Author Topic: Finally . . . the seized brake piston is unstuck  (Read 1869 times)
Online kyle750
« on: January 31, 2025, 06:52:59 PM »
This was my very first task with my Honda CB750 restoration and it took a long time. A very slow start.
When I bought the bike it had been sitting for 9 years and the brake piston was totally seized.  First we tried new brake fluid and pressure from the master cylinder - did not work. Then we tried carefully sealing and compressed air - did not work.  Then we tried the grease gun method at a car repair shop - did not work.  So . . .
I threw the brake caliper into a closed container of diesel (to try to loosen it up) and let it sit for a few weeks.  I then saw a very old machine shop that looks like it has been in business for a very long time.  Perhaps more experience and better tools?  I showed them the caliper with stuck piston and they immediately took a blowtorch to it.  Clamped the caliper to a heavy duty vise and then took heavy duty vise grips and pulled the piston out. It took over 15 minutes of heating and pulling before they finally got it out
The black paint was melted so I stripped both sides of the caliper down to the aluminum with regular paint stripper and a small brass wire brush.  Paint came off easily. Inside the caliper the cavity is now smooth and clean and the groove for the piston gasket ring has been cleaned very well.   I ordered a replacement stainless steel piston and piston gasket.
My question is what should I do with the caliper? Repaint black or can I just use as is?
I quite like the look of the silver aluminum of the brake caliper.
« Last Edit: January 31, 2025, 10:14:20 PM by kyle750 »
Re: Finally . . . the seized brake piston is unstuck
« Reply #1 on: January 31, 2025, 07:20:04 PM »
Early ones were alluminimum not black anyway
« Reply #2 on: February 01, 2025, 05:08:31 AM »
Given the way parts corrode in your environment, I’d paint it. Black is “original”, but silver works too!
« Reply #3 on: February 01, 2025, 08:18:52 AM »
I've used Duplicator caliper paint, it has a soft sheen and is supposed to be resistant to heat etc. Seems to work, not sure if you can find that there.
« Reply #4 on: February 01, 2025, 01:34:59 PM »
Any good quality paint works well. Careful with brake fluid. It will destroy virtually any coating!
Online kyle750
« Reply #5 on: February 01, 2025, 05:00:35 PM »
Thanks.  Caliper is just sitting here waiting to decide.  Corrosion is a big problem here.  I can get good quality heat resistant spray paint here (black or silver).
I'm continuing with the inspection of the brakes today.  Very surprised to find that the rotor seems to be in decent shape.  As is usual with almost everything with this bike the top edge of the rotor has rusted but the surface has stayed rust free.  Is the Honda CB750 rotor typical cast iron? Rotor does not appear to have any deep grooves but I'm not sure if it is OK to use?   It would be very easy to just sand the rust off the top edge so it looks better.
I have ordered both organic and semi-sintered EBC brake pads so I can test both and see how they perform.  Nobody likes squealing brakes.   As the Honda CB750 front brakes have a reputation for being adequate but not very good - the  stopping power and steadiness of the brakes is going to be VERY important to me.
As a rider I place Safety first - Always!
« Last Edit: February 01, 2025, 11:52:43 PM by kyle750 »
« Reply #6 on: February 01, 2025, 05:12:52 PM »
SOHC4 rotors were stainless steel, not ideal material
Online kyle750
« Reply #7 on: February 01, 2025, 05:17:50 PM »
Thanks mate.  I did not know the rotors were stainless steel.  With the rust on the top edge I am also wondering if they are not very high quality stainless steel??
« Reply #8 on: February 01, 2025, 05:30:41 PM »
Staining possibly. Scrape it off to see if it is stained or something dropped on edge or it is rust.
Online kyle750
« Reply #9 on: February 01, 2025, 06:53:53 PM »
WD-40 applied to the top edge and is soaking now
Online kyle750
« Reply #10 on: February 01, 2025, 07:30:59 PM »
Easy  :)
« Reply #11 on: February 01, 2025, 08:17:23 PM »
Also remove, clean and grease the pivot pin in the bracket the caliper bolts to
« Reply #12 on: February 01, 2025, 10:38:55 PM »
you can buy cast iron rotors for 750s and 500/550 here in Australia,i have one,just so much better,stainless has a crap frictional coefficient.
« Reply #13 on: February 02, 2025, 01:12:10 AM »
There are paints made for brake calipers.
I have a good looking caliper with a stuck piston.
Even the threads for pipe and bleeder valve had dried brake fluid. Hard as old 2k glue.
