Author Topic: O Ring source for fuel use-petcock-CB550K  (Read 2829 times)
Online denward17
« on: April 23, 2025, 03:55:06 PM »
My 550 fuel petcock started leaking around the handle, so I ordered a new petcock from 4into1.  Not my regular vendor choice but the only one I could find.
Guess what, the new one leaks in the same area.
I took my old one apart, simple device.  It has a 2mm X 19mm o ring behind the petcock handle that swivels from on/off/res.  I assume that is the reason it is leaking.
Online I found the oringstore and put in an order for 2mm X 19mm, 2.5mm X 19mm and 2.4mm x 18.6mm.  These were the closest that I could find, will decide which one to use if I ever get them, they are back ordered.
Does anyone have a good source for metric o rings?
Re: O Ring source for fuel use-petcock-CB550K
« Reply #1 on: April 23, 2025, 05:27:30 PM »
Honda sells a petcock rebuild kit for those bikes, if it has the OEM petcock: #16952-341-671
(Also in Chapter IV, Page 13. :D ).
Online denward17
« Reply #2 on: April 23, 2025, 07:23:49 PM »
I'll check my new book  ;)
But looking at SSH parts fiche, it indicates the body and the whole petcock is no longer available, and you cannot buy a rebuild kit for the body.
Part #4 highlighted in pic., with the o ring I need in yellow.
16951-374-671
BODY SET, PETCOCK (NOT AVAILABLE)
« Reply #3 on: April 24, 2025, 08:11:10 PM »
I found a kit on eBay:
https://www.ebay.com/itm/226233476688
It might be discontinued again, but there's a zillion of them out there. With Honda's parts, whenever the last 3 digits become -670 (or nearly anything "6xx") it indicates that Honda has stopped stocking it (again) and it has been turned out to the vendors who made it for them. This is when we can often find them "out there", just not at Honda's dealers.
I think this petcock kit has been on-off for years. ;)
Offline Kevin D
  • SE Michigan
« Reply #4 on: April 25, 2025, 05:16:41 AM »
That’s good to know.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Online denward17
« Reply #5 on: April 25, 2025, 05:43:38 AM »
Thanks for the info Mark, but that's the wrong part.
« Reply #6 on: April 25, 2025, 11:00:37 AM »
Hmm..those are the only seals in the petcock: the rest of the body is a valve. If the valve itself is leaking, the whole petcock must be replaced, which must be where you started?
The Zamac body and spigot (the part with the lever on it) was cast and made as one unit. Then the other seals were added, going up to the tank. MTBE ate at the Zamac during those years when it was in our gasolines, making the surfaces irregular and not smooth and straight. Then, yeah, they weep fuel afterwards.
Then you ARE stuck with finding a new petcock. :(
Our modern fuels are not a lot better: this is why I advocate for adding some oil to the fuel, which helps a lot to neutralize the non-gasoline effects on the metals. Just one example from Denver, CO: there is butane (or was, from October 1 until March 31 and then however long it takes to deplete the gas station's tanks) in our fuel now, and it dries out and cracks any rubber line in the fuel system. Then, as soon as it moves for any reason, it weeps gas, with the usual results, fires, etc. So, I have ceased riding my own 750 between those dates, as I got tired of replacing the fuel hoses every stinking year because of it. Oil in the gas greatly reduces the effect, but it still removes the flexibility from the hose itself in just one season, turning them into a soft plastic that breaks when flexed 180 degrees.
Online denward17
« Reply #7 on: April 25, 2025, 11:42:33 AM »
Here is the o ring I am referring to.......finger point...
Offline CycleRanger
  • No comment about being an
« Reply #8 on: April 25, 2025, 03:13:05 PM »
Online denward17
« Reply #9 on: April 25, 2025, 03:40:43 PM »
Offline CycleRanger
« Reply #10 on: April 25, 2025, 04:48:54 PM »
Maybe this?
https://www.ebay.com/itm/235100962638
That's it, just purchased.  Thanks CycleRanger!
You're welcome. Pictures were helpful! I hope that cures your issue.
That petcock reminds me a lot like the ones on my XS650 with that cone-shaped stopper, for which kits are available.
I wonder if the o-ring is the same size.
« Reply #11 on: April 25, 2025, 04:52:38 PM »
That's the oring I  was looking for here in my thread on it
http://forums.sohc4.net/index.php?topic=196218.new;topicseen#new
« Last Edit: April 25, 2025, 05:03:24 PM by newday777 »
Online denward17
« Reply #12 on: April 25, 2025, 05:02:26 PM »
^Did you find one Stu?
« Reply #13 on: April 25, 2025, 05:08:56 PM »
Well not back in January but just ordered a couple from cycleranger's link thanks
« Reply #14 on: April 25, 2025, 07:15:29 PM »
Ah, I see: does the 2x18mm size fit that face seal? If it does, I'll order up a batch of them at Rocket so we can get them without spending $20 each for them.
« Last Edit: April 26, 2025, 10:25:00 AM by HondaMan »
Offline CycleRanger
« Reply #15 on: April 25, 2025, 08:29:04 PM »
I missed your thread, sorry.  :)
« Reply #16 on: April 26, 2025, 04:40:08 AM »
Does the 2x18mm size fit that face seal? If it does, I'll order up a batch of them at Rocket so we can get them without spending $20 each for them.
I don't think I have a 2x18mm to try. Yet anyhow.
I did order the ones from cycleranger's ebay link and will measure when it arrives.
« Last Edit: April 26, 2025, 04:41:49 AM by newday777 »
« Reply #17 on: April 26, 2025, 04:44:07 AM »
No problem. The bikes were off the road for winter anyhow and I was going through those petcocks
Offline ClawSS
« Reply #18 on: April 29, 2025, 07:19:26 PM »
What octane or type of fuel do you recommend running? (Book arrives Friday btw) I have access to pretty much all types here in Northern Kentucky including ethanol free, E85, U88 (E15). I would assume ethanol free, but I am unsure.
Stupider follow-up question, you recommend putting some oil in the gas to reduce degradation of rubber fuel components, is this the same as the engine oil and what are the measurements of oil to fuel. For example, per fill up are you giving it a "snort" or "drop" or are you tracking it in detail to like 50 parts gas to 1 part oil ratio? 😂
« Last Edit: May 01, 2025, 05:39:36 AM by ClawSS »
Online denward17
« Reply #19 on: April 29, 2025, 07:45:05 PM »
^I use ethanol free 89 octane, and add about 1/2 teaspoon of 2 stroke oil per tank of gas.
« Reply #20 on: April 29, 2025, 07:59:27 PM »
You will need to fix those connections.
I use regular pump gas 87 octane and add 2 oz of 2 stroke oil to a tank of gas.
« Reply #21 on: April 30, 2025, 08:25:52 AM »
^I use ethanol free....
+1...ethanol free
« Reply #22 on: April 30, 2025, 06:49:51 PM »
^^ What he said...
I use the old oil I drained from my last oil change, or else the 2-stroker oil (sometimes even the synthetic kind). Here in Colorado in particular, lots of old-time bike are getting it now as word started going 'round about it last year when we got stuck with extra butane in the gas here. It really helps, and slows down the carb's drying out over the winter, we've discovered. Nice side effect. :)
« Reply #23 on: April 30, 2025, 08:32:54 PM »
Following
Online denward17
« Reply #24 on: May 01, 2025, 09:37:01 AM »
Got my o ring today from Ebay seller listed above.
Best I can tell, it measured 1.7mm x 19mm.  I put my petcock together with it, won't be able to test until next week.
