Author Topic: Another project-1976 Honda CB550K  (Read 58351 times)
Offline denward17
Re: Another project-1976 Honda CB550K
« Reply #325 on: March 24, 2024, 01:37:34 PM »
Dennis….. looking great. If you’re missing a wrench, it’s in there behind the brake pedal switch!
Lol, there as a reminder to tighten the bolt after installing battery box.
« Reply #326 on: March 24, 2024, 05:13:37 PM »
Brilliant. I have a small bag of yellow zip ties I use for just that. If something isn’t completely done at the end of the day, it always gets a zip tie.
« Last Edit: March 24, 2024, 05:15:16 PM by BenelliSEI »
« Reply #327 on: March 24, 2024, 07:28:47 PM »
I use blue painter's tape as a flag. And you can write a note on it.
Offline denward17
« Reply #328 on: March 27, 2024, 08:49:04 AM »
Nothing really to report.
I've been troubleshooting some electrical issues (left front turn signal), but got it fixed this morning.
Received a new battery (Scorpion) and it lasted about 30 secs in short bursts; with plugs out (trying to get oil pressure before start).
So now going through testing process of battery to see if I need a replacement, will be charging most of the day going through Batterystuff's testing procedure.
May try to add gas tomorrow and see if I can at least kickstart.
Online Mark1976
« Reply #329 on: March 27, 2024, 09:33:31 AM »
  It'll run like a Japanese watch!!!!!
Start with the end in mind...
« Reply #330 on: March 27, 2024, 10:20:01 AM »
Sounds like a bad battery. How annoying!
Offline denward17
« Reply #331 on: March 28, 2024, 08:54:18 AM »
After performing the vendor's test, and reporting the values, they are sending me a new battery.
Some results of testing:
1st starting voltage: 12.4v on bench
2nd voltage reading: 12.74v after 8 hour charge and resting for 30 minutes on bench
3rd voltage reading:12.64v after sitting overnight ~ approximately 14 hours after charge, on bench
4th voltage reading: installed battery in bike, 11.7v just turning key on, with headlight on and 2 running lights on; 6.5v when I hit the starter button.
Think it will kickstart like this?
Offline willbird
« Reply #332 on: March 28, 2024, 08:59:14 AM »
Back in the day when our bikes sat outside all winter we got 2 years tops out of a battery. The final portion of the second year often we had to kick start. At the very end sitting idling with headlight on the bike would quit if you put on the brakes and made the brake light come on. So IMHO if you unplug the headlight I bet it will kick start.
« Reply #333 on: March 28, 2024, 09:59:57 AM »
Den….…. With that rapid a voltage drop, it won’t start. If you need to try today, attach your lawn tractor or car with a set of booster cables to that battery…..
« Last Edit: March 28, 2024, 10:01:43 AM by BenelliSEI »
Offline denward17
« Reply #334 on: March 28, 2024, 04:11:42 PM »
And remove the fuse for the headlamp. Eliminate all auxiliary voltage draws while troubleshooting.
Good point, will remove headlamp/tail lamp fuses with the new battery.
« Reply #335 on: March 29, 2024, 06:57:01 AM »
 ...attach your lawn tractor or car with a set of booster cables to that battery…..
Important to say do not have the car running when you jump it.
Offline denward17
« Reply #336 on: March 29, 2024, 07:10:37 AM »
I'm going to wait on the new battery....need to start cleaning the gas tank next.
« Reply #337 on: March 29, 2024, 02:24:27 PM »
Completely irrelevant. The battery of the car will only discharge what is drawn from it. And the car battery is only storing 14.4v while being charged. That will not hurt the motorcycle battery as the current draw is still far less than what is available at the battery.
So you are stating that the alternator amperage output of the running car won't damage the bike electronics?
« Reply #338 on: March 29, 2024, 03:59:12 PM »
Yup. The output is what’s “available”. The consumption of the bike creates the “draw”. When your bike is running, it doesn’t draw more than the alternator can produce does it? And the Regulator toggles the output to the battery when there’s a deficiency, and shuts it down when there’s no need.