  • I'm back
« Reply #14 on: February 02, 2025, 02:22:44 AM »
Mine is partly black because of scars from accidents and I'm proud. ;D
« Reply #15 on: February 02, 2025, 06:45:48 AM »
Some get their discs drilled (I did), I won't speculate on the pros and cons but it does remove a little weight and might aid in water shedding. I like the look. Otherwise, just carefully remove any stains, iron discs in your area will turn to rusty discs right away.
Online kyle750
« Reply #16 on: February 02, 2025, 07:15:43 AM »
I should not be surprised to learn the brake rotor is made of stainless steel.  Seeing how the other metal parts on this bike rusted if the rotor was cast iron it would have turned to a heap of rust.  For where I live in a hot and humid country and living near the ocean a stainless steel rotor would be the better choice. Perhaps not the best stopping power but definitely less corrosive.
For now I think I will keep the original Stainless Steel rotor and see how the pads respond. My expectations for safe stopping and performance are very low. The disc pad is just too small for such a heavy and powerful bike.   Who knows maybe the front brakes will work  a little better than I am expecting!  I hope to find out soon.
Late Edit:  The back drum brake on the CB750 is working extremely well. Quick response and strong stopping power.  Very pleased!
« Last Edit: February 02, 2025, 07:25:05 AM by kyle750 »
« Reply #17 on: February 02, 2025, 08:10:50 AM »
Dave…. I’m thinking of ordering one of those discs. Significant improvement?
« Reply #18 on: February 02, 2025, 10:05:12 AM »
I fitted one to a 500 back in the 70's, great in the dry but worked too well in the wet, brake locked and threw me off
« Reply #19 on: February 02, 2025, 11:56:15 AM »
Honda was early with an anti-lock braking system ;)
Wet slippery roads have tought me to take it extra easy.
Roundabouts close to gas stations were often extra slippery rainy days due to splashing diesel from just filled up trucks/lorries. I learned the hard way.
« Last Edit: February 03, 2025, 01:24:54 AM by PeWe »
Offline Tim2005
« Reply #20 on: February 02, 2025, 12:48:30 PM »
Any chance they do them for CB400Fs too?
Online kyle750
« Reply #21 on: February 02, 2025, 07:31:17 PM »
The delivery of the brake parts and front fork seals from the USA has been held up in customs. Most shipments sail right through and get delivered quickly.  But sometimes packages are randomly selected and the shipper must confirm the value of goods.
From past experience once a shipment is held up in customs it takes a long time to clear (sometimes up to a month).
Frustrating
« Reply #22 on: February 03, 2025, 12:00:30 AM »
with a smaller diameter master cylinder it works great it actually gets better as it gets hot,not visa versa like the stainless one,heres a link,they do drilled or solid,with hub or fit your own etc.https://www.ebay.com.au/itm/273994779212?chn=ps&_ul=AU&norover=1&mkevt=1&mkrid=705-139619-5960-0&mkcid=2&mkscid=101&itemid=273994779212&targetid=2370955762951&device=c&mktype=pla&googleloc=1000339&poi=&campaignid=21766114506&mkgroupid=168279963077&rlsatarget=pla-2370955762951&abcId=10047372&merchantid=7364522&gad_source=1&gclid=EAIaIQobChMIzZLh_YSniwMVPKNmAh0dQAbeEAQYASABEgKn6fD_BwE
« Last Edit: February 03, 2025, 12:04:50 AM by dave500 »
Online kyle750
« Reply #23 on: February 03, 2025, 12:47:17 AM »
The cast iron rotors look very good. Thanks for the link.  At a price of AU $150.00 plus AU $70.00 shipping = AU $220.00 total.  With currency conversion to $USD = Total $USD 135.00
Offline rotortiller
« Reply #24 on: February 03, 2025, 05:01:19 AM »
Lots of bikes with SS discs that stop very well. It is the whole cake mix that works, when the recipe gets messed up we pick something to blame. Back in the seventies they were just learning about disc brakes, pad surface area, disc material and area, fluid pressure etc. Today you can have a bike with a single front SS disc lift the back end off the ground.  Unfortunately the SOHC fork lower design is not very conducive to caliper improvements.  A 5000 pound car uses two cast iron front discs to stop, so a well designed SS disc should have a very easy job with a 500 pound bike. Now if the recipe is incorrect the results will be bad. I do not like rust so I look at other areas for braking improvement like calipers and master cylinders when possible. If all else fails the cast iron disc seems like a good idea for me. I have had good results increasing the brake line pressure, there is the option for the slightly larger 77/78 caliper for braking assistance. What truly amazes me is how much stress front spores can transfer during hard braking.
