Any clutch modification, Mike?
Replace the primary Cush drive pieces. Transmission is a very low mileage F2 undercut by Fast By Gast. The original style HD primary chains from Germany. I'll probably have the basket unit balanced as well.
- No mods for better grip, less prone to slip?
I think my engine should cause clutch slip with 6-7mm longer stroke.
Dyno runs at 105-107.5whp, 68.5 ft lbs torque.
My K6 has got the late clutch from an F2 with double metal plate, glass beaded metal plates. EBC fibers, the heavier black Barnett springs middle number -66-.
I changed front sprocket to 18 from 17. Clutch gave up at next dyno run a day later. I could verify the most important needle change though.
Bike behaved not as fun on stock 18-48 as 17-48. Noticed when passing a queue of cars. I had to gear down for a quick pass when earlier not.
New EBC fibers and fresh glass beaded metal discs back in. 17-48 sprockets. This was late 2024.
My slow going engine project that has the upper case milled for the billet block has a good stock crank.
Later undercutted transmission 2-5, final shaft is from a K2-K6 trans, the gear part of the late K7 trans.
Gear 4 and 5 will rev a little more with late transmission compared to K6
Super rods.
I have a new Megacycle 125-70 on the shelf. Standard rocker arms.
It would be nice with a balanced stroker crank with rods.
This might be another thing. My K6 has one
https://good-bits.co.uk/product/cb750-sohc-clutch-actuating-hub/I do no not like how fast they years passing by.
Winter rest (waste) of 5-6 months every year start to be stressful. Riding half life only.
