Author Topic: Another Dual Brake Conversion Question  (Read 556 times)
Offline MrOuija
« on: December 07, 2023, 07:52:53 AM »
Hello all,
I'm going to make this real quick, as I probably missed the answer during my searches.
Is there a left side/right side brake caliper mount bracket?
Thanks
Online scottly
Re: Another Dual Brake Conversion Question
« Reply #1 on: December 07, 2023, 09:23:37 AM »
Which bike? The K0-K2 750s needed different brackets for the right and left sides, but the K3-K7 brackets fit either side.
Offline MrOuija
« Reply #2 on: December 07, 2023, 09:26:27 AM »
Sorry about that, forgot to mention what I'm working on,
550K0
Online scottly
« Reply #3 on: December 07, 2023, 09:30:55 AM »
The 550 uses the same ambidextrous "T" brackets as the later 750Ks.
Offline MrOuija
« Reply #4 on: December 07, 2023, 09:32:03 AM »
K3-K7 it is, thank you.
« Reply #5 on: December 07, 2023, 09:51:59 AM »
It uses the same bracket BUT spacing/filing may be requiredon the mounting points to get the caliper in line with the disc, some do some dont.
Speedo drive plate can be adapted, check the many other posts.
Cheapest way to get caliper, bracket and pads is from mmatti on amazon
« Reply #6 on: December 07, 2023, 10:07:12 AM »
You also need the other pipe and longer bolts for the disc
Online Don R
« Reply #7 on: December 07, 2023, 10:34:17 AM »
 Actually, the 550 brake caliper brackets angle down for the smaller 550 rotor, they appear to be the same except for the angle. They are also reversable like the 750's.
« Reply #8 on: December 07, 2023, 11:52:33 AM »
It is a 550 and some do need a small amount of work depending on if Honda finish machine the slider, like i said some do some dont
