Author Topic: Looking for Gordon frame mod equivalent 1975 CB750f  (Read 4611 times)
Offline kingrabbit
  • Half-Assed Wrench
« on: June 02, 2024, 08:00:45 AM »
Hi
I want to access the valve train on my CB 750f but don’t want to pull the engine. Does anyone know who sells a kit to modify the frame? Gordon Frame Kit doesn’t seem to be available anymore.
Much appreciate any info.
Thanks
Don
'74 CB 550K
'75 CB 750F
'73 XLH 1000
Donny
Re: Looking for Gordon frame mod equivalent 1975 CB750f
« Reply #1 on: June 02, 2024, 10:54:27 AM »
I don't remember what the Gondon kit was like. Was it a weld in place bungs or clamp style like Frank and Scottly were making?
But Carpy's has a weld in frame kit
https://carpyscaferacers.com/shop/shop-our-store/motorcycle-parts-accessories/honda-cb500-cb550-cb750-parts-upgrades/frame-adapter-honda/
« Reply #2 on: June 02, 2024, 11:09:20 AM »
Check CycleX
« Reply #3 on: June 02, 2024, 11:14:29 AM »
Did you call RRRToolsolutions to see if they have the kits?
https://www.rrrtoolsolutions.com/honda-cb750-frame-kit.php
« Reply #4 on: June 02, 2024, 11:22:29 AM »
Or "Frank's Weldless" clamps that forum member scottly produced for a while when Frank stopped making them.
Offline bustech51
« Reply #5 on: June 02, 2024, 01:02:10 PM »
Carpys Cafe Racer in California makes a nice kit.  I have used both with no problems.
Sent from my SM-G950W using Tapatalk
Offline CB750R
  • 77 CB750F
« Reply #6 on: June 02, 2024, 01:40:36 PM »
I used the cycle-x kit. With its tube clamp style it’s not the easiest to remove/install the frame section but it works. It was 1000% easier to install my engine!
Online scottly
« Reply #7 on: June 02, 2024, 08:15:22 PM »
Yeah, the inter-locking style of the Cycle-X parts can make it more difficult to fit than the flat Carpy style, especially if the split is vertical instead of horizontal. Do either of them provide the straps and bolts for the triangle piece? The last run of weldless kits I did a whole bunch of straps while I had the machine set up for them, and I have a bunch left over, along with the bolts and nuts.
Offline spotty
« Reply #8 on: June 02, 2024, 09:07:29 PM »
didn't terry make some kits using old fork tubes split and drilled for the clamps ?
i blame Terry
Offline willbird
« Reply #9 on: June 03, 2024, 03:57:15 AM »
One nice thing about Frank's design is that one could use it NOW, then if later on you did a full frame up restore you could use a welded type then.
I have worked up some stuff to make my own but not actually cut my K3 frame yet.
The "keys" prevent the tension of the joint from only being handled by the bolts, but after much thinking driving to and from work and other idle cpu time I think that fit up may be really tough to weld in and have it fit nice. I was thinking about 1" round tube gussets to replce the stock bent flat steel too, but now thinking more like 3/4" flushed out to the outer tubes would be sufficient and nicer, even 1/2" may be sufficient really.
A simpler joint like this but longer like the other version is what I think I will use. There is a huge amount of "grab" in the flat surface using a 1/4" button head cap screw torqued properly so that in fact the tension IMHO is not only taken by the bolt.
Offline kingrabbit
  • Half-Assed Wrench
« Reply #10 on: June 03, 2024, 06:47:36 AM »
Great info friends. My CB has been sitting for two seasons cause I just don’t want the hassle of pulling that engine just to check the top end. I’m pretty sure my issue is a plugged oil gallery is starving the valves on number four. My plan is to pull the camshaft and clear the gallery. I’m being optimistic I know.
I will note the RRR page says about the Gordon kit:
NOTE: These as designed exclusively for the Honda CB750 K0 ~K8 series from 1969 ~ 1978.
My scoot’s an F. Will it still work?
I called and left a message for clarification.
