Author Topic: Biting off more than I can chew (1977 cb750)  (Read 6090 times)
Offline spotty
Re: Biting off more than I can chew (1977 cb750)
« Reply #25 on: December 02, 2024, 04:00:04 PM »
Everything going well. Brake, tail, turns, license plate and gauge backlights ready to go.
My low headlight bulb burned out though. It looks like it’s the original sealed headlight. Main beam work.
Does anyone know of an affordable beam I could plug in there?it’s the OEM shell and rim
go to ebay and get a modern 7" lens/reflector that takes a H4 halogen, much better light for the same electrical draw, just make sure it isn't one with a plastic lens, the H4 WILL melt it, or get a full LED unit that will go straight into your stock rim/bucket
i blame Terry
Offline Floshenbarnical
  • Money pit enjoyer
« Reply #26 on: December 02, 2024, 05:11:28 PM »
On DSS I found an after market h4 unit that comes with the bulb. It’s a plug n play for the cb750.
Is it going to melt my switch? Do I need a relay to be safe? It’s a 55/60w h4 bulb (removable)
'77 CB750 SS
Offline spotty
« Reply #27 on: December 03, 2024, 04:52:12 PM »
i used to have a 90/110 in my 750 back in the 90's and nothing fried
i blame Terry
Offline tctreppin
« Reply #28 on: December 03, 2024, 06:59:01 PM »
I’ll bear that in mind when I take care of that.
Another issue: all the reg/rec diagrams have 5 wires. Mine has 7. It’s one of Rick’s. Not sure where the extra wires go!
Once I bought the “Combination regulator Rectifier I bought one for EVERY 750 since!!
 Super easy to wire if u go that route I ll draw you a picture AND U WONT HAVE TO FIDDLE WITH SOME 50 yr old tech
Offline tctreppin
« Reply #29 on: December 03, 2024, 06:59:37 PM »
Yes, switched by the key.
Like this?
Ricks haven’t made my reg-rec in 10 years so the man on the phone drew a diagram:
Excatly
  • Money pit enjoyer
« Reply #30 on: December 04, 2024, 12:09:43 AM »
Like this?
Excatly
Thanks, brother
'77 CB750 SS
