Author Topic: 086A carb choke flappers  (Read 1616 times)
« on: February 15, 2025, 11:31:41 AM »
Well today I started teardown of AlanF's 086A carbs to clean them. Whoa!! What's this me says.....
Not only are the main jets plastic 115, the choke plates have 3 of them busted 1/2 gone....what the heck??
Anyone else run into either?
Good thing I have some parts carbs.
Re: 086A carb choke flappers
« Reply #1 on: February 15, 2025, 11:35:51 AM »
I texted with Alan, they are carbs he bought off ebay, the po said he was having a hard time getting the bike to run right for a year, finally bought some manifold tube and a Harley carb to put on it.
Definitely one those head scratchers, some people have no idea or else they shouldn't be given tools! 🤔
« Reply #2 on: February 15, 2025, 12:40:26 PM »
Makes me think some tool kits should come with mandatory boxing gloves
« Reply #3 on: February 15, 2025, 12:52:25 PM »
Plastic mainjets? Wow!
I wonder if someone was trying to prevent the damage from MTBE? It ate on the brass ones, usually if the bike got fresh 1990s (USA) gas and was then parked for the winter - which became a decade or more.
But, it doesn't reach up to the choke butterfly!
« Reply #4 on: February 15, 2025, 12:59:13 PM »
I think it was the po doing it thinking it would run better....
« Reply #5 on: February 15, 2025, 01:06:50 PM »
And these were screwed into the vacuum ports. Yup holes straight through to the atmosphere.....makes me wonder if maybe there were rubber plug caps over them to remove when doing a syncing of the carbs?¿¿
Offline Alan F.
« Reply #6 on: February 15, 2025, 04:16:12 PM »
I took a look through my notes and found this from 2006: On ebay, I picked up a nice set of carbs for my K3, the owner claimed to have taken them off of his K4 in 76 in favor of a single carb setup. These carbs got drained and blown out, wrapped in newspaper and shoved in a box on a closet shelf. Got them for  $80 or so shipped.
« Reply #7 on: February 15, 2025, 04:19:53 PM »
Nylon(plastic) main jets were a thing back in late 70's, way cheaper than brass if you were messing about with an "altered" motor
« Reply #8 on: February 15, 2025, 04:20:15 PM »
Well the 086A came on the K6 so he might have given you the wrong model they were off of.
« Reply #9 on: February 15, 2025, 04:22:12 PM »
That must have been after I left being parts manager,  after the fall of 77 as I don't remember them being available.
Online scottly
« Reply #10 on: February 15, 2025, 05:35:33 PM »
Stu, any markings on the jets?
« Reply #11 on: February 15, 2025, 05:40:39 PM »
Only 115 Scott
Offline jonda500
« Reply #12 on: February 15, 2025, 07:28:40 PM »
My chromed 750 round top carbs that came on my 550K purchased in the eighties had plastic main jets!
John
A starter clutch thread:
« Reply #13 on: February 15, 2025, 07:36:12 PM »
I think those plastic jets were a thing that came in aftermarket re-jet kit for pods and/or pipe, like Dynojet...only it was a different company.
I ran across a set in my 1986 GSXR...they seem to work and hold up as good as brass aftermarket jets.
« Last Edit: February 15, 2025, 07:37:47 PM by seanbarney41 »
Offline denward17
« Reply #14 on: February 15, 2025, 07:58:37 PM »
I remember getting some of the plastic jets while trying to tune my 900 z1b back in the late 70's.
Had just built it with a MTC 1015cc kit w/cams and installed 29mm carbs, I ordered quite a few jets, and some came in the plastic variety.
IIR, I used a set while tuning, but eventually got brass to replace them.  I remember they worked fine, for as long as I used them.
I think I still have some z1 jets and needles in my tool box.
« Reply #15 on: February 15, 2025, 08:28:55 PM »
OK that'll help knowing that they might work OK.
« Reply #16 on: February 15, 2025, 11:44:19 PM »
I had a  few white nylon main jets early 80's. They were cheaper and worked fine. I think it was Dynojet brand.
Had nylon rear sprocket too.
« Reply #17 on: February 16, 2025, 03:27:25 AM »
Yes I had 1 nylon rear sprocket back in the late 70s, but if I remember correctly it didn't last long enough for my traveling across the country, or the chain didn't last? Too foggy brain to be sure.
I kept the bike running properly and I had an assortment of stock brass jet sizes that I carried to change out depending on the elevation and how it was running.
« Last Edit: February 16, 2025, 03:32:52 AM by newday777 »
« Reply #18 on: February 16, 2025, 04:25:51 AM »
My brain is also foggy about the nylon sprocket. Probably not that good as it "should".
« Reply #19 on: February 16, 2025, 05:47:14 AM »
Those choke plates broken like that are different! Never seen that before.
« Reply #20 on: February 24, 2025, 01:42:24 PM »
Would you believe it?
Today cleaning another set of 086A carbs, what did I find???
#1 & #4 plates are totally MIA......
