Author Topic: First post, resurrection of CB750K2  (Read 16228 times)
Offline Artfrombama
  • Card-carrying, board certified
  • CB750 K2
Re: First post, resurrection of CB750K2
« Reply #50 on: October 20, 2008, 06:22:47 AM »
Added replated junkyard rear grab bar, replated seat hardware. Finally disassembled and cleaned up those ratty shocks.
Now hoping to find a nice set of blinkers.
Halfassed machinist
Tinkerer/goof-off/Mr. Fix-it
CB750-2011594 Sunrise Flake Orange
CB750E2441103
« Reply #51 on: October 25, 2008, 08:32:51 AM »
That bike gets prettier on every post, Art.
Offline Artfrombama
  • CB750 K2
« Reply #52 on: October 25, 2008, 05:22:00 PM »
Thanks pal ;D
It's almost bondo and sandpaper time. It's gonna look sharp in Sunrise flake again!
Halfassed machinist
CB750E2441103
Offline Artfrombama
  • CB750 K2
« Reply #53 on: April 27, 2010, 06:29:43 PM »
OK, an update.
The bike runs great!
Smooth, responsive, doesn't foul plugs, (still ugly as ass) but a pleasure to ride.
Uses oil. About a quart in 300 miles.
If you really wrap the motor (rev it), when you let off the throttle you get a puff of smoke.
Valve guides?
Halfassed machinist
CB750E2441103
« Reply #54 on: April 27, 2010, 07:44:28 PM »
OK, an update.
Valve guides?
My first mechanical suspicion after its long sit: stuck rings. But, before doing anything about that, check the ignition timing and points gap? If the advancer is stuck (from stiff grease and crud) and not advancing/retracting the spark, it will act a lot like you describe. Also, if the points gap is too small (I'm presuming there is no electronic ignition, here) it will cause a weak spark which will burn oil, too.
For those possibly-stuck rings: pull the plugs and squirt in about 1/2 ounce of Marvel Mystery Oil or Bardahl "frees sticky valves" top end detergent oil, let it sit overnight, then repeat and let it sit 2 days. This will begin to loosen the carbon that makes the rings stick. Most K2 bikes ran a little rich and the pistons carboned up pretty badly. Honda did not slow down the spark curve on the advancers for the first few months of K2 production with those HM341 pipes, and the result was an overly-rich mix. Check your mainjets: if it still has the 110 mains, consider switching to 105 for the time being, until you get the rest of it sorted out. This will reduce the carbon issue. Today's fuels are slower burning than the 1970s gas, so carbon will be a bigger problem with the richer jets. I suggest using Shell mid-grade (or even regular) fuel for now to help clean up the old remains: you can think about premium fuel after some of the old carbon is burned off.
I'm so jealous of that perfect K2 seat: they were the most perfect fit on these bikes, IMO. Someday I'm gonna get me a new one for my K2...  ::)
Offline Artfrombama
  • CB750 K2
« Reply #55 on: April 27, 2010, 08:09:37 PM »
Think I'll powdercoat the frame, swingarm, battery tray. Send motor parts to be buffed/clear powder, paint the original orange flake, then do a top end overhaul.
This is one sweet riding bike!
Halfassed machinist
CB750E2441103
Offline Artfrombama
  • CB750 K2
« Reply #56 on: April 27, 2010, 08:31:31 PM »
Thanks Hondaman (as always) for your input. When I put the motor together I noticed quite a bit of corrosion in the intake ports (worked on the rings?) But the thing seems to have plenty of compression.
If any of youse are in the Atlanta area, come up to Road Atlanta and watch me race. They're gonna have a vintage bike race too, was outstanding last year, some really wild machines!
http://www.hsrrace.com/HSR/HSRHome.nsf/attachmentweb/EJEN-7Z4QMK/$file/Schedule.pdf?OpenElement
Halfassed machinist
CB750E2441103
Offline Artfrombama
  • CB750 K2
« Reply #57 on: June 15, 2010, 08:24:28 PM »
Well, I've been enjoying this old bike the better part of two years. In spite of the oil burning the engine has performed perfect, started instantly and after I figured out the little idiosyncrasies associated with a SOHC 750, I've really, really enjoyed this old bike.
Lately, I've noticed oil blowing out the front left side of the motor, between the head and the cylinders. Quite a bit of oil. I suppose it's time for a top end overhaul.
Halfassed machinist
CB750E2441103
Offline thacked
« Reply #58 on: June 17, 2010, 08:48:25 AM »
Nice bike!  Do you have any more recent pictures?
I'm up in Huntsville, I have an orange 550 that I'm currently working on:)
Offline Artfrombama
  • CB750 K2
« Reply #59 on: July 10, 2010, 05:58:39 PM »
Recent pictures look like old pictures. Thanks for the interest!
Rode to Decatur today, 80 mile round trip. Used a quart of oil. :'(
Stay tuned, top end overhaul coming up.... Around October
Halfassed machinist
CB750E2441103
Offline Artfrombama
  • CB750 K2
« Reply #60 on: March 13, 2016, 02:38:44 PM »
Bike runs fine around town and accelerates without a sputter to 80mph. If I give it full throttle anywhere north of 70mph it's like I "hit a wall", won't pick up speed and if I hold WOT the engine starts to drop cylinders and slow down. If I let off the throttle to maybe 2/3 throttle the engine clears up and accelerates back to  where I started.
Feels like I'm running out of gas.
Didn't notice this when I had the K&N pods, I now have a stock air box and emco filter.
Main jets are 125's (110's and 115's on the way).
Did a plug chop, plugs seemed a little dark but not gassed up.
points set at .014"
New plugs gapped to .024"
Does this sound like too much main jet??
Wasn't until six years later (last week) that I found the problem. Petcock was almost totally clogged with that white, puffy corrosion.
Halfassed machinist
CB750E2441103
