Sure the valve reliefs have same size?
If one is a little wider, it is for the IN valve.
Can be a good idea to orient them as they sat.
They have been used and married to the bores with scuff marks in one way.
They look like they are not much used.
Piston look like grinded a little.
This to balance the weight.
Have you neasured the cam lift?
Nir exact, but close.
Total lobe measurent - base circle
If closer to 0.400" lift or more
Ex can have a little lower lift
