Author Topic: Another project-1976 Honda CB550K  (Read 53797 times)
Offline denward17
Re: Another project-1976 Honda CB550K
« Reply #200 on: February 01, 2024, 06:36:52 PM »
Thanks Mark, I'll take them if you will get rid of them.
Offline Mark1976
« Reply #201 on: February 01, 2024, 06:45:39 PM »
I'll get back to ya....
« Last Edit: February 02, 2024, 12:45:55 PM by Mark1976 »
Start with the end in mind...
Offline denward17
« Reply #202 on: February 05, 2024, 01:12:54 PM »
Carb rack back together after cleaning.  Not complete yet, waiting on some brass from jetsrus and from another source.
Performed a leak down test today, and as expected I was in the 40-60% range of leakage, sounds like coming from crankcase on all cylinders.
I suspect this is because of not being run for a few years and cold.
I may pull the head off anyway to address what looks like oil leaks, or may just pop off the valve cover and replace pucks, not sure yet.
I have a habit of while I'm there and the engine is out........I hate to with only 12k miles.
Offline Mark1976
« Reply #203 on: February 05, 2024, 04:15:21 PM »
With only 12k miles, this is the most rational explanation. Given the ability to service the motor on the 550 while in the frame, I’d leave it be and get it running then, christen it with a good old fashioned Italian Break-in and see how she runs.
+1 !!!!!
« Reply #204 on: February 05, 2024, 06:19:15 PM »
+1. With that low mileage it might surprise you how well it runs after a few hundred miles and an oil change.
Offline denward17
« Reply #205 on: February 07, 2024, 01:23:28 PM »
Cleaned and polished a couple of covers waiting for carb parts to come in the mail...
I still have some more work to do on polishing.
Received carb parts from Mark1976 (Thanks Mark!) and jetsrus.  Carbs back together and float heights set to ~21.5-22mm.
Engine is next....plan is to pull off head, new head gasket, new oil seals/pucks for oil leaks and check valve to make sure none are leaking, then go from there.  The current plan is to leave cylinders alone.
Offline Mark1976
« Reply #206 on: February 07, 2024, 01:44:31 PM »
   Nice lookin' rack...
   Of carbs....
« Reply #207 on: February 07, 2024, 04:56:52 PM »
Nice work Dennis….. I seem to have left the carbs ‘till last!
Offline denward17
« Reply #208 on: February 08, 2024, 02:06:24 PM »
Head is off and all cylinders have a lot of carbon it appears.
I noticed something wonky with the tensioner, id doesn't want to automatically spring back to adjust the cam chain, so it looks like I need to lift the cylinders to take out the tensioner.
I didn't really want to do that as the cylinders look pretty good, with no wear marks I can feel, but I might have at this point to make sure the tensioner is functioning correctly.
Here we go...
« Reply #209 on: February 08, 2024, 02:58:34 PM »
Good plan, check it now.
Offline Mark1976
« Reply #210 on: February 08, 2024, 03:16:55 PM »
   A little bit of mission creep going on there, next thing ya  know you're splitting the lower half.
Do what ya gotta do, better safe than sorry.
Offline denward17
« Reply #211 on: February 09, 2024, 08:46:49 AM »
Cam chain tensioner teeth are bent from previous owners not knowing how to adjust.  I tried to repair but don't feel comfortable with it, just ordered a new Honda tensioner.
So that means the cylinders had to come off.
Time for some measurements and determine if I need to rebore and go to the next size pistons.
« Reply #212 on: February 09, 2024, 11:57:25 AM »
Looks like some fine weather there!
Offline denward17
« Reply #213 on: February 09, 2024, 12:22:54 PM »
It is pretty nice, mid 50s.....
Found out that tensioner/guide is not available anymore from Honda, argh...
« Reply #214 on: February 09, 2024, 02:00:53 PM »
Den,have you tried cmsnl.com ?
Offline denward17
« Reply #215 on: February 09, 2024, 05:32:13 PM »
^Yes, I looked, about $200 by the time it gets here.
I may try to repair mine and see if it will work.
Offline denward17
« Reply #217 on: February 10, 2024, 06:06:22 AM »
^Thanks Mark....thought bout a used one and thought it could be just like the one in my hand....
I hated to do it, but just ordered a new reproduction from JTMarks.
Offline Mark1976
« Reply #218 on: February 10, 2024, 06:30:42 AM »
   New is good!!!
« Reply #219 on: February 10, 2024, 01:41:15 PM »
You won’t be disappointed.
Offline Mark1976
« Reply #220 on: February 11, 2024, 03:39:03 PM »
   So the $64,000 question is, "whatta going to do with the head?" Best bang for your buck is spent here.
Offline denward17
« Reply #221 on: February 11, 2024, 05:21:23 PM »
I will just clean it up, lap the valves and check for flatness.
I thought about sending it to Mike, but he is tied up for a while.
Offline denward17
« Reply #222 on: February 12, 2024, 08:38:08 AM »
EDIT to add bore measurements:
appears to be a little bigger on Y axis
#1 x=2.3035 y=2.3045
#2 x=2.3037 y=2.3040
#3 x=2.3036 y=2.3041
#4 x=2.3040 y=2.3042
Standard piston size from manual = 2.301 - 2.30 with a limit of 2.302
Pistons measure: Edit: corrected piston measurements
1=2.3034
2=2.3035
3=2.3035
4=2.3035
Standard end gap = .005-.013 with a limit of .027
Piston rings end gap: (only measured #1 and #4)
1= top ring .013 in the middle and bottom of bore; .014 in top of bore
2nd ring is .015
4= top ring .014 in the middle; .015 top and bottom of bore
2nd ring same as top ring ring
Trying to determine if I need to re-bore or just do a light hone and new rings.
« Last Edit: February 12, 2024, 11:47:02 AM by denward17 »
« Reply #223 on: February 12, 2024, 10:38:07 AM »
Den,I imagine you're going to keep this 550?
The amount of work you're putting into it,it looks that way.
The numbers you mentioned above.. I personally would fresh re-bore it,imo.
Bring the factory service manual w/ numbers to the machinist.
I hope the condition of the valves,guides and seats are in excellent cond.,then lightly use some very fine grit lapping compound? unless the valves or seats are worn,then a light grind on them to bring it to 100% best compression for many years of enjoyable riding,imo.
Offline denward17
« Reply #224 on: February 12, 2024, 11:57:07 AM »
Thanks Bill, at this point I may keep it it for a few years.
The only thing that concerns me about the piston/cyl clearance is the difference in x-y axis, I guess that is to be expected.
The max difference is .001 on the x-y.
Should that be a concern?
Taking values from each bore (y axis) and piston size:
cyl/bore clearance:
1=.0011
2=.0005
3=.0006
4=.0005
Intake Valves look good, Exhaust not as good.  Going to lap all in and see if they leak.  All valve guides are tight.
I would hate to just buy new rings, hone and still have end gaps (~0.14) like I currently have.
Do stock rings come in oversize?
« Last Edit: February 12, 2024, 12:05:14 PM by denward17 »
