Author Topic: Possibly a new drag bike build. Maybe??  (Read 5072 times)
Re: Possibly a new drag bike build. Maybe??
« Reply #25 on: October 29, 2025, 09:20:26 PM »
Hey Frank, your name came up today, I was talking to Ken at Cyclex about some rods. The ones I asked about were sold but he said he still had some of the ones that you use. He was going to check stock but I haven't heard back yet.
I hope i didn't get beat up to much during that conversation. Lol. I owe Kenny a call from over a month ago.
I'm sure he's referring to the 1st generation of his super rods. I have them in the low 10 second mono shock bike with the 72mm(1030cc) top end. I'd certainly recommend them. In my opinion the best bang for the price. Well, maybe I shouldn't say bang in this case because I'm not trying to blow up an engine🤣😂. I'm glad you said he may have more rods stored away somewhere because i may need a set should I pursue a big motor build for this rat rod project. Eventhough the goal is to spend as little money as possible on the overall build, I'd definitely want to at least put together the strongest bottom end as possible without breaking the bank. I'm not comfortable buying high dollar Carillos for a low 10 or maybe high 9 second SOHC. Decent rods and a good balanced crank are all i need. I'll wholeheartedly endorse this product. One day i intend to push these rods to the limit with a healthy boost of nitrous oxide exerting a dose of pressure from the top end.
If you talk to Kenny again soon, ask him to set aside a set of those rods for me!!
Frank
Are the CycleX Super rods that I have on the right the early  rods you are talking about?
The left set are RC shot peened rods that I also picked up a couple years ago.
« Reply #26 on: October 29, 2025, 10:46:25 PM »
  Ken thought you were giving his rods a really good test. I had my heart set on a lightly used set of Carillos with coated green bearings. The problem was they were sold, as are all of the newer design rods. I just want a good rod under the billet cylinder Mike's making, I'm sure the first design rods are fine, especially with my old man riding habits. I didn't get a call back today, so I guess it's my turn to call again.
Offline dragracer
  • CB750F Dragbike
« Reply #27 on: October 29, 2025, 11:24:50 PM »
Frank
Yes. The rods on the right are the ones I have in my mono shock bike right now. Nothing fancy, but they work. Be sure you have the upgrade ARP rod bolts. I had Kenny to install them for me prior to shipping.
By the way, the RC  rods you have on the left are what's in my F3 motor. I've been racing that bike for the last 30 years with that same part. Regular maintenance is key. I'm way past due for a tear down and new bearings in that 1030cc engine.
Offline dragracer
  • CB750F Dragbike
« Reply #28 on: October 29, 2025, 11:32:44 PM »
Those rods should hold anything I'd ever throw at them. Its important to keep an idea on bearing wear and freshen up the complete engine regularly for longevity. Of course you know that from racing your comp dragster. I'm hoping Kenny has several sets of those rods left so both you and I can snag a pair. While I'd love to have a set of Carillos, I don't believe I'll ever build an engine powerful enough to exceed the strength of the CycleX  rods. A fully balanced rotating assembly is  the main key to longevity.
« Reply #29 on: October 30, 2025, 03:56:51 PM »
 Ken said he could take care of what you need when you are ready, I called dibbs on a set of the original CycleX rods. He checked the big ends on them to be sure they were up to his tolerances. I'm calling tomorrow to talk about working on the cases.
« Last Edit: October 30, 2025, 04:03:15 PM by Don R »
Offline dragracer
  • CB750F Dragbike
« Reply #30 on: October 30, 2025, 07:05:17 PM »
Thanks for letting him know. I'll contact him soon. Right now I just want to focus on the chassis setup. I've got to get my hands on a complete front end and a stock front wheel/axle. I'll have to locate an 18" aluminum rim band and spokes for it also. I hope Kenny still has some n.o.s. laying around.  I don't see wheels or forks listed on his site anymore. I could install a set of PM Chicanes or something equivalent but the old school spoke are what I'd prefer on this build just to retain the nostalgia theme.
Offline dragracer
  • CB750F Dragbike
« Reply #31 on: November 03, 2025, 10:56:33 PM »
The new steel  tank and small cafe fairing arrived via FedEx  today. I did a quick mock up to see how the lines flowed. I kind of like the slimmer tank but it doesn't fit perfectly in the rear as it more narrow than the frame- I can live with it though. A big problem is the location of the petcock bung. It falls exactly in line with the daggum frame rail. I've got several ideas on how to get around that issue. One entails relocating the bung to the rear of the tank . The other is to modify that frame rail inward in that spot since I'll be putting in a removable kit anyway. Last resort is to go old school and just cut the rails out completely. Definitely not my preference for a dragbike.
The cheap little café fairing had some brackets included so I drilled holes in the headlight ears just to see how it might fit. I didn't like the forward position so I'll probably trim the lower part of the fairing so I can move it back towards the handle bars about 3-4 ". Unfortunately trimming that much away will remove the lower area where the fairing bracket bolts up. No harm there really because i can always drill new holes, cut the provided bracket in half and find a new spot to bolt it onto the headlight ears. I'll fabricate a lexan plate and mold it into the headlight opening then get a headlight decal from Summit Racing and stick it onto the lexan to mimic a sealed beam light.
One of my dilemmas will be the fork length. As you can see, the tube i about 5-6"above the triple tree now. I had to slide them up to get my preferred ride height. Even by internally lowering the forks, I likely won't be able to achieve a minus 6" length difference without loosing all travel. Rigid is not good. The last build i did on the mono shock bike required a short fork tube as well. Kenny at Cyclex accommodated me by custom making a set of fork tubes to my specs. Hopefully I can lean on him to help me out again. I won't be using this front end or wheel anyway. I'm on the hunt for a complete replacement set up with lowers, tube and triple trees with an axle and possibly spacers. I want to put a single disc spoke wheel on the bike with an aluminum ban. To get my body positioned correctly, the handle bars will need to be in front of the forks. I'm going to weld up a set myself for now and then get a chassis builder to use it as an example for a professionally built set. I'm not a trained welder but can do just enough to get myself in lots of trouble. Lol.
This weekend coming I may move forward with the fiberglass work for the tail piece. I ordered the release agents but need to get some fresh resin and hardener along with fiberglass matting or mesh.
I'm going to slowly move this project forward.
« Last Edit: November 03, 2025, 11:17:43 PM by dragracer »
Offline dragracer
  • CB750F Dragbike
« Reply #32 on: November 03, 2025, 11:03:04 PM »
Its going to be ugly. Don't let it hurt your eyes to much. Haha.
I'm not going to spend much time on bling with this one. I need function on a tight budget.
Offline dragracer
  • CB750F Dragbike
« Reply #33 on: November 03, 2025, 11:05:54 PM »
The fairing definitely needs to be moved back closer to the handle bars.
Offline dragracer
  • CB750F Dragbike
« Reply #34 on: November 03, 2025, 11:09:21 PM »
I hope that fairing eventually grows on me. Its going to be used regardless 😝🤪
Offline dusterdude
« Reply #35 on: November 04, 2025, 01:49:23 AM »
Looks good frank
Sent from my SM-S711U using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline dragracer
  • CB750F Dragbike
« Reply #36 on: November 04, 2025, 06:50:17 PM »
Looks good frank
Mark.
It's just a crazy project with very little rhyme or reason.
Hopefully I can eventually dress this pig up with some lip stick when I'm done. Hahaha 😆
Motorcycle rich and cash poor.
Offline dusterdude
« Reply #37 on: November 05, 2025, 12:41:57 AM »
Thats a never ending condition
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