Just like your home. You’ve likely got 200amp panel, but about 600+ at the nearest transformer serving your home. By the referenced logic, that 600+ would flood the home and fry the electrical appliances and devices. But your home doesn’t draw that amount so the balance sits waiting.
Simple.
Thanks.
Offline denward17
« Reply #339 on: March 31, 2024, 12:02:41 PM »
2nd new battery scheduled to be delivered mid week, so I started sanding the new side covers from Frankenstuff; drilled holes for badge placement.
Poured about 3.5 gallons of white vinegar into tank and let soak for about 3 days, emptied into a 5 gallon bucket to see what came out, pic below.
I then rinsed with a baking soda water mix, rinsed it out good, then used air hose to dry it out inside.  I am now soaking some Evaporust in the tank, only had about 2.5 quarts.  Will swish around and prop tank at different angles over the next few days.
I thought the tank looked good before I started, but did get some gunk out.
« Reply #340 on: March 31, 2024, 12:14:58 PM »
Den,that rust may have been on the underside-Top of the tank.
« Reply #341 on: March 31, 2024, 12:34:22 PM »
Exactly why you need to full the tank full. This picture is with a bore scope.
This is the top of the last tank I cleaned, electrolysis, followed up with Evaporust. Apparently I hadn't burped the tank when I filled it. I buy a 5 gallon bucket of Evaporust.
Offline denward17
« Reply #342 on: March 31, 2024, 03:55:30 PM »
Newday, I have ordered some more Evaporust....do you rinse with anything afterwards, or just leave the Evaporust film in there before putting in gas?
I plan to paint the tank after cleaning the inside.
« Reply #343 on: March 31, 2024, 03:59:42 PM »
I usually splash a 50/50 mix of two stroke oil and gas around and drain. 1 pint is lots if you give it a good shake.
Offline denward17
« Reply #344 on: March 31, 2024, 04:41:35 PM »
I don't think I want any gas vapors in there while sanding and prepping tank for paint, so will coat inside with some 2 stroke oil.
« Reply #345 on: March 31, 2024, 06:10:42 PM »
I rinse with fresh diesel fuel, 1-2 quarts, shake lots to capture moisture of the Evaporust, dump into empty 5 gallon bucket to recycle, do this 4 times. Then coat the tank insides with 6 oz 2 stroke oil to preserve the tank. Dump out excess when you are ready to put it into service.
Offline denward17
« Reply #346 on: April 01, 2024, 12:09:41 PM »
First coat of primer on side covers, started on tank.
Sanding with 80 grit was a very slow go trying to get decals off, so resorted to a chemical affair and got them off.  Lots more sanding to go...
Used the Klean Strip aircraft paint stripper.
Edit to add the color I am going with:
https://www.66autocolor.com/products/house-of-kolor-k462-bermuda-triangle
Ordered decals from: https://cbdecals.afegraphics.com/view_product.php?adminshopping=&product=76cb550k-TNKT-CB00240
« Last Edit: April 01, 2024, 12:18:23 PM by denward17 »
Online Mark1976
« Reply #347 on: April 01, 2024, 12:51:04 PM »
   Stripper is the way to go, sanding gets old very quickly!!!
Offline denward17
« Reply #348 on: April 01, 2024, 06:40:28 PM »
Make sure when you paint the tank, leave the top of the filler neck bare metal. Fuel vapors will cause the paint to peel if you paint the rolled edge. Stop your paint on the outside, right at the bottom of the rolled edge. Your paint will last decades as a result.
Thanks for the tip, I was wondering about that.
Offline denward17
« Reply #349 on: April 02, 2024, 11:51:50 AM »
Finished stripping the paint, sanded with 100 grit and then 220 grit with palm sander.
Need to finish up going around the edges by hand, that can't wait another day or so.
Tried to use a c-clamp and a 6 penny nail to push the cap pin through, but the nail just bent , also need another pairs of hands to help hold.
