If you just got the bike, then you have made a good start. You will have to check your carbs completely.
Remove them and then dis-assemble them from each other or at least pull of 1 and 4 and all the tubes.
Clean everything, everything, make sure to pull the accel pump on #2 off and clean it and check for tears in the diaphragm.
Clean out all passagesways with some soft wire and carb spray, dont worry about compressed air right now. Pull the jets, all of them, even the mains. Clean all areas inside the jet housings. Pull of the tops and remove the slides. clean those and the bores.
Then pull the fuel screws and clean those. Watch out for the screw, spring, and washer and oring in there.
Pull the floats and valves. Clean the pivots and valves and the valve seats. Put them back on and measure at the middle of the float from the side, 14-15MM. When doing this, observe the valves, there are little pins there, these must NOT be pushed in, so you hold the carbs at an angle just so the valves close but not push in the pins.
Put it all back together. make your bench sync so all 4 slides are even. Set you fuel screws to 1.5 turns out. Check your boots for cuts or splits. Remount carbs and check for any gaps in the boots. Put on the upper part of the airbox and then the filter and bottom. If you use an uni or K&N filter, turn the fuel screws to 1.75 turns out. If pods, start at 1.75 but be prepared to turn out more.
OUT is RICHER and IN is LEANER.
Make sure timing is on, should be pretty easy with a dyna. make sure battery is fully charged and have at er. You should start pretty easy with choke and be able to drop it after a minute of 2 if the air is warm.
