Author Topic: CB750KO - Caliper pin problem  (Read 7352 times)
Offline Steve F
Re: CB750KO - Caliper pin problem
« Reply #25 on: January 25, 2010, 05:50:51 PM »
This would be my fix, as vibration has egged out the holes.
Ream or bore the swing bracket and the alum bracket that bolts to the fork (may only have to do the top on that one. Adjustable Ream or bore till it cleans up ar atleast 85%.
Then machine a new pin out of stainless, and add a grease or oil hole near the top of the swing bracket or grease it once in a while.
 i bet some people WASH IT REALLY REALLY GOOD at the car wash or with a pressure washer.. cuase there was a bit of seepage there.. that will surely make the problem worse..
Added.. checked one today.. the swing bracket could be bored and bushed, if the pin has not worn in the bracket. The one I looked at the pin was sticking in the swing bracket and pivoting in the  c shaped bracket.
Back on this subject - Is stainless steel hard enough to make a new pin from or should I have one machined in steel and then hardened?
Stainless is fine. again, no need to harden.  I was thinking of making some thin walled bronze bushings for mine after I ream the holes and maybe make a new pin too if it's worn unevenly.
« Reply #26 on: January 25, 2010, 08:41:37 PM »
I was looking at one, I think it needs a grease nipple, the whole problem is, it never gets lubed..
« Last Edit: January 26, 2010, 07:36:54 PM by 754 »
Offline Old Scrambler
« Reply #27 on: January 26, 2010, 05:16:07 PM »
Nice thread and I understand you are dealing with PO maintenance problems. I usually hit that pin with Teflon spray after a wash or ride in the rain. No rattles yet.........after 37 years and about 65,000 miles. Frank's fix will be applied to my K2 build.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline AshimotoK0
  • CB400/4, 69 CB750K0, '69 CB250SS, CB350K1 CB500K0
« Reply #28 on: January 28, 2010, 12:20:00 PM »
I have had a CAD drawing done for an oversize caliper pivot pin for the CB750K0/K1/K2 if anyone is interested. I am getting on made in Stainless Steel and reaming the hole in the arm and brackets out to 11mm. the standard pin is NLA from Honda and I don't even think Yamiya sell a repro one
“Alright friends, you have seen the heavy groups, now you will see morning maniac music. Believe me, yeah. It’s a new dawn.”
Offline nippon
    • Classic Cycle City
« Reply #29 on: January 28, 2010, 12:42:05 PM »
I made a new stainless steel pin and a bronze bushing for the aluminum bracket two years ago.
I'm pretty sure that there is not that much power on the pin to make a steel pin necessary.
I guess, if you do not use a bushing,....the soft aluminum bracket will be opened up again after thousands of miles.
So far, no clunks anymore.
nippon
« Last Edit: January 28, 2010, 12:50:35 PM by nippon »
Offline Johnie
« Reply #30 on: January 28, 2010, 01:28:59 PM »
As you may note I started this post back in February 2008 on my KO project. I never did fix it, but instead tightened the screw tension on the front pads a bit which helped some. But the noise is still there just not as bad. Is there someone willing to make some of those pins and bushings and offer them to the members with some profit of course for time, materials, etc. Appears to be a popular problem, but many of us do not have the tools to fabricate pins and bushings. I would still have to have the bracket drilled by someone.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Simpson
  • I ain't no
  • Aged to perfection
« Reply #31 on: January 28, 2010, 01:50:37 PM »
Suprised you can't find an OEM used replacement on ebay.
You could always shell out the big bucks. :)
http://www.yamiya750e.com/index.php?main_page=product_info&cPath=33_86&products_id=361
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Johnie
« Reply #32 on: January 28, 2010, 01:54:54 PM »
Agreed...Yamiya at $305 is pretty steep. I have seen them on eBay, but I have used and don't need another which will probably have the same problem. I like the idea of new pin and bushing.
Oshkosh, WI  USA
« Reply #33 on: January 28, 2010, 08:15:14 PM »
If I ever build oversize pins, I will try to put a grease nipple in.. the bottom would be good..hmmm.. wonder if they make them in 1/16 pipe thread..?
Offline Steve F
« Reply #34 on: January 30, 2010, 07:41:09 AM »
Most grease nipples are 1/16 pipe thread, and you can get them with just about ANY thread you want, even some that get pressed in.  Unless you leave internal space for the grease to get pumped in, a grease fitting would be ineffective and you just blow out the o-rings.  Just my opinion.  I'll stick to disassembly and packing w/ grease.
« Reply #35 on: January 30, 2010, 08:10:00 AM »
I looked yeasterday at a 1/4 NF nipple, that would work..
 No need to blow anything out, an 1/8 or 14 stroke of the grease gun will put new grease on the pin surface.. no need to grease up the rotor.
Offline hahnda
  • lskdfhs;dljksa;
« Reply #36 on: February 10, 2010, 08:14:06 AM »
Found this in a stack of Honda Service Bulletins I have.
Kevin
CB750K4 in pieces
CB750K3 with F trim
CB750K7
CB500 Cafe Project
CB750 Cafe
Offline Johnie
« Reply #37 on: February 10, 2010, 09:45:25 AM »
I saw that bulletin, but I could not get a spacer in there. No enough room.
Oshkosh, WI  USA
