Author Topic: New Toy ! Updated !#$%!@#! PO  (Read 4130 times)
Offline greenjeans
  • 1972 CB750K2
Re: New Toy ! Updated !#$%!@#! PO
« Reply #25 on: February 29, 2008, 07:51:01 AM »
Hey Spikey, I'm about  to go an look....just wanted to try something quick and easy - this thing hasn't run in years & I need to hear it.  patience ins't MY virtue
Thanks for the tip Bob, going to go see what I can find & pick up a battery.  check back in a bit
Offline Roach Carver
« Reply #26 on: February 29, 2008, 08:40:21 AM »
throw a pic up with as much info as you can. I may have one as well.
Offline greenjeans
  • 1972 CB750K2
« Reply #27 on: February 29, 2008, 03:57:04 PM »
Here's some pics of the carbs....thanks guys - lemme know what you think, don't see any obvious stamping to indicat what they are.  I'm probably not looking hard enough.
« Reply #28 on: February 29, 2008, 04:15:51 PM »
sorry, not what i got
Offline pampadori
  • slingshotcycles.com
    • Slingshot Cycles
« Reply #29 on: February 29, 2008, 04:56:04 PM »
Carbs.....!    PO had broken one of the posts that holds the main jet.  Not a bad crack, the jet still threads in and seems to seat pretty well.  But...it still has a visible crack.  Was thinking of using a tiny piece of teflon tape wrapped around the jet before re-installing as a cheap measure...probably on the lookout for some new carbs or just that one.  It's either the number 1 or 4....can't remember - need to go take a look again with fresh eyes.
exact same thing happened on one of mine.  noticed a jet sitting in the bowl.  looked at the hole it usually threads into and found it wasn't there.  also sitting in the bowl.  i ended up JB Welding the threaded part back to the carb body.  let it try for a couple hours and then put the jet back in.  filled up with fuel and went for a ride.  haven't thought about it since, so i guess its holding up well.
www.slingshotcycles.com
brake hoses and more!
SOHC4 is your coupon code for 15% off!
Offline droopy
« Reply #30 on: February 29, 2008, 05:52:48 PM »
I've got a like new carb body looks just like your pic
pm me
2007 lifan 200cc sport ohc thumper
« Reply #31 on: February 29, 2008, 05:55:57 PM »
Wow, an exact copy of my bike, color and all! Except the bent sidestand...what a beauty, what a steal of a deal!
Offline Tower
  • Only at conception could I have been called a
  • My personal time machine: 1973 CB750K3
« Reply #32 on: March 01, 2008, 09:04:29 AM »
Wow, @greenjeans, that's not just a good deal - its a fricking steal!
Here's a list of things to check based on what it took to bring my 73 CB750 K3 back from 16 years of storage...
http://forums.sohc4.net/index.php?topic=8077.msg105603#msg105603
I like your bike's colour, green.  And, if its original, so much the better.  Painting the tank was the biggest headache of the entire project.
I wouldn't try Teflon.  Its notorious for shredding.  Once the shreds are lodged in those tiny inner passages, then you'll have some real heartache.
Offline kghost
« Reply #33 on: March 01, 2008, 09:38:38 AM »
I can send you just the body....I have heaps of them
Stranger in a strange land
