Author Topic: Which side plastic covers are interchangable with 1976 CB550F  (Read 1134 times)
Offline Vhonda
Looking for plastic replacement side covers for 1976 CB550F.
What model and years are interchangeable?
Thanks
73' CB500
76' CB550k
77' Yamaha 750
78' CB550k
Re: Which side plastic covers are interchangable with 1976 CB550F
« Reply #1 on: July 13, 2024, 10:15:35 PM »
Only way to be sure is look up part number at cmsnl then create a free account and it will tell you what bikes fit but from memory only 550F
Offline CycleRanger
  • No comment about being an
« Reply #2 on: July 13, 2024, 10:32:11 PM »
I'm pretty sure the side covers on the 550F are the same from 75-77 and are unique to the 550F.
There are lots of reproductions available if you can't find an original.
4into1 offers a set.
https://4into1.com/honda-cb550f-side-cover-set-1975-1977/
« Last Edit: July 13, 2024, 10:34:49 PM by CycleRanger »
« Reply #3 on: July 14, 2024, 02:53:10 AM »
According to Frankenstuff the 550F (Supersport) and the  77/78 550K models share the same sidecovers.
https://www.fb-stuff.com/fb-stuff-store.html
« Reply #4 on: July 14, 2024, 03:02:38 AM »
Thanks
550F Supersport? Or are you using 550F as a short for 550Four that is a 550K?(not a good thing with Honda in searching for specific parts that have model changes...I was a parts manager) and in this case, specific years changes the application. When you ask for parts include your full year and exact model so there isn't wrong part numbers or links given you and you blame the wrong person(remember, when you point your finger, there are 3 fingers pointing back to you...😐)
« Last Edit: July 14, 2024, 03:04:23 AM by newday777 »
Offline jonda500
« Reply #5 on: July 14, 2024, 05:40:08 AM »
The 77/78 K does not share the same sidecovers with the F, but the 77/78 K covers will fit the F.
John
A starter clutch thread:
Offline jlh3rd
« Reply #6 on: July 14, 2024, 06:22:42 AM »
To the OP:
knowing exactly what model you have is critical, as stated.
I have  no idea if the 77/78 "K" model side covers will "fit" an "F" model but regardless they are not the same shape. In my opinion, if an external part isn't the same shape, I probably don't want to spend the money for a part that doesn't look right. The pic shows '78 "K" model. see the curved front? So in my opinion, frankenstuff is wrong.
CMS is a good source for interchangeability. However, in this case, since the OEM part came as a specific color, this function doesn't work quite well. For example, a '76 "F" model side cover I know for a fact fits on a '75 "F" model. But CMS only shows it "fits" on '76 models, any country, only...because that color was only for '76 "F's".
point is, do  your due diligence when trying to source correct parts....beware the internet.
« Last Edit: July 14, 2024, 06:33:13 AM by jlh3rd »
Offline jlh3rd
« Reply #7 on: July 14, 2024, 06:39:07 AM »
I just saw your other post about the bike you purchased. From the picture, it appears you have a "K" model.
« Reply #8 on: July 14, 2024, 09:40:52 AM »
As said previous the picture in your other post is a CB550K and definately NOT AN F
Offline jonda500
« Reply #9 on: July 14, 2024, 06:11:00 PM »
I have a set of '77 550K covers - they most definitely do fit on my '75 550F - the side cover mounting tabs are the same on all 550F and 77/78 550K frames. John
Offline jlh3rd
« Reply #10 on: July 14, 2024, 07:05:31 PM »
hmm
cms shows the right side cover pins are different for a  '77K vs a'75 F....and oriented different
« Last Edit: July 14, 2024, 07:12:27 PM by jlh3rd »
Offline jlh3rd
« Reply #11 on: July 14, 2024, 07:10:46 PM »
and this rt side '77K fits where this '75 F's rt side cover fits?
Offline jonda500
« Reply #12 on: July 14, 2024, 08:25:44 PM »
That is not a 77/78 cover!
John
Offline jlh3rd
« Reply #13 on: July 15, 2024, 05:44:39 AM »
using your picks and these from CMS (1978 K)...the mounting post distance and angles do not match up!
Offline jonda500
« Reply #14 on: July 15, 2024, 06:32:19 PM »
The mounting post distance and angles are identical! John
Here's my F with a K cover fitted.
Offline jlh3rd
« Reply #15 on: July 16, 2024, 05:15:14 AM »
ok, picture is worth....
looks like a nice F.
Offline Vhonda
« Reply #16 on: July 16, 2024, 07:50:18 AM »
My apologies to the group for the confusion, thanks for your help.
I am also looking at a two CB550 Supersport.
« Last Edit: July 16, 2024, 07:53:05 AM by Vhonda »
73' CB500
76' CB550k
77' Yamaha 750
78' CB550k
Offline jlh3rd
« Reply #17 on: July 16, 2024, 03:52:28 PM »
my apologies.
Nice F's , it appears. paintwork appears good.
Offline jonda500
« Reply #18 on: July 16, 2024, 05:24:01 PM »
I have always wanted a 550 supersport and am jealous of your completely original F since I first saw it (and saved the pictures of it! -It is a valuable piece of treasure).  Your bike is my inspiration for putting together my F out of ebay parts from all over the world that have never before been on the same bike! I hope I end up getting it very close to looking like yours! John
Offline jlh3rd
« Reply #19 on: July 16, 2024, 06:51:36 PM »
eating humble pie...with foot in mouth..
If you need close ups for research, or questions about what is authentic for a '75 "F", please ask.
