Author Topic: Battery relocation  (Read 9249 times)
Offline mmtsquid
Battery relocation
« on: June 22, 2007, 05:23:09 AM »
I've seen several bikes on here with the battery and electronics moved to hidden locations, and was just wondering where they hide those things?
77 CB550K4
Offline Gordon
  • 750K1, 550K2
Re: Battery relocation
« Reply #1 on: June 22, 2007, 05:59:51 AM »
I'm guessing most of the bikes you're talking about have solo seats with a raised section (cowling) at the back.  That's typically where the battery and other electronics are stashed.  Smaller AGM or gel batteries are often used because they can be laid on their sides to fit smaller spaces.
Offline Roach Carver
« Reply #2 on: June 22, 2007, 06:34:32 AM »
that is what i did with mine. It is still a bit tight for me but hopefully it doesnt rub.
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #3 on: June 22, 2007, 07:59:24 AM »
I believe most people move their batteries and electrics to obtain a "no sidecover" look, like I did on my CB450...
Offline neil young
  • striving to be an
« Reply #4 on: June 22, 2007, 09:04:44 AM »
nice bike proteal but where is the battery(show me) >:(
1972 CB500 k1
1974 CB550
1977 cb 550
2008 Triumph Scrambler
scratch
« Reply #5 on: June 27, 2007, 01:48:03 PM »
What type of battery did you use? The make and model number. Will this power the started, headlights and signals??
Thanks
Offline ProTeal55
  • Est1968.com
« Reply #6 on: June 27, 2007, 03:35:03 PM »
The battery resides under the cafe "hump", with all the electrics mounted under the seat pan we made--->
The battery in the pic above has sience be changed out to a sealed unit from a Honda 919 Sportbike. The other battery didnt have enough "umph" to get the starter to spin..
Offline ProTeal55
  • Est1968.com
« Reply #7 on: June 27, 2007, 03:37:55 PM »
P.S-->
The CB450 is running a headlite-two 1157 bulbs for running/brake - a small LED stip above my license plate - and the electric starter. No horn, no turn signals, no gauge lights, etc...
scratch
« Reply #8 on: June 28, 2007, 07:16:28 AM »
Thanks for the response. I have actually seen your build - very cool! I am doing the same with a 76 Cb550 four. I am planning on relocating my battery under the seat as well. I am up in Canada, so I am going to be running the headlight, turn signals, gauge and my signals are single filament. I have been talking to a guy at GS Batteries and he reccomended this battery 14AHBS Premium
Sealed AGM battery (http://www.gsbattery.com/) but did not reccomend mounting it on its side - just strraight up. Anyway I was hoping to get some idea from someone who is doing the same as me, - it seems people have reccomended batteries and then changed them after testing.
Offline forwheeldrift
  • 1972 cb 500 Four
    • pics
« Reply #9 on: June 28, 2007, 07:49:26 AM »
I used a yamaha R1 battery, it just barley fits under cowling.
with the starter and all the lights and some more lights no problems, so far! ???
« Last Edit: June 28, 2007, 07:52:23 AM by forwheeldrift »
scratch
« Reply #10 on: July 20, 2007, 01:29:06 PM »
I checked out your pictures- awesome job! Are you running just the speedometer? If so what did you use for a tach plug? I am looking to do the same.
scratch
« Reply #11 on: July 20, 2007, 01:33:47 PM »
I also like the rearsets, what are those off of?
  • 1972 cb 500 Four
    • pics
« Reply #12 on: July 24, 2007, 09:42:40 AM »
thanks
just the tach no speedo.
when im passing everyone i know im going fastenough ;D ;D
Offline Caferacernoc
« Reply #13 on: July 27, 2007, 12:38:35 PM »
   "I also like the rearsets, what are those off of?"
Yes, please share fourwheeldrift!
Nice bike by the way. I like how you keep tweaking it way past where most people would call it done.
Offline JZEROE
« Reply #14 on: March 02, 2008, 11:06:30 PM »
OK, so I'm *NOT* looking to relocate my battery for aesthetic reasons.
I want to drop my center of gravity. Seeing as I fired the stock airbox, I thought I would drop the cell down to sit on top of the swing arm pivot. Anyone have any luck with this arrangement? Any suggestions about where to stick a mount, or, better yet, where to drill? I always prefer to remove material rather than add it.
Thanks,
Joe
'75 CB400F
'76 CB750K - Project Freebike
« Reply #15 on: March 02, 2008, 11:38:47 PM »
If you are running without center stand, try underneath the swingarm. build a bracket so the battery slides in from the side, then a door or cover to keep it in.
Kosman had some cool battery holders that might give you some ideas.
eldar
« Reply #16 on: March 03, 2008, 07:23:28 AM »
When you do this, use and AGM battery though as you can mount them however you want. Just make sure to prevent too much vibration from shaking the battery. Just remember to try and maintain ground clearance, no sense lowering the CoG if you cant use it for cornering.
