Pretty sure I'll be very afraid to f#&k things up and constantly be checking the manual for every little detail, guess that's better than rushing it and start banging the pistons with a hammer...
Don't fret over that either! There is NUMEROUS ways to screw up and still recover. I just did my Goldwing's throttle cables 3 times in one night (didn't like the way they were routed)... took the air filter housing out 4 times (I thought I could squeeze the gaskit in after...). All that because I broke the throttle cables installing the Vista Cruise Control and trying to twist/slide the grip to get a little room at the switch housing.
SH!T, if I don't do it at least twice (trying to get it right), I don't feel like I've done anything. BUT, I learned a lot in the process!
I almost had tears in my eyes (and did have blood on my knuckles) from re-installing the carbs on my '77 CB550F. I used to think, 'to be sure there is an easier way than this," NOPE, sometimes it takes brute force to squeeze it in!
But I find it more rewarding (and a Helleva Lot Cheaper) than the dealer/stealer!
I've replaced the cables and hoses (brake and radiator), pads F&R, timing belts, thermostat, getting ready to do some points and timing, and the valves... I saw a guy that had a GW similar to mine, he's had it 5 months and had the dealer do some of this for him, $900 plus parts!
At this time I'm getting ready to go back into the timing belts on the GW. I think I got them too tight, they're 'singing and whining'. For those that don't know, that means removing the radiator AGAIN for the second time this month! I may have learned how to do this w/o removing the Rad since only an adjustment is needed. We'll see.
MOTORCYCLE GOD, PLEASE HELP US!
Later, Phil
