Author Topic: Norris D5 Cam  (Read 1805 times)
Offline PimpPinto
Norris D5 Cam
« on: June 08, 2025, 05:00:15 PM »
Hey everyone,
I recently picked up a mystery camshaft as part of a package deal. The only marking on it is Norris Cycle D5.” From what I've gathered, Norris may have some connection to Megacycle, but beyond that, I haven't been able to dig up much information. Following megacycles guide I believe the cam lifts would be around .324 and .283. Someone said the rocker ratio means you have to multiply that by 1.2 for the valve lifts, so somewhere around .39 and .34.
Has anyone here come across this cam or know anything about it?
Re: Norris D5 Cam
« Reply #1 on: June 10, 2025, 09:23:48 AM »
Here's the card for a Norris D cam; not sure if it's the same cam? Note that it lists net valve lift in one place, and lobe lift in another.
« Last Edit: June 10, 2025, 09:27:00 AM by scottly »
Offline willbird
Re: Norris D5 Cam
« Reply #2 on: June 10, 2025, 05:15:28 PM »
What is "lifter checking clearance" referring to ??
Bill
Re: Norris D5 Cam
« Reply #3 on: June 12, 2025, 01:07:32 PM »
Those look like Kenny Harmon cam numbers especially the duration on the exhaust cam.....valve is open a long time. Grind # also has an H in front of it. I also notice the ubiquitous 105LC.
Re: Norris D5 Cam
« Reply #4 on: June 12, 2025, 04:50:18 PM »
 I bet he's right ^ Kenny Harmon made cams with long exhaust duration for endurance racing. I have a KH-F cam in an 836 that's way short on compression for that cam. It needs the Honda F2 cam that was in it before.
Re: Norris D5 Cam
« Reply #5 on: June 12, 2025, 05:57:44 PM »
just tried to go to Satanic Mechanic website to look up old cam specs and it seems to not be working anymore...that is a tremendous resource lost.
Re: Norris D5 Cam
« Reply #6 on: June 12, 2025, 06:56:27 PM »
The Satanic Mechanic site still works for me:
http://www.satanicmechanic.org/index.shtml
Offline PimpPinto
Re: Norris D5 Cam
« Reply #7 on: June 13, 2025, 07:44:38 AM »
Thank you all for the responses :). What sort of compression would I need to run to get good use of this cam? (I'm already porting the head).
Re: Norris D5 Cam
« Reply #8 on: June 13, 2025, 10:56:55 AM »
10.5....probably more like 11. Problem is that exhaust duration. It will suck a lot of intake charge out into the exhaust and it kills compression. As Rob Muzzy once said...."I've never seen an engine make power with the valves open." I've never been a fan of long duration cams except for LSR stuff but hey....try it. You can always change it for something else. ;)
