, 08:42:27 PM »
I have one and found the same thing. It never quite fit right. It did go in my K8 for some reason, so there it stayed. I use OEM.
