Author Topic: American Land Master UTV.  (Read 35227 times)
Re: American Land Master UTV.
« Reply #125 on: December 20, 2025, 09:50:50 PM »
John, I saw the side wood 'fences' you made for it;that will help to have something to use to bungee large branches over the top also,when you need to.
« Reply #126 on: December 21, 2025, 07:19:26 AM »
Bill…… truthfully I had the table saw out and the leftover wood. Was looking for something to do with it and the UTV was sitting right there! That bin on the back had the six stake pockets and there was just enough wood. They need some sealer and red paint.
I suspect my wife will destroy them, next time she massively overloads the box. I did pick up a small 4’ X 4’ box trailer a few months ago(needs some work). This thing has an excellent hitch and will easily pull it around.
« Last Edit: December 21, 2025, 02:43:21 PM by BenelliSEI »
« Reply #127 on: December 21, 2025, 02:51:45 PM »
I like the amount of visibility I see in the picture,and seating position,etc.  ;)
« Reply #128 on: December 21, 2025, 08:31:48 PM »
Visibility is excellent, enhanced by a fold down wind screen. Initially I found the ride VERY stiff, until I dropped the tire pressures from 25 to 6-8 psi and it’s much improved!
« Last Edit: December 22, 2025, 06:34:54 AM by BenelliSEI »
« Reply #129 on: December 22, 2025, 10:08:32 AM »
Paint and done.
« Reply #130 on: December 22, 2025, 11:22:27 AM »
Paint and done.
I like the look of your completed Land MASTER John.  ;) :)
« Reply #131 on: December 22, 2025, 11:47:08 AM »
Bill…. We just took it about a kilometre across our backfields to the hiking trails on our neighbour’s 200 acres of woods. The load of fire wood in the back really improves the traction in deep snow. May have to keep it full all winter!
Online denward17
« Reply #132 on: December 22, 2025, 12:45:54 PM »
^John, I like the way you finished "trimming" it out with the red trim boards.
« Reply #133 on: December 22, 2025, 01:47:41 PM »
Happened to have 1/2 a can of that red and it worked out well! Looks better balanced with some colour out back.
That plastic box is bolted to an angle iron frame that has only two large “hinge” bolts about 2/3 of the way back. There is a spring loaded locking latch up front. Even with the weight of all that wood, it’s quite easy to flip down the tailgate and dump.
I have a pile of 1.25” steel tubing that I scrounged some time ago. Thinking the next project might be to weld up a larger “flatbed” style deck for moving around larger stuff……..
« Last Edit: December 22, 2025, 02:08:16 PM by BenelliSEI »
« Reply #134 on: December 22, 2025, 05:19:12 PM »
Will the plastic box be able to bolt-up to the new tube deck and dump;be nice to have the option for both.
« Reply #135 on: December 22, 2025, 07:26:55 PM »
The existing boxe unit comes off with two large bolts through the hinge points. I’ll make them interchangeable.
Offline dhall57
« Reply #136 on: December 28, 2025, 09:39:55 AM »
New muffler on the Landmaster.
« Last Edit: December 28, 2025, 09:42:24 AM by dhall57 »
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
« Reply #137 on: December 28, 2025, 10:42:50 AM »
Did it make it any quieter? Mine has a smaller unit (Subaru 650cc Twin) facing straight back, with a smaller spark arrestor can on the back. It looks to be in good shape, but I wish it was a bit less noisy.
Offline dhall57
« Reply #138 on: December 28, 2025, 11:57:07 AM »
It's quieter no doubt. The old muffler was broke in several places.
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
« Reply #139 on: December 28, 2025, 01:33:22 PM »
Well done. Mine is a standard can, about 1’ long and 10” in dia. I’m going to look for something about the same size and try an “upgrade”.
Offline dhall57
« Reply #140 on: December 28, 2025, 03:48:23 PM »
When I bought this from the rental company several years ago it had 2 different tire brands and tread patterns on it. The front were 4 ply and the rear 6 ply. I constantly had issues with side wall punctures so I purchased heavy duty 10 ply tires and so far no flats ;)
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
« Reply #141 on: December 28, 2025, 05:03:08 PM »
I’m sure mine is still on the O.E. tires. When I first got it they were at about 25 psi and the ride was brutal. I think I have them down to about 8 psi and the ride is much improved!!
« Reply #142 on: January 11, 2026, 11:42:41 AM »
Abused the LM650 all day. Dragged and chopped up a big old tree that came down near our entrance gate. Snow cover is crunchy and covered in ice, driveway is a skating rink. Lowered the tire pressures all around and it clambered everywhere I needed to go. Took me a while to solve the blocked fuel line problem, but it’s become a truly great addition to the work fleet. Despite very cold weather, it starts instantly on full choke and warms up quickly. In the spring I will treat it to a valve clearance adjustment……
Got finished just in time, it’s snowing again!
« Last Edit: January 11, 2026, 01:07:13 PM by BenelliSEI »
Offline Kelly E
  • Geriatric Hooligan
« Reply #143 on: January 12, 2026, 09:43:41 AM »
That's awesome, now I wish I had one instead of the 01' Honda TRX 350 Rancher I currently have.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #144 on: January 12, 2026, 10:10:26 AM »
John,does the interior have heat? if you installed some side panels to close it in ?
« Reply #145 on: January 12, 2026, 10:48:00 AM »
No…. They sell a curtain kit but no heat.
« Reply #146 on: January 12, 2026, 10:49:04 AM »
Yeah, but yours is a HONDA!
Online Stev-o
« Reply #147 on: January 13, 2026, 06:51:26 AM »
I'm now shopping for a Kawasaki Mule or similar that I can use to get down to the boat.
Edit...considering making an offer on this Polaris
« Last Edit: January 13, 2026, 07:26:49 AM by Stev-o »
« Reply #148 on: January 13, 2026, 09:19:51 AM »
Steve.... Nice looking machine. They are useful too.
« Last Edit: January 14, 2026, 02:43:11 PM by BenelliSEI »
