Ok so I got the points firing right on the F mark, I took the valve cover off seeing as I had to replace all the bolts anyways and it is lined up exactly like it says in the manual, check the plug wires for position and spark again and they are right, but I still get no fire. It did start backfiring more from the #4 cylinder and I checked the plugs again and a couple of them seemed to have either gas or starter fluid on them, so at least it looks like I am getting fuel. But the damn thing still doesnt fire. I repainted the valve cover because it had a few scratches from putting it back together, so I have to wait for it to dry, then I will put it back together and try it again.
If I hold my hand over the exhaust or over the carb intakes, I can feel air moving in and out of them. I also checked the valve tappets and they are all moving up and down.