I was on the CycleX page too and saw their kit. Looks good too. But I couldn’t find a video on YouTube about installing it.
'74 CB 550K
'75 CB 750F
'73 XLH 1000
Donny
Offline CB750R
  • 77 CB750F
« Reply #11 on: June 03, 2024, 07:26:26 AM »
Can’t see why it wouldn’t work on your F, I have a 77 F2 and the frame kit I purchased from cycle-x fit the I.D. of my frame tubes.
The Cycle-x kit didn’t include tabs to re attach the “triangle” I just used some flat bar, but having the welded nuts on the backside is a nice call!
« Reply #12 on: June 03, 2024, 10:32:52 AM »
Frank's kit good for an eventual future going back to stock, weld frame.
Only missing metal, the thickness of the saw blade, ca 2mm that will be a good fill for a welder.
Plus the holes in the triangle that must be an important part of the frame.
« Reply #13 on: June 04, 2024, 04:02:11 PM »
  My Hot Rod bike had been cut years ago and I actually used a Franks style kit to re-install the lower tubes from an F1 frame into a K1 frame. I had to re-weld on the top sections of the triangle also and then cut them in the middle for the bolt-ons.
« Reply #14 on: June 04, 2024, 10:17:44 PM »
I really like the ones in the top pic,on the wooden table;they look to be designed to lock-together good and solid  ;)
« Last Edit: June 04, 2024, 10:19:19 PM by grcamna2 »
Offline willbird
« Reply #15 on: June 05, 2024, 04:01:20 AM »
I only built in .005" slop of the keys in the keyways though, hindsight has me thinking welding them in will move things enough that .005" is not enough.
Bill
« Reply #16 on: June 05, 2024, 08:42:07 AM »
Bill
I suppose you would bolt them together tight first,then weld them?
Offline willbird
« Reply #17 on: June 05, 2024, 11:45:14 AM »
Bill
I think things will still shrink and move though. I think if you were selling them those keys would be a real lure to buyers ;-), but I still think that the joint clamped up with a 1/4-28 bolt torqued properly is not honestly putting the bolt in shear, the ends of the joints take care of compression forces.
« Reply #18 on: June 06, 2024, 02:06:51 PM »
 I just looked at the cycleX splices and really like the locking shape, in my opinion are way better than the flat surfaces bolted together. I think my Gordons kit had something that locks.
« Last Edit: April 30, 2025, 05:27:39 PM by Don R »
Offline Finnigan
« Reply #20 on: June 06, 2024, 11:18:20 PM »
I still have an unused kit from a member here that is still in the wrappings, I don't plan to use it and could offer it for good price
Offline willbird
« Reply #21 on: June 07, 2024, 03:59:26 AM »
I just looked at the cycleX splices and really like the locking shape, in my opinion are way better than the flat surfaces bolted together. I think my Gordons kid had something like that.
I have a half hour drive to and from work so ponder on all kinds of things, the frame kit is one such thing. The area IMHO is not highly stressed enough for the "good, best, and better" options may ALL work just fine really. I'm not fond of the erector set solutions to splicing the gussets, would prefer to totally remove them and make steel tube round gussets.
Bill
Offline kingrabbit
  • Half-Assed Wrench
« Reply #22 on: June 18, 2024, 03:02:41 PM »
Alright just got the Cycle X kit today. Exciting! My question is where exactly do I make my cuts?
'74 CB 550K
'75 CB 750F
'73 XLH 1000
Donny
Offline spotty
« Reply #23 on: June 18, 2024, 06:29:49 PM »
One option is to weld the bungs in, but make the “tube” from solid aluminum round bar. That piece you can cut after the welding process to ensure a proper fit-up. I bolted them together during the weld process to keep the alignment perfect. After welding, the smallest amount of sanding brought the fit in perfectly.
The weight difference is neglible, the strength is massive.
thats a nice version of this , how do you fix the attach to the top tube bits ?
i blame Terry
Online scottly
« Reply #24 on: June 18, 2024, 10:50:39 PM »
Just how much do those solid aluminum bars weigh?
