can't take good pictures right now,but i will later....promise...
all i did is i found an old piece of steel what happend to have the flat handke part on it,what i liked as soon as i saw it...
i straithend the rod and then i measured up an old 18mm socket,that has the perfect 7/8" size for the clutch handle to clamp on to,i welded thew socket onto the rod...
then i took off my foot shifter and cut off the part that clamps on the shifter shaft,and welded my new rod on there...
then i just pointed it up so it's more or less balanced,had to do abit of bending etc. to clear the tank...
next i routed my clutch cable up on the right down tube from the frame,curved it over the 2 middle exhaust pipes,down the left down tube of the frame,over the stator cover,up on the jockeyshift.....
tested the needed lenght of clutch cable to move freely when shifting and zip tied it to the down tube in such away that it left the needed free play...
all in all it took me 30 minutes,fighting to get the left handle grip off to remove the clutch lever etc..
now learning how to drive it is a different story,that took me awhile before i could take off full bore...but now i can,and it's awesome to shift that way..
just make sure you practice on a quit place....
